Posting this in the Graphics section as it started after I tried to upgrade.
If it matters, I just did this this morning. I have not yet done the 11/4 update. 10/19 was the last one I’ve done on this machine.
While logged into the desktop, I tried to upgrade the nvidia driver by running the following commands…
sudo mhwd -r pci video-nvidia-440xx
sudo mhwd -i pci video-nvidia-455xx
The desktop became unresponsive so I had to reboot thru the terminal.
After rebooting, I now have these errors on boot.
Failed to start Load Kernel Modules.
I switched to tty and ran the following…
journalctl -b -u systemd-modules-load.service --no-hostname --no-pager
Which shows the following errors…
Failed to insert module 'nvidia' : Exec format error
Failed to insert module 'nvidia_drm' : Exec format error
I tried reinstalling video-nvidia-440xx but I have the same issue still. If I remove all nvidia drivers I can boot but the desktop still doesn’t work right. All I can use is the terminal. Apps show the are open but I don’t see them.
Any help is appreciated!
P.S. I’m using kernel 5.8 currently.
