I am running Manjaro XFCE with the latest updates, including the big ones that were released yesterday.
XFCE keyboard shortcuts don’t work while dropdowns are visible. For example, if I display the whisker menu and press printscreen, a screenshot is not added to my clipboard. If I do the same while any native dropdown widget is open in any software, third-party or otherwise, the screenshot is also not added then. If I don’t have a dropdown visible, my keybinds work again.
This is not a new issue as of yesterday. It has been present since I switched from Windows to Manjaro 2 weeks ago.
How can I fix this? Is there an alternative global keybinding system that is GUI-configurable that doesn’t have limitations?
Ok i see a limitation, that you can only use 2 function keys. That means Print is a function key. You can use Print with other function keys like: CTRLALTSUPER , but not with other keys, while CTRLALTSUPER can be use with letters. I guess this is a made by design this way to keep it simple.
Cant take screenshot when an application menu is open https://bugzilla.xfce.org/show_bug.cgi?id=12323
The work around:
Start the Screenshot application
Set a Delay
Click ok
Go to the window you want to capture and expand a menu.
This worked for me. The “Print Screen” button did not.
GIMP has a screen capture menu item under File > Create > Screenshot.... Sometimes it is nice to be able to add text or bullets to a screen capture, but of course you can do this with XFCE screenshot too via Open With....
