Kernel: 7.2.0-rc2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2026-07-19_10-40-38/@/boot/vmlinuz-7.2-x86_64
root=UUID=a64f38b0-8e39-4df4-b595-d597fd0784c1 rw
rootflags=subvol=timeshift-btrfs/snapshots/2026-07-19_10-40-38/@ quiet
splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver dm: LightDM v: 1.32.0
Type: Laptop System: Framework product: Laptop 13 (AMD Ryzen AI 300 Series)
v: A5 serial:
Mobo: Framework model: FRANMGCP05 v: A5 serial:
part-nu: FRANVCCP05 uuid: bcd9a3f5-b3c0-f011-bfcd-245527900084
Firmware: UEFI vendor: INSYDE v: 03.04 date: 06/10/2025
ID-1: BAT1 charge: 52.4 Wh (83.2%) condition: 63/60.6 Wh (104%) volts: 17.72
min: 15.48 model: NVT FRANGWA type: Li-ion serial: charging:
status: charging cycles: 6
System RAM: total: 16 GiB available: 11.46 GiB used: 2.2 GiB (19.2%)
Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1
max: 1.1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMSX16GX5M1A4800C40 serial: N/A
Device-2: Channel-B DIMM 0 type: no module installed
Slot: 1 type: N/A status: available info: M.2, JWLAN length: short
bus-ID: c0:00.0
Slot: 2 type: N/A status: available info: M.2, JSSD1 length: short
bus-ID: bf:00.0
Info: model: AMD Ryzen AI 5 340 w/ Radeon 840M socket: FP8DDR5 bits: 64
type: MT MCP arch: Zen 6 note: 6 level: v4 note: check built: 2026+
process: TSMC n2/n3 (2,3nm) family: 0x1A (26) model-id: 0x60 (96)
stepping: 0 microcode: 0xB600037
smt: enabled cache: L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 6 MiB
desc: 6x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 625 min/max: 625/4900:3425:3275 boost: enabled
base/boost: 2000/4850 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 625 2: 625 3: 625 4: 625 5: 625
6: 625 7: 625 8: 625 9: 625 10: 625 11: 625 12: 625 bogomips: 47913
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx
ospke osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni
stibp succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale
umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: vmscape mitigation: IBPB on VMEXIT
Device-1: Advanced Micro Devices [AMD/ATI] Krackan [Radeon 840M / 860M
Graphics] vendor: Framework driver: amdgpu v: kernel arch: RDNA-3
code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3,
DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1 bus-ID: c1:00.0
chip-ID: 1002:1114 class-ID: 0380 temp: 45.0 C
Device-2: Framework Laptop Webcam Module (2nd Gen) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2
chip-ID: 32ac:001c class-ID: fe01 serial:
Display: x11 server: X.org v: 1.21.1.24 compositor: xfwm4 v: 4.20.0
driver: X: loaded: modesetting alternate: amdgpu,fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2880x1920 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: BOE Display NE135A1M-NY1 built: 2023 res:
mode: 2880x1920 hz: 120 scale: 100% (1) dpi: 257 gamma: 1.2 chroma: red:
x: 0.655 y: 0.333 green: x: 0.294 y: 0.624 blue: x: 0.145 y: 0.047 white:
x: 0.314 y: 0.329 size: 285x190mm (11.22x7.48") diag: 343mm (13.5")
ratio: 3:2 modes: 2880x1920, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
112
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon 840M Graphics (radeonsi krackan1
ACO DRM 3.64 7.2.0-rc2-1-MANJARO) device-ID: 1002:1114 memory: 3.91 GiB
unified: yes
gpu: amdgpu_top x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Framework driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c1:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Framework
driver: snd_acp_pci v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63,
snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c1:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Framework
bus-ID: c1:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k7.2.0-rc2-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.7 status: n/a (root, process) with:
Device-1: MEDIATEK MT7925 Wi-Fi 7 160MHz driver: mt7925e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: c0:00.0 chip-ID: 14c3:0717
class-ID: 0280
IF: wlp192s0 state: up mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 0e8d:0717
class-ID: e001 serial:
Local Storage: total: 931.51 GiB used: 18.58 GiB (2.0%)
model: WD BLACK SN7100 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 7615M0WD temp: 41.9 C scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
used: 18.58 GiB (2.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: a64f38b0-8e39-4df4-b595-d597fd0784c1
used: 668 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: N/A uuid: 7702-8435
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 1-1:2 info: Shenzhen Goodix Fingerprint USB Device
type: driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:609c class-ID: ef00 serial:
Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Device-1: 3-3:2 info: Framework Laptop Webcam Module (2nd Gen) type: video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 32ac:001c class-ID: fe01
serial:
Device-2: 3-5:3 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0717 class-ID: e001 serial:
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 49.9 C mobo: N/A
Fan Speeds (rpm): fan-1: 2204
Packages: 1229 pm: pacman pkgs: 1222 libs: 365 tools: pamac pm: flatpak
pkgs: 0 pm: snap pkgs: 7
1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
6: https://mirrors2.manjaro.org/stable/$repo/$arch
7: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
9: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
11: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
13: https://mirrors.manjaro.org/repo/stable/$repo/$arch
14: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
15: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
17: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirror.fcix.net/manjaro/stable/$repo/$arch
19: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
20: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
21: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
22: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
23: https://muug.ca/mirror/manjaro/stable/$repo/$arch
24: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
25: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
26: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
27: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
28: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
29: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
30: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
31: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
32: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
33: https://mirror.init7.net/manjaro/stable/$repo/$arch
34: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
35: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
36: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
37: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
38: https://mirror.23m.com/manjaro/stable/$repo/$arch
39: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
40: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
41: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
42: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
43: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
44: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
45: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
46: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
47: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
48: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
49: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
50: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
51: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
52: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
53: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
54: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
55: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
56: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
57: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
58: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
59: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
60: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
61: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
62: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
63: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
64: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
65: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
66: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
67: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
68: https://manjaro.grena.ge/stable/$repo/$arch
69: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
70: https://linorg.usp.br/manjaro/stable/$repo/$arch
71: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
72: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
73: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
74: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
75: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
76: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
77: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
78: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
79: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
80: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
81: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
82: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
83: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
84: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
85: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
86: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
87: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
88: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
89: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
90: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 399
1: cpu: 10.9% command: vivaldi-bin pid: 4216 mem: 307.4 MiB (2.6%)
2: cpu: 7.7% command: vivaldi-bin pid: 3438 mem: 369.1 MiB (3.1%)
3: cpu: 6.6% command: vivaldi-bin pid: 3673 mem: 286.4 MiB (2.4%)
4: cpu: 6.3% command: vivaldi-bin pid: 3488 mem: 231.4 MiB (1.9%)
5: cpu: 4.5% command: vivaldi-bin pid: 4135 mem: 269.0 MiB (2.2%)
Memory top: 5 of 399
1: mem: 369.1 MiB (3.1%) command: vivaldi-bin pid: 3438 cpu: 7.7%
2: mem: 307.4 MiB (2.6%) command: vivaldi-bin pid: 4216 cpu: 10.9%
3: mem: 286.4 MiB (2.4%) command: vivaldi-bin pid: 3673 cpu: 6.6%
4: mem: 269.0 MiB (2.2%) command: vivaldi-bin pid: 4135 cpu: 4.5%
5: mem: 231.4 MiB (1.9%) command: vivaldi-bin pid: 3488 cpu: 6.3%
Processes: 399 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 4.48 GiB services: upowerd,xfce4-power-manager Init: systemd v: 261
Compilers: N/A Shell: Sudo (sudo) v: 1.9.17p2 default: Bash v: 5.3.15
running-in: xfce4-terminal inxi: 3.3.41
Apologies if i missed something or am late to reply, am heading out for a few hours for a party but will reply when back, thank you for helping already <3
Edit: From what i remember journalctl gave me no insight when i did check it, will try the other one once back
