XnView MP crash at startup
#1
I have just installed Manjaro Linux on a Dell OptiPlex 790.
Generally, it works well, but XnView MP crash during startup of the application.
I have used XnView MP for several years on other hardware, and with various Linux distros, without any problems. So, I don’t know if this is Manjaro related or hardware related.
/ Hans Gatu
#2
xnviewmp is an AUR package. That means, if you updated your system, you might have to reinstall/recompile it.
Maybe you will also need the xnviewmp-system-libs package and install/reinstall that too, but always make sure your system is updated and then deal with AUR packages.
To trace what is causing the crash, open it from terminal and share here what error you get.
#3
I have uninstalled/reinstalled with no difference.
Terminal window result:
[~]$ xnviewmp
==> 1,000000 102,298601 96,000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1920 1014
w.init
XNVIEW SIZE 1920 1014
########### BrowserWindow :: BrowserWindow
libpng warning: iCCP: known incorrect sRGB profile
MENU install : 0x1dbd4e0
ThumbLoaderThread :: stop()
ThumbLoaderThread :: stop() ok
########### BrowserWindow :: ok create (640 480)
BrowserWindow :: changeVisibility()
########### BrowserWindow :: restoreState (1920 1014)
BrowserWindow :: restoreState => 1920 1014
=> 1658 800
BrowserWindow :: restoreState ok => 1658 800
XNVIEW SIZE ok
w.start
BrowserWindow :: onStart go
onFavoriteDockVisible (1)
BookmarkNode::BookmarkNode : 0x2057970
onCategoryFilterDockVisible (1)
onCategoryDockVisible (1)
########### BrowserWindow :: restoreState (1920 982)
BrowserWindow :: restoreState => 1920 982
=> 1658 625
BrowserWindow :: restoreState ok => 1658 625
BrowserWindow :: onStart 2
setPathname </home/gatu/>
ThumbLoaderThread :: setFileList(0)
ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : 1e88bf0
######ThumbLoaderThread :: forever : 1e88bf0
** start condition wait
ThumbLoaderThread :: setFileList() after wait
** start condition wake one 2
ThumbLoaderThread :: setFileList ok
######ThumbLoaderThread :: forever 2 : 1e88bf0
CHECK <0>
OPEN FOLDER
OPEN DB FOLDER ok
UPDATE DB FOLDER ok
OPEN FOLDER ok
updateLabels
updateLabels ok
######### CategoryModel :: checkAndSave()
TIME 0
BitmapLoadThread :: stop()
QObject::disconnect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
QObject::connect: No such signal CategoryView::selectionChanged(const DBFilterModel::DBFileList&)
Create children /home/gatu/
MyDirModelThread :: run
OPEN FOLDER done
ThumbLoaderThread :: setFileList(37)
BrowserWindow :: finish
sizeHints : 128
CHECK <36>
START 37
######ThumbLoaderThread :: start : 36
CHECK : <027_26.jpg>
LOAD BITMAP </home/gatu/Bilder/027_26.jpg>
onChildrenChecked 20 <Xerox-Phaser_6000_6010-1.0-1.i686>
sizeHints : 128
GFF :: LoadThumbnail : 0
CHECK : <1000-bitarspussel.png>
LOAD BITMAP </home/gatu/Bilder/1000-bitarspussel.png>
onChildrenChecked 17
onChildrenChecked 16
onChildrenChecked 15
onChildrenChecked 14
onChildrenChecked 13
onChildrenChecked 12
onChildrenChecked 9
onChildrenChecked 8
onChildrenChecked 3
thumbnail crack
libpng warning: IDAT: Too much image data
GFF :: LoadThumbnail : 15
CHECK <36>
START 37
ThumbLoaderThread :: setFirstItemToLoad
** start condition wake one 3
ThumbLoaderThread :: setFirstItemToLoad ok
CHECK : <10kB_Avatar.jpg>
LOAD BITMAP </home/gatu/Bilder/10kB_Avatar.jpg>
CHECK : <1967-2011.png>
LOAD BITMAP </home/gatu/Bilder/1967-2011.png>
ItemData :: update ==> Bilder OK
CHECK : <116830_jkl_s.jpg>
LOAD BITMAP </home/gatu/Hasse/116830_jkl_s.jpg>
CHECK : <222813842_3823b3cf-b708-4718-bf61-b6be7b0e76f1.jpg>
LOAD BITMAP </home/gatu/Hasse/222813842_3823b3cf-b708-4718-bf61-b6be7b0e76f1.jpg>
CHECK : <222813842_491e383f-0261-48f8-922d-b5469691138f.jpg>
LOAD BITMAP </home/gatu/Hasse/222813842_491e383f-0261-48f8-922d-b5469691138f.jpg>
ItemData :: update ==> Deklaration OK
ItemData :: update ==> Dokument OK
ItemData :: update ==> E-post OK
ItemData :: update ==> foo2zjs OK
ItemData :: update ==> foo2zjs-master OK
CHECK : <222813842_956f1431-1d97-4fdf-87c7-ada170974fad.jpg>
LOAD BITMAP </home/gatu/Hasse/222813842_956f1431-1d97-4fdf-87c7-ada170974fad.jpg>
CHECK : <02_640.png>
LOAD BITMAP </home/gatu/Mina dokument/02_640.png>
ItemData :: update ==> Hasse OK
ItemData :: update ==> Hämtningar OK
ItemData :: update ==> Ljudfiler OK
ItemData :: update ==> Mallar OK
CHECK : <123.xls>
LOAD BITMAP </home/dokument/123.xls>
my_error_exit…<Not a JPEG file: starts with 0xd0 0xcf>
GFF :: LoadThumbnail : 2
(then hundreds of rows with similar error message)
CHECK : <tahoma.ttf>
LOAD BITMAP </home/gatu/TTF4/tahoma.ttf>
my_error_exit…<Not a JPEG file: starts with 0x00 0x01>
CHECK : <tahomabd.ttf>
LOAD BITMAP </home/gatu/TTF4/tahomabd.ttf>
CHECK : <tallpaul.ttf>
LOAD BITMAP </home/gatu/TTF4/tallpaul.ttf>
free(): invalid next size (fast)
Avbruten (SIGABRT) (minnesutskrift skapad)
/ Hans Gatu
