Hello, I want to apologize first if this is not the right place for this, but here me out I have laptop Asus t300chi this is a touchscreen laptop with Bluetooth keyboard in 2021 I installed manjaro XFCE on it and everything worked fine only the keyboard didn’t connect at start but because it is touchscreen I was able to use onboard to fill my passwords so didn’t bothered me. Long story short my manjaro broke and I needed to reinstall I downloaded the latest version of manjaro XFCE and installed it, but when I tried to pair my keyboard the manjaro Bluetooth didn’t detect it at all it detects other devices as my phone and turned on devices in the area but not the keyboard. I then installed Fedora Gnome and it worked ok, but my mouse buttons were detected as one button so I decided to try Mint XFCE and again the same problem there is no keyboard detection so I installed manjaro KDE and the keyboard works now perfectly so my question is is there any possible way to fix this on XFCE. Thanks in advance!
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=5ee9140e-5500-44bb-9eda-5ebe93f13145 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: T300CHI v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: T300CHI v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: T300CHI.207 date: 08/06/2015
ID-1: BAT0 charge: 8.1 Wh (30.6%) condition: 26.5/31.3 Wh (84.6%) volts: 7.6
min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 25
Device-1: asus-keyboard-1c:b7:2c:15:91:6e-battery model: ASUS T300CHI
DOCKING serial: N/A charge: N/A status: discharging
RAM: total: 3.74 GiB used: 1002.5 MiB (26.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core M-5Y10c bits: 64 type: MT MCP arch: Broadwell
level: v3 built: 2015-18 process: Intel 14nm family: 6 model-id: 0x3D (61)
stepping: 4 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 499 min/max: 500/2000 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 499 2: 499 3: 499 4: 499 bogomips: 7985
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5300 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:161e class-ID: 0300
Device-2: Realtek USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:57d2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x106d built: 2014 res: 1920x1080
hz: 60 dpi: 177 gamma: 1.2 size: 276x155mm (10.87x6.1") diag: 317mm (12.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 5300 (BDW GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-4:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 117.38 GiB used: 10.26 GiB (8.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD i110 128GB
size: 117.38 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 000 scheme: GPT
ID-1: / raw-size: 117.08 GiB size: 114.68 GiB (97.95%) used: 10.26 GiB
(9.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 5ee9140e-5500-44bb-9eda-5ebe93f13145
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 421B-39FC
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 1-4:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-5:3 info: Realtek USB2.0 HD UVC WebCam type: Video
Device-3: 1-7:4 info: Synaptics Synaptics Touch Digitizer V04 type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 400mA chip-ID: 06cb:11f0 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 178 Uptime: 2m wakeups: 2 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1082
pm: pacman pkgs: 1077 libs: 312 tools: pamac pm: flatpak pkgs: 5 Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
