Pamac is working normally, but the buttons icon is different. I’ve tried changing the theme, updating the packages and changing the kernel and it’s still the same.
xfce 4.18
gtk 3.24.37
kernel 6.3.5
this icon insted of
and this
xfce 4.18
gtk 3.24.37
kernel 6.3.5
this icon insted of
and this
Do you have pamac
(gtk4) or pamac-gtk3
installed?
Do you mean
sudo pacman -Ss pamac* | grep installed
as far as i see it i only have these pamac packages installed
extra/libpamac 11.5.4-1 [installed]
extra/pamac-cli 10.5.1-2 [installed]
extra/pamac-gtk 10.5.1-2 [installed]
Which i believe is default … nevertheless be very careful with AUR. There are plenty of forum items about the AUR warning about broken systems.
https://packages.manjaro.org/?query=pamac
…but I realize now OP did designate Stable in their profile.
Post#1 mentions kernel v6.3.5 so must be on stable branch
Stable branch does not have pamac-gtk3 yet
So I suggest wait until next stable update and install pamac-gtk3
to replace pamac-gtk
After some time researching I ended up solving the problem with the command:
sudo pacman -Syu pamac-gtk
Even so, thanks for the help.
