after many trial and error i’ve hit a wall into what i can do.
after install and reboot, it loads for a very long time until i get an error saying ERROR: device 'UUID=’ not found skipping fsck. "
"mount: /new_root: can’t find UUID=
you are now being dropped into an emergency shell.
sh: cant access tty: job control turned off"
im using an HP 15 FD0083WM
any help would be appreciated
Welcome to the forum!
Here’s a few things you can do… Boot up from the Manjaro installer USB/DVD/CD in live mode, open a terminal window, and issue the following commands…
sudo su -
manjaro-chroot -a
lsblk -f
Check the UUID
of your root filesystem in that list, and compare that to the UUID
for your root filesystem in /etc/fstab
. If they differ, modify /etc/fstab
nano /etc/fstab
Next, make sure your system is up to date, rebuild your initcpio
s and update your boot loader configuration…
pacman-mirrors -f 5 && pacman -Syyu
mkinitcpio -P
update-grub
Let all commands finish. Do not press that reset button!
If it still doesn’t work on the next reboot, post the output of…
inxi -Fza
The root UUID in /boot/grub/grub.cfg
does not match with /etc/fstab
You can correct this in chroot in /etc/default/grub
sorry for the long delay in commenting or progress, i didnt have wifi for this live installer (had to use usb teathering) but now i can finally get somewhere
after doing lsblk -f this is what shows up
lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
loop1
loop2
loop3
sda
|-sda1
-sda2 sdb |-sdb1 |-sdb2 266.6M 10% /boot/efi |-sdb3 |-sdb4 |-sdb5
-sdb6 38.2G 15% /
also one other thing the UUID in /etc/fstab and /boot/grub//grub.cfg matched
Kernel: 6.1.30-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2213 quiet
systemd.show_status=1 splash apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-fd0xxx v: N/A
Mobo: HP model: 8B36 v: 62.30 serial: <superuser required> UEFI: AMI
v: F.06 date: 07/03/2023
ID-1: BAT0 charge: 15.9 Wh (37.7%) condition: 42.2/41.0 Wh (102.9%)
volts: 12.0 min: 11.2 model: HP Primary type: Li-ion serial: <filter>
status: charging cycles: 21
Info: model: Intel N200 bits: 64 type: MCP arch: Alder Lake level: v3
note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6
model-id: 0xBE (190) stepping: 0 microcode: 0x11
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 1x2 MiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 850 high: 1000 min/max: 800/3700 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 800 3: 800 4: 800
bogomips: 7988
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel Alder Lake-N [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46d0
class-ID: 0300
Device-2: Chicony HP True Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b78f
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1541 built: 2021 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo
missing.
Device-1: Intel vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:54c8 class-ID: 0401
API: ALSA v: k6.1.30-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek vendor: Hewlett-Packard driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:b85b
class-ID: 0280
IF-ID-1: enp0s20f0u4 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung Galaxy series misc. (tethering mode) driver: rndis_host
v: kernel type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:7 chip-ID: 04e8:6863 class-ID: 0a00 serial: <filter>
Device-2: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 0bda:b85d
Report: ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 147.85 GiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: Cruzer Glide
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 model: KLUDG4UHGC-B0E1 size: 119.2 GiB
block-size: physical: 4096 B logical: 4096 B tech: N/A serial: N/A
fw-rev: 1001 scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 223 Uptime: 2m wakeups: 239 Memory: available: 3.49 GiB
used: 2.39 GiB (68.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1163 libs: 325 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.27 ```
if anything else is needed to troubleshoot or whatever i’d be happy to try
Olli
26 August 2023 15:20
9
weapingwillow:
scheme: MBR
seems this install won’t work because you have to do an uefi-based install. please check your manufacturer-handbook for avaiable bios-settings (secure-boot etc.) and check the link below.
