“Newbie” here.
At first glance, every Linux distribution is laggy on my desktop computer, and I never understood why (i tried Debian, Ubuntu and Kali)… Today, I finally figured out it may be because of the Nvidia drivers.
So I tried again, but decided to use Manjaro instead, as it is my laptop’s distribution.
On a very fresh install, everything seems to work fine, except the usual lag (for exemple trying to select files in Dolphin makes the computer jump some frames…), but then I try to install the drivers.
I tried with the “Hardware configuration” by default in Manjaro, installing nvidia-utils and lib32-nvidia-utils, but :
- it is still laggy
- after one rebbot, i can log in, and now there is only my pointer, on the window, taking up the whole screen. I need to use another TTY output if I want to continue using my computer
For the hardware… :
Intel Core i5-8400 (2.8 GHz)
MSI GeForce GTX 1070 Ti ARMOR 8G, 8 Go
Manjaro version : 22.1.3
How should I install graphical drivers ?
