Running the command
xinput set-prop 8 154 3 0 0 0 3 0 0 0 1
returns with the error code
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 131 (XInputExtension)
Minor opcode of failed request: 57 ()
Value in failed request: 0x9a
Serial number of failed request: 20
Current serial number in output stream: 21
Everything was working fine until I used mhwd to install the nvidia prorietary drivers. I’ve searched far and wide and have no idea how to deal with this issue. Please ask if there’s any more information you might need to help with this. Thank you!
