Xfce "Free Space Checker" panel plugin shows wrong values for NAS
The correct data for the NAS are (same readable in inxi -Fxxxz as you could see below):
Local Storage: total: 3.87 TiB used: 1.25 TiB (32.3%)
Also the admin GUI of the NAS says so:
The correct data for the OS partition is 177,29 GB free.
177,29 GB free for NAS (wrong) and 177,29 GB free for OS partition (correct).
  Host: pc Kernel: 5.3.11-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 9.2.0 Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37)
  v: 2.0 serial: <filter> UEFI [Legacy]: American Megatrends v: A.40
  date: 09/10/2019
  Topology: 8-Core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen
  L1 cache: 512 KiB L2 cache: 4096 KiB L3 cache: 32.0 MiB
  bogomips: 115250
  Speed: 2633 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 3530 2: 2055 3: 2049 4: 2057 5: 1866 6: 1899 7: 2697 8: 1930 9: 1966
  10: 2051 11: 1927 12: 2042 13: 2800 14: 1896 15: 3585 16: 2046
  Device-1: NVIDIA GF114 [GeForce GTX 560 Ti] vendor: CardExpert
  driver: nouveau v: kernel bus ID: 2d:00.0 chip ID: 10de:1200
  Display: x11 server: X.Org 1.20.5 driver: nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa resolution: 1920x1080~60Hz, 1920x1080~60Hz
  OpenGL: renderer: NVCE v: 4.3 Mesa 19.2.4 direct render: Yes
  Device-1: NVIDIA GF114 HDMI Audio vendor: CardExpert
  driver: snd_hda_intel v: kernel bus ID: 2d:00.1 chip ID: 10de:0e0c
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 2f:00.4 chip ID: 1022:1487
  Device-3: Logitech HD Webcam C910 type: USB
  driver: snd-usb-audio,uvcvideo bus ID: 5-3:2 chip ID: 046d:0821
  serial: <filter>
  Sound Server: ALSA v: k5.3.11-1-MANJARO
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 27:00.0
  chip ID: 10ec:8168
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
Argument "1TB" isn't numeric in numeric eq (==) at /usr/bin/inxi line 11522.
Use of uninitialized value within @row in pattern match (m//) at /usr/bin/inxi line 11562.
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
  speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: P3CR013 scheme: MBR
  ID-2: /dev/sda vendor: Samsung model: HD103UJ size: 931.51 GiB
  speed: 3.0 Gb/s serial: <filter> rev: 1112 scheme: MBR
  ID-3: /dev/sdb vendor: Samsung model: SSD 840 PRO Series size: 238.47 GiB
  speed: 6.0 Gb/s serial: <filter> rev: 4B0Q scheme: MBR
  ID-4: /dev/sdc vendor: Western Digital model: WD10EFRX-68JCSN0
  size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> rev: 1A01 scheme: MBR
  ID-5: /dev/sdd vendor: Western Digital model: WD10EFRX-68JCSN0
  ID-1: / size: 862.34 GiB used: 641.18 GiB (74.4%) fs: ext4
  dev: /dev/nvme0n1p4
  System Temperatures: cpu: 51.2 C mobo: N/A gpu: nouveau temp: 38 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 1140
  Processes: 467 Uptime: 1d 9h 00m Memory: 31.38 GiB used: 8.88 GiB (28.3%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash (su) v: 5.0.11
  running in: bash inxi: 3.0.36
BTW if i use a name in Xfce "Free Space Checker" panel plugin all other values ar not visible. not expected. see here:
BTW this sh script works nearly correct: https://gist.github.com/sl5net/158d3cdb9f91f7482661874eb483e447
you may want compare this issue with this issue: https://stackoverflow.com/questions/58927403/disk-usage-info
Opening a bug report
https://goodies.xfce.org/projects/panel-plugins/xfce4-fsguard-plugin
would be better.
https://bugzilla.xfce.org/show_bug.cgi?id=16202
