Bluetooth not seeing devices Manjaro Gnome - Macbookpro 8.1
Hello, I’m trying to connect to speakers and headphones on Bluetooth, but without success. My macbook is visible from other devices. However the macbook/Manjaro does not seem to see any device in bluetooth. How to fix this? I did not find the information online.
Here is some extracts from my terminal :
systemctl status bluetooth                                       ✔
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset>
     Active: active (running) since Thu 2022-07-28 16:03:01 CEST; 21min ago
       Docs: man:bluetoothd(8)
   Main PID: 515 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 19067)
     Memory: 2.2M
        CPU: 66ms
     CGroup: /system.slice/bluetooth.service
             └─515 /usr/lib/bluetooth/bluetoothd
inxi -Fazy :
  Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
    root=UUID=e0bbbafe-3056-407e-96b9-460854661fca rw quiet splash apparmor=1
  Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
    v: 42.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
    serial: <superuser required> Chassis: type: 10 v: Mac-94245B3640C91C81
  Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
    serial: <superuser required> UEFI: Apple v: 87.0.0.0.0 date: 06/13/2019
  ID-1: BAT0 charge: 51.8 Wh (96.1%) condition: 53.9/62.9 Wh (85.8%)
    volts: 12.3 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
    status: full cycles: 1471
  Info: model: Intel Core i5-2435M bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 built: 2010-12 process: Intel 32nm family: 6 model-id: 0x2A (42)
    stepping: 7 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1325 high: 1689 min/max: 800/3000 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1081 2: 1348 3: 1689
    4: 1182 bogomips: 19161
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
    vendor: Apple driver: i915 v: kernel arch: Gen6 process: Intel 32nm
    built: 2011 ports: active: LVDS-1
    empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
  Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
    bus-ID: 1-2:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
    compositor: gnome-shell driver: gpu: i915 display-ID: 0
  Monitor-1: LVDS-1 model: Apple 0x9ccb serial: <filter> built: 2009
    res: 1280x800 dpi: 114 gamma: 1.2 size: 286x179mm (11.26x7.05")
    diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
  OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 22.1.3
    direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
    chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
    driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
  IF-ID-1: wlp3s0b1 state: up mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
    bus-ID: 1-1.1.3:8 chip-ID: 05ac:821a class-ID: fe01
  Local Storage: total: 2.27 TiB used: 262.53 GiB (11.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK5065GSXF
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: 8B scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Expansion
    size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 0712 scheme: GPT
  ID-1: / raw-size: 409.96 GiB size: 402.46 GiB (98.17%)
    used: 262.53 GiB (65.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 397 MiB size: 396.2 MiB (99.79%)
    used: 1.2 MiB (0.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: partition size: 17.21 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda5 maj-min: 8:5
  System Temperatures: cpu: 77.0 C mobo: 0.0 C
  Processes: 245 Uptime: 21m wakeups: 3 Memory: 15.54 GiB
  used: 2.03 GiB (13.1%) Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1361
  lib: 352 flatpak: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
  inxi: 3.3.19
