MicroSD drive support and configuration
Is it possible to use the eMMC for Manjaro and still have a large microSD card in for larger files and as a drive? I understand the boot priority, but is there a way around that? Or is it better to just use an external thumb drive in the dock?
I would like to use the microSD card to store larger files that would always be available on the OS.
Just do not have a bootable OS on the SD card. You might have to go into DIsks app and mount the SD card by hand.
Should mount to /run/media/manjaro/“label of SD”
In the Usage app / storage tab / if mounted you will see aprox. 32Gb + the size of your SD
