Running on a Dell XPS 15. When I boot I get a distorted login screen and desktop. After changing resolution in arandr and then back it resolves. Wondering if there is something I can do to permanently fix the issue.
Kernel: 5.10.36-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
Desktop: Budgie 10.5.2 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: XPS 15 9570 v: N/A serial: <filter>
Mobo: Dell model: 02MJVY v: A00 serial: <filter> UEFI: Dell v: 1.16.2
date: 04/21/2020
ID-1: BAT0 charge: 22.3 Wh (100.0%) condition: 22.3/56.0 Wh (39.7%)
volts: 12.8 min: 11.4 model: BYD DELL CP6DF87 status: Full
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
charge: 55% (should be ignored) status: Discharging
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check rev: A cache: L2: 9 MiB
bogomips: 52815
Speed: 1254 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 1254 2: 1212
3: 1202 4: 1206 5: 1205 6: 1219 7: 1227 8: 1223 9: 1247 10: 1254 11: 1202
12: 1202
Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nouveau
v: kernel bus-ID: 01:00.0
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:7
Display: x11 server: X.Org 1.20.11 driver: loaded: intel,nouveau
unloaded: modesetting resolution: 1: 1920x1080~60Hz 2: 1440x2560~60Hz
3: 2560x1440~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
v: 4.6 Mesa 21.0.3 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: Razer USA Razer Seiren Mini type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1.1:4
Sound Server-1: ALSA v: k5.10.36-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Rivet Networks driver: ath10k_pci v: kernel port: 3000
bus-ID: 3b:00.0
IF: wlp59s0 state: up mac: <filter>
IF-ID-1: br-d5490162fac3 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 238.47 GiB used: 95.34 GiB (40.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: PM981 NVMe 256GB
size: 238.47 GiB temp: 33.9 C
ID-1: / size: 216.83 GiB used: 95.32 GiB (44.0%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 18.1 MiB (6.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 16.81 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 73.0 C mobo: N/A gpu: nouveau temp: 40.0 C
Fan Speeds (RPM): cpu: 2509 fan-2: 2496
Processes: 313 Uptime: 8m Memory: 15.28 GiB used: 2.79 GiB (18.2%)
Init: systemd Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1511
Shell: Bash v: 5.1.8 inxi: 3.3.04
