Xfce4-gtk3
xfce4-gtk3
#22
Phil,
Thanks for the information. I will stay in the unstable branch.
#23
Hi Guys, I have encountered a problem, I installed the xfce4 gtk3 panel by mistake and I do not like, I want to find the way to revert back to the original xfce4 panel that came with manjaro installation but when I try to do it through pacman an error appears “could not satisfy dependencies”
Is there a way to revert back? thank you all for your answers.
#24
What exactly are your dependency problems?
Lets see your terminal output when you try to install
sudo pacman -S xfce4-panel
#25
Hi, this is what appears
$ sudo pacman -S xfce4-panel
resolving dependencies…
:: xfce4-panel and xfce4-panel-gtk3 are in conflict. Remove xfce4-panel-gtk3? [y/N] Y
:: xfce4-whiskermenu-plugin-gtk3: removing xfce4-panel-gtk3 breaks dependency ‘xfce4-panel-gtk3’
#26
Try installing xfce4-whiskermenu-plugin at the same time
sudo pacman -S xfce4-panel xfce4-whiskermenu-plugin
and then say ‘yes’ to remove both xfce4-panel-gtk3 and xfce4-whiskermenu-plugin-gtk3
EDIT: Most likely you will also have to do this with / include some more packages, like exo(-gtk3), libxfce4ui(-gtk3) and garcon(-gtk3):wink:
#27
Why not install the whole group
sudo pacman -S xfce4 xfce4-goodies
#28
Open pamac and go to groups and search xfce-gtk3 and you mark uninstall to everything in there and in the xfce-goodies-gtk3 or something like that is the whiskermenu gtk 3 and you uninstall it but before applying you obviously need to mark the xfce(the gtk2) group completely and in the xfce-goodies you will find the original whisker menu,mark it and then apply.
#29
The problem is that xfce4 and xfce4-goodies groups include both gtk3 and gtk2 versions of some packages, so:
and then selecting all packages in the group(s) does not work.
One has to manually select the packages inside the group(s) (either gtk3 or gtk2, but not both).
#30
Instead of CLI, use Pamac. It has them separated.
#31
I don’t use Pamac, since last time I checked it would not work behind proxy. I use Octopi instead. I installed by manually selecting gtk2 package numbers.
Anyway, the groups should not contain conflicting versions of any package. It is a bad practice.
#32
Yes, I noticed that, too - thunar-gtk3 and xfce4-appfinder-gtk3 are in the xfce4 group by accident.
Will fix that asap. Thanks.
#33
I must say that i use xfce gtk3 from unstable repo more then one week and its work great.i have only few bugs that i fix (install other window manager metacity fix all my problem). so good work and i wait for some new package for xfce gtk3 :wink:
Screen Tearing Xfce
#34
Can you please specify exactly what problems you encounter?
#35
yes,I described it to xfce github but in short brief:
  • when i change icon theme icons did not change only on one tab xfce-session-logout (power off, reboot, sleep, hibernate)
  • with xfwm4 enable (setting/windows manager tweak/compositor/enable display compositor) i have strange menu blinking/disappearance like on screen`s
https://postimg.org/image/gtjdfq7vp/
https://postimg.org/image/aie5zb6n9/
after i disable xfwm4 windows manager in settings xfce looks ugly but it works - blinking menu stops appear so I start looking another wm and I discovered that when i replace xfwm4 wm to other (i install metacity) my bugs were gone and I did not notice others i use suspend, hibernate, screen lock, vpn, custom theme and everyday normal use so for me it`s quite stable now
https://postimg.org/image/7qvqd15c5/
#36
Thank you.
I was experiencing that, too, until I removed video-intel driver. Running with modesetting now, the issue has disappeared.
Only sound in VLC player
Transitioning to i3
#37
Could you please share links to your bug reports? I would love to follow-up on those.
#38
of course
menu blinking:
https://bugzilla.xfce.org/show_bug.cgi?id=13872
icons not change:
https://bugzilla.xfce.org/show_bug.cgi?id=13875
ps: i have intel graphics card too
#39
I too quickly praised that everything works xD
so there is the problem with “XFCE notifications service” is not runing with system start-up
cat /usr/lib/systemd/user/xfce4-notifyd.service
[Unit]
Description=XFCE notifications service
[Service]
Type=dbus
BusName=org.freedesktop.Notifications
ExecStart=/usr/lib/xfce4/notifyd/xfce4-notifyd
so… /usr/lib/xfce4/notifyd/xfce4-notifyd show me this error
error while loading shared libraries: libxfconf-0.so.2: cannot open shared object file: No such file or directory
it is related with the same bug https://github.com/manjaro/packages-extra/issues/111 ??? you wrote then that you update xfce4-session, xfce4-settings, xfce4-power-manager, panel, thunar, xfdesktop but you probably forgot about xfce4-notifyd
#40
Installing the right package xfce4-notifyd-gtk3 might help here.
#41
omg xD my mistake you have right!
but after i switch to manajro unstable and install
sudo pacman -S xfce4-gtk3 xfce4-gtk3-goodies
package xfce4-notifyd-gtk3 did not update like other package :confused: some xfce4 group problem?
