Hi,
Every time timeshift runs in the terminal i get this following error.
sudo timeshift-autosnap
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/nvme0n1p2' at '/run/timeshift/15984/backup'
E: ERROR: can't list qgroups: quotas not enabled
E: btrfs returned an error: 256
E: Failed to query subvolume quota
Creating new backup...(BTRFS)
Saving to device: /dev/nvme0n1p2, mounted at path: /run/timeshift/15984/backup
Created directory: /run/timeshift/15984/backup/timeshift-btrfs/snapshots/2023-01-02_13-10-28
Created subvolume snapshot: /run/timeshift/15984/backup/timeshift-btrfs/snapshots/2023-01-02_13-10-28/@
Created subvolume snapshot: /run/timeshift/15984/backup/timeshift-btrfs/snapshots/2023-01-02_13-10-28/@home
Created control file: /run/timeshift/15984/backup/timeshift-btrfs/snapshots/2023-01-02_13-10-28/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2023-01-02_13-10-28': ondemand
Mounted '/dev/nvme0n1p2' at '/run/timeshift/16127/backup'
Removing snapshot: 2022-12-31_21-08-51
Deleting subvolume: @ (Id:267)
Deleted subvolume: @ (Id:267)
Deleted directory: /run/timeshift/16127/backup/timeshift-btrfs/snapshots/2022-12-31_21-08-51
Removed snapshot: 2022-12-31_21-08-51
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Detecting snapshots ...
Found snapshot: 2023-01-02 13:10:28 | timeshift-btrfs/snapshots/2023-01-02_13-10-28/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-01-02 12:58:51 | timeshift-btrfs/snapshots/2023-01-02_12-58-51/@ | ondemand daily | {timeshift-autosnap} {created before upgrade} |
Found snapshot: 2023-01-01 23:10:58 | timeshift-btrfs/snapshots/2023-01-01_23-10-58/@ | ondemand | N/A |
Found snapshot: 2023-01-01 16:22:51 | timeshift-btrfs/snapshots/2023-01-01_16-22-51/@ | ondemand | N/A |
Found snapshot: 2022-12-31 23:40:09 | timeshift-btrfs/snapshots/2022-12-31_23-40-09/@ | ondemand | N/A |
Found snapshot: 2022-12-31 23:38:09 | timeshift-btrfs/snapshots/2022-12-31_23-38-09/@ | ondemand | N/A |
Found snapshot: 2022-12-31 23:06:36 | timeshift-btrfs/snapshots/2022-12-31_23-06-36/@ | ondemand daily | N/A |
Found snapshot: 2022-12-31 22:04:48 | timeshift-btrfs/snapshots/2022-12-31_22-04-48/@ | ondemand | {timeshift-autosnap} {created before upgrade} |
Found 8 snapshot(s)
Unmount /tmp/grub-btrfs.R90kcR8QH2 .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
