The OS doesn’t detect headphones instantly whenever I plug my headphones in the 3.5mm jack. I have to manually go every time to PulseAudio Volume Control -----> Output devices -----> Port. And change it from Speaker
to Headphones
. The problem didn’t exist before the last major update (giant 1+GB one).
Here is my system info by inxi -Fazy
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=b7f8ad79-6fb0-4053-b2f4-b41cd7833b15 rw quiet apparmor=1
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: vala-panel, xfce4-panel, plank
wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Dell product: Inspiron 5559 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0924RG v: A00 serial: <filter> UEFI: Dell v: 1.5.2
date: 07/18/2018
ID-1: BAT0 charge: 25.4 Wh condition: 34.6/32.6 Wh (106%) volts: 15.9/14.8
model: LGC-LGC2.80 DELL 991XP55 type: Li-ion serial: <filter>
status: Charging
Info: Dual Core model: Intel Core i3-6100U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: D6
L2 cache: 3072 KiB
bogomips: 18406
Speed: 500 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 500 2: 500 3: 500
4: 500
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:1916
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon
520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus ID: 01:00.0
chip ID: 1002:6660
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 0bda:5684 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: ati,intel,radeon
unloaded: modesetting alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 20.2.1
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d70
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: e000
bus ID: 02:00.0 chip ID: 8086:08b3
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus ID: 03:00.0 chip ID: 10ec:8136
Local Storage: total: 931.51 GiB used: 168.22 GiB (18.1%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw size: 63.48 GiB size: 62.23 GiB (98.04%) used: 18.67 GiB (30.0%)
fs: ext4 dev: /dev/sda8
ID-2: /home raw size: 92.58 GiB size: 90.62 GiB (97.89%)
used: 30.34 GiB (33.5%) fs: ext4 dev: /dev/sda9
ID-1: swap-1 type: partition size: 8.01 GiB used: 8.3 MiB (0.1%)
priority: -2 dev: /dev/sda7
System Temperatures: cpu: 44.0 C mobo: 41.0 C sodimm: 37.0 C gpu: radeon
temp: 42.0 C
Fan Speeds (RPM): cpu: 0
Processes: 226 Uptime: 5h 19m Memory: 7.67 GiB used: 3.18 GiB (41.4%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 10.0.1 Packages:
pacman: 1584 lib: 374 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.08
By mhwd -lh -d --pci
16: PCI 1f.3: 0403 Audio device
SysFS ID: /devices/pci0000:00/0000:00:1f.3
SysFS BusID: 0000:00:1f.3
Hardware Class: sound
Model: "Intel Sunrise Point-LP HD Audio"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x9d70 "Sunrise Point-LP HD Audio"
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x06b2
Revision: 0x21
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xdf320000-0xdf323fff (rw,non-prefetchable)
Memory Range: 0xdf300000-0xdf30ffff (rw,non-prefetchable)
IRQ: 132 (3276 events)
Module Alias: "pci:v00008086d00009D70sv00001028sd000006B2bc04sc03i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Driver Info #1:
Driver Status: snd_soc_skl is active
Driver Activation Cmd: "modprobe snd_soc_skl"
