If you haven’t changed something, even by accident, it should still be there. I’ve used mine with 2 screens for ±4 years now, and it’s never done anything that I haven’t configured.
If you’re sure you haven’t changed anything, I recommend checking your cables, connectors, etc. because that sounds like hardware.
I also have use for years without issues.
After I figured out it was not working I have made sudo pacman -Syu this morning.
The following is the output you requested:
[mgem@dellg5 ~]$ xrandr
Screen 0: minimum 8 x 8, current 5120 x 1440, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
DP-0 connected primary 1920x1080+0+360 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
None-2-1 connected (normal left inverted right x axis y axis)
1920x1080 60.00 +
DP-1-1 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 59.95*+
1920x1080 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1280x1440 59.91
1680x1050 59.95
1280x1024 75.02 60.02
1440x900 59.89
1280x960 60.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
ok, I have tried to disconnect HDMI cable and reconnect again and now I am getting this:
HDMI-0 connected (normal left inverted right x axis y axis)
2560x1440 59.95 + 74.97
1920x1080 74.97 60.00 59.94 50.00
1680x1050 59.95
1440x900 59.89
1280x1440 59.91
1280x960 60.00
1280x720 60.00 59.94 50.00
800x600 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 75.00 72.81 59.94 59.93
1920x1080 144.00*+
1920x1080 60.00 +
2560x1440 59.95*+
1280x1440 59.91
1680x1050 59.95
1440x900 59.89
1280x960 60.00
832x624 74.55
720x576 50.00
720x480 60.00 59.94
720x400 70.08
2560x1440 (0x236) 241.500MHz +HSync +VSync
h: width 2560 start 2608 end 2640 total 2720 skew 0 clock 88.79KHz
v: height 1440 start 1443 end 1448 total 1481 clock 59.95Hz
1920x1080 (0x237) 148.500MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x238) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1280x1440 (0x23d) 156.000MHz -HSync +VSync
h: width 1280 start 1376 end 1512 total 1744 skew 0 clock 89.45KHz
v: height 1440 start 1443 end 1453 total 1493 clock 59.91Hz
1680x1050 (0x23e) 146.250MHz -HSync +VSync
h: width 1680 start 1784 end 1960 total 2240 skew 0 clock 65.29KHz
v: height 1050 start 1053 end 1059 total 1089 clock 59.95Hz
1280x1024 (0x23f) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x240) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x241) 106.500MHz -HSync +VSync
h: width 1440 start 1520 end 1672 total 1904 skew 0 clock 55.93KHz
v: height 900 start 903 end 909 total 934 clock 59.89Hz
1280x960 (0x242) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1280x720 (0x243) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x244) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1024x768 (0x246) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x247) 75.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.48KHz
v: height 768 start 771 end 777 total 806 clock 70.07Hz
1024x768 (0x248) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
800x600 (0x24a) 50.000MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.08KHz
v: height 600 start 637 end 643 total 666 clock 72.19Hz
800x600 (0x24b) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x24c) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
800x600 (0x24d) 36.000MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.16KHz
v: height 600 start 601 end 603 total 625 clock 56.25Hz
720x576 (0x24e) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x480 (0x250) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
640x480 (0x251) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x255) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
But I can’t enable the monitor in display configuration. But why I am getting the following 4th monitor that I don’t have? I only have internal screen and two external Philips monitors.
It looks good because video-nvidia is not installed and instead video-hybrid-nvidia-prime is installed.
It works, I can work with my two Philips external monitors but I still have that 4th monitor in the display configuration that does not make any sense.
So, must be then Intel and everything else is connected to nvidia?
I guess the reason is simply this: In modesetting mode and you use prime-reverse and no monitor is connected to intel, it needs at least a dummy monitor to initialize the Intel GPU . Therefore you see this unknown monitor.
