XFCE: How to autostart a sudo-script on boot
boot
xfce
autostart
systemd-boot
#1
Hi,
since my switch to Manjaro XFCE this script does not autostart on boot anymore.
rc.local:
#!/bin/bash
# /usr/local/sbin/rc.local: Local multi-user startup script.
sudo dell-bios-fan-control 0
sudo modprobe i8k force=1
echo 'ik8' | sudo tee -a /etc/modules
systemctl start i8kmon
then chmod +x the rc.local file
copied to:
reboot
Doesn’t work on XFCE. :confused:
Please can anybody help to find a working solution?
pappl
#2
I would try copying it to /etc/profile.d although… Manjaro has several different ways of autostarting things: https://wiki.archlinux.org/index.php/Autostarting
#3
Hi,
tried several options:
/etc/profile.d/autostart.sh -> Doesn’t work
/home/pappl/.config/autostart/autostart.desktop -> Doesn’t work
Add .sh to to autostart in XFCE settings -> Doesn’t work
:thinking:
#4
It won’t work in xfce startup as it uses sudo.
What about a systemd unit?
[Unit]
Description=Example systemd service.
[Service]
Type=simple
ExecStart=/bin/bash /usr/bin/your-script-here.sh
[Install]
WantedBy=multi-user.target
Take out the sudo commands and move to /usr/bin
:face_with_symbols_over_mouth:, i quit trying.
I stopped trying to start a file script on boot.
Opened XFCE settings -> Session and Startup -> Add -> Command:
sleep 10 && sudo dell-bios-fan-control 0 && sudo modprobe i8k force=1 && sleep 1 && echo 'ik8' | sudo tee -a /etc/modules && systemctl start i8kmon
Reboot -> Doesn’t work.
If i copy/paste it in the terminal it works.
Do these autostart variations support sudo on startup?
EDIT 1: Yes, this doesn’t support sudo
EDIT 2:
Will try now.
#6
Right, been trying to recall how to do this as it has been a few months :smiley:
# Create your.service in:
/etc/systemd/system/yourname.service
# Enable it:
sudo systemctl enable yourname.service
reboot
It works!
Thanks a lot. :hugs::+1:
Here a summary of required steps:
1. Create and edit a bash-file (.sh) with your terminal commands.
Leave all
sudo , will be done automaticly!
Using nano text editor here:
sudo nano /usr/bin/autostart.sh
Paste this into the created .sh file:
#!/bin/bash
# /usr/bin/autostart.sh: Local multi-user startup script.
place your terminal-command 1 here
place your terminal-command 2 here
place your terminal-command 3 here and so on
Edit your commands 1, 2, 3,…
If you are using nano then save by pressing Ctrl+O -> hit Enter -> Ctrl+X
do a:
chmod +x '/usr/bin/autostart.sh' to set permissions.
2. Create systemd service to run the .sh on boot:
then:
sudo nano '/lib/systemd/system/autostart.service'
Copy/paste the following into the editor:
[Unit]
[Service]
Type=simple
ExecStart=/bin/bash /usr/bin/autostart.sh
[Install]
Press Ctrl+O -> Hit Enter -> Ctrl+X if you are using nano text editor.
3. Now start services and enable to restart on boot:
sudo systemctl start autostart
sudo systemctl status autostart
sudo systemctl enable autostart
reboot, all commands will be executed on boot.
:grinning:
