I’ve got a pi-hole running on my network, and my router’s DNS is pointed directly there. All other devices that have DHCP enabled automatically pull their DNS from the router, go to the pi-hole, and see no ads.
Much to my astonishment, when I opened up Chromium in XFCE, there were ads everywhere. I used the Network applet in the bottom menubar thing to manually set the DNS to the pi-hole in both IPv4 and IPv6, and all the ads disappeared.
Is this the expected default behavior? Shouldn’t having everything set to auto, the way it comes on a clean install, automatically get the proper DNS addresses from the router/gateway address? I know it was getting valid IP addresses from the router, and the connection was working before I did anything. Just not the correct DNS. I’m very confused.
I just realized I forgot to check the resolv.conf file to figure out what the values were before I changed them. Sorry about that.
