I am a noob and have been using Manjaro for about 2 months now. This morning I got a notification on the task bar that there were a few updates and I just ran all the updates, got coffee came back and now the second display monitor doesnt work anymore :(. I tried rebooting, booted into my other windows OS and works just fine. I even get the login screen on both monitors but when I log in the second display just goes blank and does not even show up on the display settings. I have a AMD Radeon RX 5500
I also tried reinstalling drivers. Hers is the result of my drivers
Blockquote
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
~]$ glxinfo | grep OpenGL
OpenGL vendor string: X.Org
OpenGL renderer string: Radeon RX 5500 XT (NAVI14, DRM 3.39.0, 5.9.11-3-MANJARO, LLVM 11.0.0)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 20.2.3
OpenGL core profile shading language version string: 4.60
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 20.2.3
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.2.3
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
inxi -G
Device-1: AMD Navi 14 [Radeon RX 5500/5500M / Pro 5500M]
driver: amdgpu v: kernel
Display: x11 server: X.Org' 1.20.10 driver: amdgpu,ati
unloaded: modesetting,radeon resolution: 1920x1080~60Hz
OpenGL: renderer: Radeon RX 5500 XT (NAVI14 DRM 3.39.0
5.9.11-3-MANJARO LLVM
Blockquote
Spent about an hour on the internets trying to find solutions, but no luck. Would really appreciate if anyone has any ideas. I am guessing it has something to do with the updates. I wish I checked what the updates were before installing them. Alas.
Oh also, Im running Linux 5.9.11-3-MANJARO
Thanks!
logan
