[Xfce] Cairo Dock screen issue
Hi, all.
Bummer that the old forum went down and lost all of its posts. Anyway, I am experiencing issues with Cairo. A long “stripe” has appeared approx. 2-3 cm. above the bottom on the screen and it doesn’t disappear. How do I fix this? Apparently, I can’t post pictures or links, so I will have to host it on Imgur. imgur dot com slash iW7nHZV.png
-Thanks
Hello,
Yeah, still good we can read some of the old posts…
You will need to disable Show shadows under dock windows in Settings > Window Manager Tweaks > Compositor and that stripe will go away :slight_smile:
Aaand… IT’S SOLVED! Thanks again, Bogdan :slight_smile:
