[ARM Stable Update] 2022-08-16 - Thunderbird, Plasma, Gnome, CoreApps and Kernels
Hello ARM community.
Preparing for our 22.08 release! Keep an eye out in the coming days for new images!
Some highlights:
  • Most of our kernels got updated to 5.19
  • Thunderbird updated to 91.12.0
  • Plasma updated to 5.25.4
  • Mesa updated to 22.1.6
  • Gnome updated to 42.4
  • LibreOffice updated to 7.3.5
  • Firefox updated to 103.0.2
  • CoreApps updated to 4.4.0
  • Lots of updated packages for our Mobile offerings
  • The regular Python updates
  • And regular updates from upstream
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installed. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
Chromium will loose sync support in early March:
Arch Linux - News: Chromium losing Sync support in early March
ghostpcl>=9.53.2-2 and ghostxps>=9.53.2-2 updates require manual intervention:
The nss and zn_poly packages requires manual intervention:
Arch Linux - News: zn_poly 0.9.2-2 update requires manual intervention
The packages hplip and firewalld requires manual intervention:
Package changes:
(Tue Aug 16 13:06:30 CEST 2022)
  • arm-stable community aarch64: 592 new and 540 removed package(s)
  • arm-stable core aarch64: 48 new and 46 removed package(s)
  • arm-stable extra aarch64: 534 new and 533 removed package(s)
  • arm-stable kde-unstable aarch64: 353 new and 353 removed package(s)
:: Different overlay package(s) in repository community aarch64
                             PACKAGE           2022-08-03          2022-08-16
                          callaudiod   0.1.4+1+gd380d60-2   0.1.4+9+g7f2c637-1
                          coreaction              4.3.0-1              4.4.0-1
                        corearchiver              4.3.0-1              4.4.0-1
                              corefm              4.3.0-1              4.4.0-1
                          coregarage              4.3.0-1              4.4.0-1
                            corehunt              4.3.0-1              4.4.0-1
                           coreimage              4.3.0-1              4.4.0-1
                            coreinfo              4.3.0-1              4.4.0-1
                        corekeyboard              4.3.0-1              4.4.0-1
                             corepad              4.3.0-1              4.4.0-1
                           corepaint              4.3.0-1              4.4.0-1
                             corepdf              4.3.0-1              4.4.0-1
                            corepins              4.3.0-1              4.4.0-1
                         corerenamer              4.3.0-1              4.4.0-1
                            coreshot              4.3.0-1              4.4.0-1
                           corestats              4.3.0-1              4.4.0-1
                           corestuff              4.3.0-1              4.4.0-1
                        coreterminal              4.3.0-1              4.4.0-1
                            coretime              4.3.0-1              4.4.0-1
                        coretoppings              4.3.0-1              4.4.0-1
                        coreuniverse              4.3.0-1              4.4.0-1
                            electron             19.0.9-1             20.0.2-1
                          electron17             17.4.9-1            17.4.11-1
                          electron18             18.3.6-1             18.3.8-1
                     element-desktop             1.11.1-1             1.11.2-1
                         element-web             1.11.1-1             1.11.2-1
                 glacier-browser-git    0.1.r2.gae35d42-1                    -
                    glacier-calc-git  0.3.1.r3.g6ba3925-1                    -
                  glacier-camera-git  0.1.2.r6.g7447f14-1                    -
             glacier-filemuncher-git    0.3.r8.gaf14838-1                    -
                 glacier-gallery-git 0.2.3.r22.g8f8f87c-1                    -
                   glacier-music-git  0.2.3.r0.gfb09d18-1                    -
                glacier-pinquery-git    0.3.r3.ga3d3a3a-2                    -
                glacier-settings-git 0.1.3.r17.g9d3c1ed-1                    -
                              hwinfo              21.82-1               22.1-1
                           libcprime              4.3.0-1              4.4.0-1
                             libcsys              4.3.0-1              4.4.0-1
                             libdsme             0.66.6-1             0.66.7-1
                                phoc0.21.0beta1+21+ge367874-2  0.21.0+3+gcee43cf-1
                               phosh0.20.0beta3+4+gd4728aea-1 0.20.0+2+g4a93126f-1
              plasma-mobile-settings           20220628-1           20220812-1
                         python-gatt              0.2.7-2              0.2.7-3
                qt5-sensors-sensorfw             5.15.4-1             5.15.5-1
                      signal-desktop             5.50.1-1             5.53.0-1
                                vvmd                0.9-1               0.10-1
                                 yay             11.2.0-1             11.3.0-1
                          electron19                    -            19.0.12-1
              glacier-alarm-listener                    -                0.1-1
                     glacier-browser                    -              0.1.2-1
                      glacier-camera                    -              0.1.4-1
                    glacier-contacts                    -              0.8.1-1
                      glacier-dialer                    -              0.5.1-1
                 glacier-filemuncher                    -              0.3.2-1
                     glacier-gallery                    -              0.3.1-1
                        glacier-mail                    -              0.0.2-1
                    glacier-messages                    -              0.2.4-1
                       glacier-music                    -              0.3.1-1
                    glacier-pinquery                    -              0.3.4-1
               nemo-device-pinephone                    -                0.8-1
     nemo-qml-plugin-folderlistmodel                    -               0.15-1
      nemo-qml-plugin-statusnotifier                    -              1.0.1-1
         nemo-qml-plugin-thumbnailer                    -              1.0.6-1
                         qt5-systems                    -               5.12-1
                        qtdocgallery                    -         5.3.0+git3-1
                              ventoy                    -             1.0.79-2
                           voicecall                    -             0.7.14-1
                           watchmate                    -              0.2.0-1
:: Different sync package(s) in repository community aarch64
                            algol68g              2.8.5-6              3.0.6-1
                        algol68g-doc              2.8.5-6              3.0.6-1
                       android-tools             31.0.3-3             31.0.3-7
                             ansible              6.1.0-1              6.2.0-1
                     archlinux-repro           20220606-1           20220805-1
                        avr-binutils               2.38-2               2.39-1
                             aws-cli            1.25.17-2            1.25.48-1
                              awxkit             21.3.0-1             21.4.0-1
                              babeld               1.12-1             1.12.1-1
                                bamf              0.5.5-2              0.5.6-1
                             baresip              2.5.1-1              2.6.0-1
                              batctl             2022.1-1             2022.2-1
                           bctoolbox             5.1.51-1             5.1.55-1
                           benchmark              1.6.2-1              1.7.0-1
                       bitwarden-cli           2022.6.2-2           2022.8.0-1
                             blender           17:3.2.1-1           17:3.2.2-1
                               boinc             7.18.1-1             7.20.2-1
                           boinc-nox             7.18.1-1             7.20.2-1
                            boinctui              2.5.2-1              2.6.0-1
                          bootconfig               5.18-1               5.19-1
                                 bpf               5.18-1               5.19-1
                               brook           20220401-1           20220404-1
                             buildah             1.26.2-1             1.27.0-1
                               bzrtp             5.1.51-1             5.1.55-1
                             calibre              6.2.1-1              6.3.0-1
                              camlp4             4.13+1-3             4.14+1-3
                              camlp5                8.0-3                8.0-4
                          cargo-crev             0.23.2-1             0.23.3-1
                          cargo-deny             0.12.1-1             0.12.2-1
                        cargo-expand             1.0.28-1             1.0.29-1
                       cargo-feature              0.6.0-1              0.7.0-1
                       cargo-nextest             0.9.33-1             0.9.34-1
                      cargo-zigbuild             0.11.3-1             0.12.0-1
                           catatonit              0.1.7-1              0.1.7-2
               cgroup_event_listener               5.18-1               5.19-1
                               chafa             1.12.0-1             1.12.1-1
                               charm             0.12.1-1             0.12.3-1
                            cinnamon              5.4.8-1              5.4.9-1
             cinnamon-control-center              5.4.4-1              5.4.6-1
                cinnamon-screensaver              5.4.1-1              5.4.2-1
            cinnamon-settings-daemon              5.4.3-1              5.4.4-1
                             clojure        1.11.1.1149-1        1.11.1.1155-1
                             cockpit                273-1              274.1-1
                         cockpit-pcp                273-1              274.1-1
                          containerd              1.6.6-1              1.6.8-1
                   containers-common           1:0.48.0-1           1:0.48.0-2
                            copr-cli              1.101-1              1.101-2
                                 coq             8.15.0-1             8.15.0-3
                             coq-doc             8.15.0-1             8.15.0-3
                              coqide             8.15.0-1             8.15.0-3
                            corectrl              1.2.4-2              1.2.7-1
                              cosign              1.9.0-1             1.10.1-1
                           cpp-hocon             0.3.0-10             0.3.0-11
                            cpupower               5.18-1               5.19-1
                               cri-o             1.24.1-1             1.24.2-1
                            crypto++              8.6.0-2              8.7.0-1
                              csvkit              1.0.6-3              1.0.7-1
                                 cue              0.4.2-2              0.4.3-1
                              dagger             0.2.27-1             0.2.29-1
                         dark-reader             4.9.52-1             4.9.55-1
                           dart-sass             1.54.0-1             1.54.4-1
                          difftastic             0.31.0-1             0.32.0-1
                         dns-lexicon             3.11.3-1             3.11.3-2
                      dnscrypt-proxy              2.1.1-3              2.1.2-1
                      docker-compose              2.6.1-1              2.9.0-1
                             doctest              2.4.7-1              2.4.9-1
                            dokuwiki         20220626rc-1           20220731-1
                                dpdk              22.03-1              22.07-1
                                dpkg             1.21.8-1             1.21.9-1
                              dqlite             1.10.0-1             1.11.1-1
                               draco              1.5.1-2              1.5.3-1
                               drone             2.12.0-1             2.12.1-1
                           drone-oss             2.12.0-1             2.12.1-1
                           drumstick              2.6.1-1              2.7.0-1
                              drupal              9.4.2-1              9.4.4-1
                             dua-cli             2.17.7-1             2.17.8-1
                                dune              3.3.1-1              3.4.1-2
                            electrum              4.2.2-1              4.3.0-1
                          emscripten             3.1.17-1             3.1.18-1
                             esptool                4.1-1              4.2.1-1
                              facter            3.14.23-2            3.14.24-1
                              faudio              22.07-1              22.08-1
                          featherpad              1.3.0-1              1.3.1-1
                            feeluown              3.8.6-1              3.8.7-1
                ffnvcodec-headers8.1          8.1.24.11-2          8.1.24.13-1
                                 fio               3.29-1               3.31-1
                 firefox-dark-reader             4.9.52-1             4.9.55-1
                             fluxctl             1.25.2-1             1.25.3-1
                                foot             1.12.1-2             1.13.0-1
                       foot-terminfo             1.12.1-2             1.13.0-1
                         fortune-mod             3.14.0-1             3.14.1-1
                              fossil               2.18-1               2.19-1
                             freecad               0.20-1             0.20.1-2
                          frotz-dumb               2.53-1               2.54-1
                       frotz-ncurses               2.53-1               2.54-1
                           frotz-sdl               2.53-1               2.54-1
                              fulcio              0.1.1-2              0.5.2-1
                                 fzf             0.31.0-1             0.32.1-1
                               gajim              1.4.5-2              1.4.7-2
                            gamemode              1.6.1-2                1.7-1
                              gauche             0.9.11-3             0.9.12-1
                               gcovr                5.1-1                5.2-1
                                gdal              3.5.1-1              3.5.1-2
                                 gdu             5.14.0-1             5.15.0-1
                               geany               1.38-2               1.38-3
                              gensio              2.3.5-2              2.4.1-1
                               gephi              0.9.5-1              0.9.7-1
               git-credential-gopass             1.12.0-1             1.14.3-1
                               gitea             1.16.9-1             1.17.0-1
                          github-cli             2.13.0-1             2.14.4-1
                                  go           2:1.18.4-1             2:1.19-1
                         go-ethereum            1.10.20-1            1.10.21-1
                            go-tools           4:0.1.11-2           4:0.1.12-1
                               go-yq             4.27.1-1             4.27.2-1
                              gopass             1.14.3-1             1.14.4-1
                         gopass-hibp             1.12.0-1             1.14.3-1
                               gopls              0.9.1-1              0.9.2-1
                          goreleaser              1.9.2-1             1.10.3-1
                          gpio-utils               5.18-1               5.19-1
                             gpodder            3.10.21-2             3.11.0-1
                                 gum              0.2.0-4              0.4.0-1
                              hatari              2.3.1-2              2.4.0-1
                              hcloud             1.30.1-1             1.30.2-1
                           heaptrack              1.3.0-2              1.4.0-1
                                helm              3.9.0-1              3.9.3-2
                            helmfile            0.144.0-1            0.145.2-1
                        herbstluftwm              0.9.4-2              0.9.5-1
                               hevea               2.35-1               2.36-1
                               hivex             1.3.21-6             1.3.21-7
                      home-assistant         1:2022.7.4-2         1:2022.8.2-1
                               hugin           2021.0.0-4           2021.0.0-5
                              hyperv               5.18-1               5.19-1
                           ibus-m17n              1.4.9-1             1.4.10-1
                          ibus-table             1.16.9-1            1.16.11-1
                               icewm              2.9.8-1              2.9.9-1
                           iio-utils               5.18-1               5.19-1
                  interception-tools              0.6.8-4              0.6.8-5
                               iperf              2.1.7-1              2.1.8-1
                                 iwd               1.27-1               1.29-1
                             jansson               2.14-2                    -
                             jenkins              2.361-1              2.363-1
                                jmol           14.32.66-1           14.32.67-1
                               jsmol           14.32.66-1           14.32.67-1
                                just              1.3.0-1              1.4.0-1
                                 k9s             0.26.0-2             0.26.3-1
                             kak-lsp             12.2.1-1             13.0.0-2
                                 kea              2.0.2-2              2.0.3-2
                            kea-docs              2.0.2-2              2.0.3-2
                              kotlin              1.7.0-1             1.7.10-1
                             kubectx              0.9.1-2              0.9.4-1
                               kubie             0.17.2-1             0.18.0-1
                           kustomize              4.5.4-2              4.5.7-1
                            lablgtk3              3.1.2-2              3.1.2-3
                            laborejo              2.1.0-1              2.2.0-1
                          leatherman             1.12.7-2             1.12.8-2
                           leiningen              2.9.8-2             2.9.10-2
                       libimagequant              4.0.0-1              4.0.1-1
                libmemcached-awesome              1.1.1-1              1.1.2-1
                             libmgba              0.9.3-3              0.9.3-4
                              libnfs              5.0.1-2              5.0.2-1
                              libp11             0.4.11-2             0.4.12-1
              libperconaserverclient          8.0.28_19-2          8.0.29_21-1
                          librdkafka              1.9.1-1              1.9.2-1
                               libre              2.5.0-1              2.6.1-1
                              librem              2.5.0-1              2.6.0-1
                             libvirt            1:8.5.0-3            1:8.6.0-2
                      libvirt-python            1:8.5.0-1            1:8.6.0-1
             libvirt-storage-gluster            1:8.5.0-3            1:8.6.0-2
        libvirt-storage-iscsi-direct            1:8.5.0-3            1:8.6.0-2
                         libwhereami             0.5.0-12             0.5.0-13
                    linux-tools-meta               5.18-1               5.19-1
                             liteide               37.4-3               38.0-1
                           log4cplus              2.0.7-1              2.0.8-1
                            logwatch                7.6-1                7.7-1
                 lua-language-server              3.5.1-1              3.5.3-1
                              luajit2.1.0.beta3.r431.g5677985d-12.1.0.beta3.r439.g633f265f-1
                                 mac               7.56-1               8.43-1
                            mailman3              3.3.5-5              3.3.5-6
                               mdcat             0.27.1-1             0.28.0-1
                                 med              4.1.0-8              4.1.1-1
                       mediastreamer             5.1.51-1             5.1.55-1
                         meilisearch             0.28.0-1             0.28.1-1
                             mgba-qt              0.9.3-3              0.9.3-4
                            mgba-sdl              0.9.3-3              0.9.3-4
                               micro             2.0.10-4             2.0.11-4
                            minetest              5.5.1-1              5.6.0-1
                     minetest-common              5.5.1-1              5.6.0-1
                     minetest-server              5.5.1-1              5.6.0-1
                            minikube             1.26.0-1             1.26.1-1
                      mongo-c-driver             1.21.2-1             1.22.0-1
                              muffin              5.4.4-1              5.4.5-1
                           musescore              3.6.2-5              3.6.2-7
                                 mvt              1.5.5-1              2.1.2-1
                                mypy              0.961-1              0.971-1
                              nebula              1.5.2-2              1.6.0-1
                           neovim-qt             0.2.17-1             0.2.17-2
                             nerdctl             0.22.0-1             0.22.2-1
                      netcdf-fortran              4.5.4-1              4.6.0-1
              netcdf-fortran-openmpi              4.5.4-1              4.6.0-1
                             netdata             1.35.1-1             1.36.0-1
                 networkmanager-l2tp             1.20.4-1             1.20.4-5
           networkmanager-strongswan              1.5.2-4              1.5.2-5
                           nextcloud             24.0.3-1             24.0.4-1
                  nextcloud-app-mail             1.13.6-1             1.13.7-1
                  nextcloud-app-news             18.1.0-1             18.1.1-1
                    nextcloud-client            2:3.5.3-1            2:3.5.4-1
     nextcloud-client-cloudproviders            2:3.5.3-1            2:3.5.4-1
                           nicotine+              3.2.2-2              3.2.3-1
                              nikola              8.2.2-1              8.2.3-1
                       nlohmann-json             3.10.5-1             3.11.2-1
                               nomad              1.3.2-1              1.3.3-1
                                 npm             8.15.1-1             8.17.0-1
                   npm-check-updates             15.0.0-1             15.0.2-1
                          ocaml-base             0.15.0-1             0.15.0-2
                         ocaml-cairo              0.6.3-1              0.6.3-2
      ocaml-compiler-libs-repackaged             0.12.4-3                    -
                         ocaml-csexp              1.5.1-4              1.5.1-5
                       ocaml-findlib              1.9.5-1              1.9.5-2
                      ocaml-hashcons                1.3-4                1.3-5
                        ocaml-lablgl              1.06-11              1.06-12
                           ocaml-num                1.4-5                1.4-6
                            ocaml-pp              1.1.2-2              1.1.2-3
                  ocaml-ppx_derivers              1.2.1-8              1.2.1-9
                      ocaml-sexplib0             0.15.1-1             0.15.1-2
                         ocaml-stdio             0.15.0-1             0.15.0-2
                  ocaml-stdlib-shims              0.3.0-4              0.3.0-5
                        ocaml-zarith               1.12-4               1.12-5
                          ocamlbuild             0.14.1-1             0.14.1-2
                                 oil             0.12.0-1             0.12.3-1
                                opam              2.1.2-1              2.1.3-1
                            openblas             0.3.20-1             0.3.21-1
                            openfire              4.7.2-1              4.7.3-1
                         openimageio           2.3.16.0-2           2.3.18.0-1
                            openrct2              0.4.1-2              0.4.1-3
                            opensips              3.2.6-1              3.3.0-1
                         openvswitch             2.16.4-1             2.17.2-1
                                ortp             5.1.51-1             5.1.55-1
                             osbuild                 60-1                 63-2
                    otf-font-awesome              6.1.1-1              6.1.2-1
                           paperwork              2.1.1-1              2.1.1-2
                  papirus-icon-theme           20220710-1           20220808-1
                                pdal              2.4.2-3              2.4.3-1
                               pdfjs           2.14.305-1           2.15.349-1
                      percona-server          8.0.28_19-2          8.0.29_21-1
              percona-server-clients          8.0.28_19-2          8.0.29_21-1
                                perf               5.18-1               5.19-1
          perl-file-sharedir-install               0.13-6               0.14-1
                           perl-json               4.07-1               4.09-1
                      perl-test-trap              0.3.4-5              0.3.5-1
                      perl-type-tiny           1.012005-1           1.016006-1
                  perl-www-mechanize               2.12-1               2.13-1
                         pgformatter                5.2-3                5.3-1
                        phpldapadmin            1.2.6.3-1            1.2.6.4-1
                     plantuml-server           1.2022.6-1           1.2022.6-2
                              podman              4.1.1-2              4.1.1-4
                       podman-docker              4.1.1-2              4.1.1-4
                                poke                2.3-1                2.4-1
                              popeye             0.10.0-1             0.10.1-2
                                ptex              2.4.1-3              2.4.2-1
                              pulumi             3.37.1-1             3.37.2-1
                              puppet             7.17.0-1             7.18.0-1
                               pyenv              2.3.2-1              2.3.3-1
                             pyright            1.1.264-1            1.1.266-1
                       python-apipkg              2.1.1-1              3.0.1-1
                    python-asttokens              2.0.5-2              2.0.7-1
                     python-autobahn             22.6.1-1             22.7.1-1
           python-aws-sam-translator             1.48.0-1             1.49.0-1
                        python-boto3            1.24.27-1            1.24.48-1
                     python-botocore            1.27.27-1            1.27.48-1
                       python-bottle            0.12.21-1            0.12.23-1
                    python-braintree             4.15.2-1             4.16.0-1
                     python-cachelib              0.8.0-2              0.9.0-1
                    python-crashtest              0.3.1-6              0.4.0-1
                        python-crate             0.27.0-1             0.27.1-1
                python-cssbeautifier             1.14.4-1             1.14.5-1
                         python-dask           2022.6.1-1           2022.7.1-1
                      python-debugpy              1.6.2-1              1.6.2-2
                  python-distributed           2022.6.1-1           2022.7.1-1
                         python-docs             3.10.4-1             3.10.6-1
                     python-dominate              2.6.0-5              2.7.0-1
                   python-dotty-dict              1.3.0-5              1.3.1-1
              python-email-validator              1.2.0-1              1.2.1-1
                    python-executing              0.9.1-1             0.10.0-1
                   python-findpython              0.2.0-1              0.2.1-1
                     python-fixtures             3.0.0-12              4.0.1-1
                python-flask-caching              2.0.1-1              2.0.1-2
                  python-flask-login              0.6.1-1              0.6.2-1
                   python-frozendict            1:2.3.3-1            1:2.3.4-1
                         python-gdal              3.5.1-1              3.5.1-2
                       python-gitlab              3.7.0-1              3.8.1-1
     python-google-api-python-client             2.51.0-1             2.56.0-1
                     python-graphviz               0.20-1             0.20.1-1
                    python-hatchling              1.5.0-1              1.6.0-1
                       python-hcloud             1.16.0-2             1.17.0-1
                     python-identify              2.5.2-1              2.5.3-1
                   python-ipywidgets              7.7.1-1              7.7.1-2
                          python-irc             20.0.0-2             20.1.0-1
                 python-jsbeautifier             1.14.4-1             1.14.5-1
                        python-json5              0.9.8-1              0.9.9-1
                   python-jsonschema              3.2.0-6              4.9.0-1
                 python-kaitaistruct                0.9-5               0.10-1
                  python-lark-parser             0.12.0-1              1.1.2-1
                         python-ldap              3.4.0-1              3.4.2-1
                  python-levenshtein             0.12.2-3             0.20.1-2
                      python-libtmux             0.11.0-1             0.14.0-1
                     python-llvmlite             0.38.1-1             0.39.0-1
               python-logilab-common              1.9.6-1              1.9.7-1
                       python-nbxmpp              3.1.0-1              3.1.1-1
                     python-networkx              2.8.4-1              2.8.5-1
     python-openapi-schema-validator              0.1.5-3              0.3.0-1
                  python-oslo-config              8.8.0-1              9.0.0-1
                   python-oslo-utils             4.11.0-1             4.12.0-1
                        python-parso            1:0.8.2-3            1:0.8.3-1
                          python-pbr              5.9.0-1             5.10.0-1
                          python-pdm              2.1.0-1              2.1.1-1
                 python-phonenumbers            8.12.52-1            8.12.53-1
                       python-pipenv           2022.7.4-1          2022.7.24-1
                        python-pybcj              0.6.1-1              1.0.1-1
                      python-pycares              4.2.1-1              4.2.2-1
                     python-pydantic              1.9.1-2              1.9.2-1
                     python-pyflakes              2.4.0-3              2.5.0-1
                  python-pygame-sdl21:2.1.0.r411.7f814e9-11:2.1.0.r411.7f814e9-2
                python-pylink-square             0.14.1-1             0.14.2-1
                      python-pymupdf             1.20.1-1             1.20.2-1
                   python-pynitrokey             0.4.25-1             0.4.27-1
                       python-pyppmd             0.18.2-1             0.18.3-1
                   python-pytest-mpl             0.15.1-1             0.16.1-1
         python-pytest-rerunfailures               10.2-3               10.2-4
                      python-pytools           2022.1.7-1           2022.1.9-1
                       python-pyzstd             0.15.2-1             0.15.3-1
                    python-rapidjson                1.7-1                1.8-1
                      python-rcssmin              1.1.0-3              1.1.1-1
                    python-reportlab             3.6.10-1             3.6.11-1
                         python-rpyc              5.1.0-1              5.2.3-1
          python-scikit-hep-testdata             0.4.12-3             0.4.16-3
                        python-scipy              1.9.0-1              1.9.0-2
                      python-serpent               1.40-3               1.41-1
python-setuptools-declarative-requirements              1.2.0-3              1.3.0-1
               python-setuptools-scm              7.0.4-1              7.0.5-1
                           python-sh             1.14.2-3             1.14.3-1
                  python-shellingham              1.4.0-4              1.5.0-1
                   python-simplejson             3.17.6-3             3.17.6-4
                  python-sounddevice              0.4.2-2              0.4.4-1
                        python-spsdk              1.6.3-3              1.7.0-1
                   python-stack-data              0.3.0-1              0.4.0-1
                       python-svglib              1.3.0-1              1.4.1-1
                      python-testflo              1.4.8-1              1.4.9-1
                      python-tomlkit             0.11.1-1             0.11.4-1
                       python-tzdata             2022.1-1             2022.2-1
                 python-versioningit              2.0.0-1              2.0.1-1
                       python-vistir              0.5.2-5              0.5.6-1
                         python-wand              0.6.8-1              0.6.9-1
                           python-z3              4.9.0-1              4.9.1-1
                      python2-future             0.18.2-2                    -
                 python2-pygame-sdl21:2.1.0.r411.7f814e9-1                    -
                               quilt               0.66-2               0.67-1
                                raft             0.13.0-1             0.14.0-1
                             rathole              0.4.2-1              0.4.3-1
                              raylib              4.0.0-2              4.2.0-1
                              rclone             1.59.0-1             1.59.1-1
                      reactphysics3d              0.8.0-2              0.9.0-1
                 reactphysics3d-docs              0.8.0-2              0.9.0-1
                              reaper               6.64-1               6.65-1
                              recoll             1.32.1-1             1.32.5-1
                              revive              1.2.1-1              1.2.3-1
                               rizin              0.3.4-1              0.4.0-1
                           robin-map              0.6.3-1              1.0.1-1
                                ruby              3.0.4-2              3.0.4-5
                          ruby-async             1.29.0-1             1.30.3-1
                      ruby-async-dns              1.2.5-1              1.2.6-1
                       ruby-async-io             1.30.2-1             1.33.0-1
                    ruby-bundledgems              3.0.4-2              3.0.4-5
                        ruby-bundler             2.3.18-1             2.3.19-1
                        ruby-daemons              1.3.1-2              1.4.1-1
                           ruby-docs              3.0.4-2              3.0.4-5
                          ruby-erubi             1.10.0-2             1.11.0-1
                            ruby-hoe             3.22.3-3             3.24.0-1
          ruby-jekyll-sass-converter              2.1.0-2              2.2.0-1
                       ruby-minitest             5.15.0-1             5.16.2-1
                ruby-minitest-sprint              1.2.1-2              1.2.2-1
                        ruby-msgpack              1.5.3-1              1.5.4-1
                     ruby-mustermann              1.1.1-1              3.0.0-1
                      ruby-nats-pure              2.1.0-1              2.1.2-1
                       ruby-nokogiri             1.13.6-1             1.13.8-2
                  ruby-path_expander              1.1.0-3              1.1.1-1
                        ruby-pcaprub             0.12.4-8             0.13.1-1
                             ruby-pg              1.4.2-1              1.4.3-1
                           ruby-rack              2.2.3-2              2.2.4-1
                        ruby-rainbow              3.0.0-6              3.1.1-1
                        ruby-sqlite3              1.4.2-5              1.4.4-1
                         ruby-stdlib              3.0.4-2              3.0.4-5
                         ruby-timers              4.3.2-2              4.3.3-1
                        ruby-trollop              2.1.3-4             2.9.10-1
                           ruby-yard             0.9.26-2             0.9.28-1
                       rust-analyzer           20220725-1           20220808-1
                           rz-cutter              2.0.5-3              2.1.0-2
                           rz-ghidra              0.3.0-3              0.4.0-3
                             s2n-tls             1.3.11-1             1.3.19-1
                       schemacrawler           16.16.12-1            16.17.3-1
                              scrcpy               1.23-2               1.24-1
                             scribus              1.5.8-7              1.5.8-8
                             scummvm              2.5.1-1              2.6.0-1
                       scummvm-tools              2.5.0-3              2.6.0-1
                          sentry-cli              2.1.0-1              2.5.0-1
                             ser2net              4.3.4-2              4.3.7-1
                               siege              4.1.2-1              4.1.5-1
                                sile             0.13.3-1             0.14.2-1
                               skate              0.2.0-2              0.2.1-3
                              skopeo              1.9.1-1              1.9.2-1
                            smartdns               36.1-1                 37-2
                                 snd               22.5-1               22.6-1
                          soft-serve              0.3.2-1              0.4.0-2
                         spire-agent              1.1.1-1              1.4.0-1
                        spire-server              1.1.1-1              1.4.0-1
                                sqlc             1.14.0-1             1.15.0-1
                            sqlx-cli              0.6.0-1              0.6.1-1
                         staticcheck           2022.1.2-1           2022.1.3-1
                             step-ca             0.20.0-1             0.21.0-1
                          strongswan              5.9.5-1              5.9.7-1
                           stylelint             14.9.1-1            14.10.0-1
        stylelint-config-recommended              8.0.0-1              9.0.0-1
           stylelint-config-standard             26.0.0-1             27.0.0-1
                          swi-prolog              8.4.2-2              8.4.3-1
                                syft             0.49.0-1             0.53.4-1
                           tailscale             1.26.1-1             1.28.0-1
                           taplo-cli              0.6.9-1             0.6.10-1
                                tcsh            6.24.00-2            6.24.01-1
                    telegram-desktop              4.0.2-4              4.1.0-1
                           terraform              1.2.6-1              1.2.7-1
                          terragrunt             0.38.1-1             0.38.7-1
                           texstudio              4.2.3-1              4.3.0-1
             thunderbird-dark-reader             4.9.52-1             4.9.55-1
                               tiled              1.9.0-1              1.9.1-1
                    timescaledb-tune             0.13.0-1             0.13.1-1
                             tinyssh           20220311-1           20220801-1
                              tllist              1.0.5-3              1.1.0-1
                                tmon               5.18-1               5.19-1
                               tmuxp             1.11.1-1             1.12.1-1
                                 tor            0.4.7.8-1            0.4.7.9-1
                             traefik              2.7.0-1              2.8.3-1
                         ttc-iosevka             15.5.0-1             15.6.3-1
                    ttc-iosevka-aile             15.5.0-1             15.6.3-1
                   ttc-iosevka-curly             15.5.0-1             15.6.3-1
              ttc-iosevka-curly-slab             15.5.0-1             15.6.3-1
                  ttc-iosevka-etoile             15.5.0-1             15.6.3-1
                    ttc-iosevka-slab             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss01             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss02             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss03             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss04             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss05             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss06             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss07             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss08             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss09             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss10             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss11             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss12             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss13             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss14             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss15             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss16             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss17             15.5.0-1             15.6.3-1
                    ttc-iosevka-ss18             15.5.0-1             15.6.3-1
                    ttf-font-awesome              6.1.1-1              6.1.2-1
          typescript-language-server             0.11.2-1              1.0.0-1
                          ufw-extras              0.7.0-2              0.7.0-3
                               ugrep              3.8.3-1              3.9.0-1
                             unbound             1.16.1-1             1.16.2-1
                              upterm              0.8.2-1              0.9.0-1
                             urlscan              0.9.9-2             0.9.10-1
                               usbip               5.18-1               5.19-1
                            usbredir             0.12.0-1             0.13.0-1
         v2ray-domain-list-community     20220730021420-1     20220813040114-1
                         v2ray-geoip       202207280056-1       202208110837-1
                                vals             0.16.2-1             0.18.0-1
                             vicious              2.5.0-1              2.5.1-1
                        virt-install              4.0.0-1              4.1.0-1
                        virt-manager              4.0.0-1              4.1.0-1
           vscode-css-languageserver             1.69.0-1             1.70.0-1
          vscode-html-languageserver             1.69.0-1             1.70.0-1
          vscode-json-languageserver             1.69.0-1             1.70.0-1
                           watchexec             1.20.4-1             1.20.5-1
                             web-ext              7.1.1-1              7.2.0-1
                              websvn              2.6.1-2              2.7.0-1
                             wezterm20220624.141144.bd1b7c5d-220220807.113146.c2fee766-1
                               xonsh             0.13.0-1             0.13.1-1
                          xtrabackup          8.0.27_19-4          8.0.29_22-1
                               yaegi             0.12.0-1             0.14.1-1
                               yosys               0.12-6               0.12-7
                                  z3              4.9.0-1              4.9.1-1
                              zellij             0.31.0-1             0.31.1-1
                           zeroc-ice              3.7.7-1              3.7.8-1
                     zsh-completions             0.34.0-1             0.34.0-2
                   alsa-scarlett-gui                    -                0.2-2
                       camlp-streams                    -              5.0.1-1
                               cmctl                    -              1.9.1-1
                  cockpit-packagekit                    -              274.1-1
                    cockpit-storaged                    -              274.1-1
                                  ct                    -              0.9.3-1
                              datree                    -              1.6.6-1
                            earlyoom                    -                1.7-1
                              eksctl                    -            0.108.0-1
                               jumpy                    -              0.4.3-1
                      kube-apiserver                    -             1.24.3-2
             kube-controller-manager                    -             1.24.3-2
                          kube-proxy                    -             1.24.3-2
                      kube-scheduler                    -             1.24.3-2
                             kubeadm                    -             1.24.3-2
                             kubectl                    -             1.24.3-2
                kubectl-cert-manager                    -              1.9.0-1
                             kubelet                    -             1.24.3-2
     kubernetes-control-plane-common                    -             1.24.3-2
                       libretro-mame                    -              83471-1
                         med-openmpi                    -              4.1.1-2
                        meson-python                    -              0.8.1-1
                            openh264                    -              2.3.0-2
       prometheus-wireguard-exporter                    -              3.6.3-1
                        python-bleak                    -             0.15.1-1
                      python-fnvhash                    -              0.1.0-3
     python-home-assistant-bluetooth                    -              1.4.0-1
                  python-jarowinkler                    -              1.2.0-2
                      python-nrfutil                    -              6.1.6-1
       python-pytest-shell-utilities                    -              1.6.0-1
          python-pytest-skip-markers                    -              1.3.0-1
                    python-rapidfuzz                    -              2.4.2-2
               python-rapidfuzz-capi                    -              1.0.5-3
                       rapidfuzz-cpp                    -              1.1.1-2
                             reapack                    -            1.2.4.1-1
                           ruby-date                    -              3.2.2-1
                       ruby-net-http                    -              0.2.2-1
                       ruby-open-uri                    -              0.2.0-2
                           ruby-time                    -              0.2.0-2
                            ruby-uri                    -             0.11.0-2
                             sonivox                    -          3.6.10.14-1
                                 sws                    -           2.13.1.0-1
                              wldash                    -              0.3.0-2
:: Different overlay package(s) in repository core aarch64
                               linux            5.18.14-1             5.19.1-2
               linux-clockworkpi-a06            5.18.15-1             5.19.1-1
       linux-clockworkpi-a06-headers            5.18.15-1             5.19.1-1
                       linux-headers            5.18.14-1             5.19.1-2
                        linux-khadas            5.18.14-1             5.19.0-2
                linux-khadas-headers            5.18.14-1             5.19.0-2
                           linux-lts            5.15.58-1            5.15.60-1
                   linux-lts-headers            5.15.58-1            5.15.60-1
                        linux-odroid            5.18.12-2             5.19.0-1
                linux-odroid-headers            5.18.12-2             5.19.0-1
                     linux-pinephone            5.18.15-1             5.19.1-1
             linux-pinephone-headers            5.18.15-1             5.19.1-1
                  linux-pinephonepro            5.18.15-1             5.19.1-1
          linux-pinephonepro-headers            5.18.15-1             5.19.1-1
:: Different sync package(s) in repository core aarch64
                          debuginfod              0.187-1              0.187-2
                              dialog     1:1.3_20220526-1     1:1.3_20220728-1
                            elfutils              0.187-1              0.187-2
                              gnutls              3.7.6-1              3.7.7-1
                            iproute2             5.18.0-1             5.19.0-1
                               lemon             3.39.1-1             3.39.2-2
                          libarchive              3.6.1-1              3.6.1-2
                              libelf              0.187-1              0.187-2
                            libevent             2.1.12-1             2.1.12-2
                          libgssglue                0.4-4                0.5-1
                            libtirpc              1.3.2-1              1.3.3-1
                   linux-api-headers             5.17.5-2            5.18.15-1
                                mpfr          4.1.0.p13-2          4.1.0.p13-3
                                nano                6.3-1                6.4-1
                              nettle                3.8-1              3.8.1-1
                           nfs-utils              2.6.1-1              2.6.2-1
                            nfsidmap              2.6.1-1              2.6.2-1
                                nspr               4.34-1             4.34.1-1
                              python             3.10.5-1             3.10.5-2
                        python-tests             3.10.5-1             3.10.5-2
                              sqlite             3.39.1-1             3.39.2-2
                     sqlite-analyzer             3.39.1-1             3.39.2-2
                          sqlite-doc             3.39.1-1             3.39.2-2
                          sqlite-tcl             3.39.1-1             3.39.2-2
                             systemd              251.3-1              251.4-1
                        systemd-libs              251.3-1              251.4-1
                  systemd-resolvconf              251.3-1              251.4-1
                  systemd-sysvcompat              251.3-1              251.4-1
                              tzdata              2022a-1              2022b-1
                          util-linux               2.38-1             2.38.1-1
                     util-linux-libs               2.38-1             2.38.1-1
                      wpa_supplicant             2:2.10-4             2:2.10-5
                             jansson                    -               2.14-2
                       libevent-docs                    -             2.1.12-2
:: Different overlay package(s) in repository extra aarch64
                                kwin           5.25.3-1.1           5.25.4-1.1
            manjaro-settings-manager              0.5.7-1              0.5.7-2
        manjaro-settings-manager-kcm              0.5.7-1              0.5.7-2
                            mesa-git22.2.0_devel.157428.5780ea90c4d9-122.3.0_devel.158055.d08bd9a8d8ba-1
                       plasma-mobile             5.25.3-1             5.25.4-1
                    plasma-mobile-nm             5.25.3-1             5.25.4-1
                         plasma-nano             5.25.3-1             5.25.4-1
                   qqc2-breeze-style             5.25.3-1             5.25.4-1
                     qt5-es2-wayland     5.15.5+kde+r38-2     5.15.5+kde+r38-3
                               snapd             2.56.3-1             2.57.1-1
:: Different sync package(s) in repository extra aarch64
                            apparmor              3.0.4-2              3.0.7-1
                      appstream-glib              0.8.0-1              0.8.1-1
                           bluedevil           1:5.25.3-1           1:5.25.4-1
                               bluez               5.64-2               5.65-2
                          bluez-cups               5.64-2               5.65-2
                       bluez-hid2hci               5.64-2               5.65-2
                          bluez-libs               5.64-2               5.65-2
                       bluez-plugins               5.64-2               5.65-2
                         bluez-utils               5.64-2               5.65-2
                              breeze             5.25.3-1             5.25.4-1
                         breeze-grub             5.25.3-1             5.25.4-1
                          breeze-gtk             5.25.3-1             5.25.4-1
                              brltty                6.5-1                6.5-2
                 brltty-udev-generic                6.5-1                6.5-2
                            calligra             3.2.1-34             3.2.1-35
                            chromium     103.0.5060.134-1      104.0.5112.79-1
                               clang             14.0.6-1             14.0.6-2
                        cups-filters            1.28.15-1            1.28.15-2
                         dbus-broker                 31-1                 32-1
                        dconf-editor             3.38.3-1             3.38.3-2
                             dejagnu              1.6.3-2              1.6.3-3
                     directx-headers            1.602.0-1            1.606.3-1
                            discover             5.25.3-1             5.25.4-1
                                dkms              3.0.5-2              3.0.6-1
                   double-conversion              3.2.0-1              3.2.1-1
                             drkonqi             5.25.3-1             5.25.4-1
                                 ell               0.51-1               0.52-1
                                 eog               42.2-1               42.3-1
                            eog-docs               42.2-1               42.3-1
                            epiphany               42.3-1               42.4-1
                           evolution             3.44.3-1             3.44.4-1
                evolution-bogofilter             3.44.3-1             3.44.4-1
               evolution-data-server             3.44.3-1             3.44.4-1
                       evolution-ews             3.44.3-1             3.44.4-1
              evolution-spamassassin             3.44.3-1             3.44.4-1
                              facile              1.1.4-1              1.1.4-2
                             firefox            103.0.1-1            103.0.2-1
                    firefox-i18n-ach            103.0.1-1            103.0.2-1
                     firefox-i18n-af            103.0.1-1            103.0.2-1
                     firefox-i18n-an            103.0.1-1            103.0.2-1
                     firefox-i18n-ar            103.0.1-1            103.0.2-1
                    firefox-i18n-ast            103.0.1-1            103.0.2-1
                     firefox-i18n-az            103.0.1-1            103.0.2-1
                     firefox-i18n-be            103.0.1-1            103.0.2-1
                     firefox-i18n-bg            103.0.1-1            103.0.2-1
                     firefox-i18n-bn            103.0.1-1            103.0.2-1
                     firefox-i18n-br            103.0.1-1            103.0.2-1
                     firefox-i18n-bs            103.0.1-1            103.0.2-1
                     firefox-i18n-ca            103.0.1-1            103.0.2-1
            firefox-i18n-ca-valencia            103.0.1-1            103.0.2-1
                    firefox-i18n-cak            103.0.1-1            103.0.2-1
                     firefox-i18n-cs            103.0.1-1            103.0.2-1
                     firefox-i18n-cy            103.0.1-1            103.0.2-1
                     firefox-i18n-da            103.0.1-1            103.0.2-1
                     firefox-i18n-de            103.0.1-1            103.0.2-1
                    firefox-i18n-dsb            103.0.1-1            103.0.2-1
                     firefox-i18n-el            103.0.1-1            103.0.2-1
                  firefox-i18n-en-ca            103.0.1-1            103.0.2-1
                  firefox-i18n-en-gb            103.0.1-1            103.0.2-1
                  firefox-i18n-en-us            103.0.1-1            103.0.2-1
                     firefox-i18n-eo            103.0.1-1            103.0.2-1
                  firefox-i18n-es-ar            103.0.1-1            103.0.2-1
                  firefox-i18n-es-cl            103.0.1-1            103.0.2-1
                  firefox-i18n-es-es            103.0.1-1            103.0.2-1
                  firefox-i18n-es-mx            103.0.1-1            103.0.2-1
                     firefox-i18n-et            103.0.1-1            103.0.2-1
                     firefox-i18n-eu            103.0.1-1            103.0.2-1
                     firefox-i18n-fa            103.0.1-1            103.0.2-1
                     firefox-i18n-ff            103.0.1-1            103.0.2-1
                     firefox-i18n-fi            103.0.1-1            103.0.2-1
                     firefox-i18n-fr            103.0.1-1            103.0.2-1
                  firefox-i18n-fy-nl            103.0.1-1            103.0.2-1
                  firefox-i18n-ga-ie            103.0.1-1            103.0.2-1
                     firefox-i18n-gd            103.0.1-1            103.0.2-1
                     firefox-i18n-gl            103.0.1-1            103.0.2-1
                     firefox-i18n-gn            103.0.1-1            103.0.2-1
                  firefox-i18n-gu-in            103.0.1-1            103.0.2-1
                     firefox-i18n-he            103.0.1-1            103.0.2-1
                  firefox-i18n-hi-in            103.0.1-1            103.0.2-1
                     firefox-i18n-hr            103.0.1-1            103.0.2-1
                    firefox-i18n-hsb            103.0.1-1            103.0.2-1
                     firefox-i18n-hu            103.0.1-1            103.0.2-1
                  firefox-i18n-hy-am            103.0.1-1            103.0.2-1
                     firefox-i18n-ia            103.0.1-1            103.0.2-1
                     firefox-i18n-id            103.0.1-1            103.0.2-1
                     firefox-i18n-is            103.0.1-1            103.0.2-1
                     firefox-i18n-it            103.0.1-1            103.0.2-1
                     firefox-i18n-ja            103.0.1-1            103.0.2-1
                     firefox-i18n-ka            103.0.1-1            103.0.2-1
                    firefox-i18n-kab            103.0.1-1            103.0.2-1
                     firefox-i18n-kk            103.0.1-1            103.0.2-1
                     firefox-i18n-km            103.0.1-1            103.0.2-1
                     firefox-i18n-kn            103.0.1-1            103.0.2-1
                     firefox-i18n-ko            103.0.1-1            103.0.2-1
                    firefox-i18n-lij            103.0.1-1            103.0.2-1
                     firefox-i18n-lt            103.0.1-1            103.0.2-1
                     firefox-i18n-lv            103.0.1-1            103.0.2-1
                     firefox-i18n-mk            103.0.1-1            103.0.2-1
                     firefox-i18n-mr            103.0.1-1            103.0.2-1
                     firefox-i18n-ms            103.0.1-1            103.0.2-1
                     firefox-i18n-my            103.0.1-1            103.0.2-1
                  firefox-i18n-nb-no            103.0.1-1            103.0.2-1
                  firefox-i18n-ne-np            103.0.1-1            103.0.2-1
                     firefox-i18n-nl            103.0.1-1            103.0.2-1
                  firefox-i18n-nn-no            103.0.1-1            103.0.2-1
                     firefox-i18n-oc            103.0.1-1            103.0.2-1
                  firefox-i18n-pa-in            103.0.1-1            103.0.2-1
                     firefox-i18n-pl            103.0.1-1            103.0.2-1
                  firefox-i18n-pt-br            103.0.1-1            103.0.2-1
                  firefox-i18n-pt-pt            103.0.1-1            103.0.2-1
                     firefox-i18n-rm            103.0.1-1            103.0.2-1
                     firefox-i18n-ro            103.0.1-1            103.0.2-1
                     firefox-i18n-ru            103.0.1-1            103.0.2-1
                    firefox-i18n-sco            103.0.1-1            103.0.2-1
                     firefox-i18n-si            103.0.1-1            103.0.2-1
                     firefox-i18n-sk            103.0.1-1            103.0.2-1
                     firefox-i18n-sl            103.0.1-1            103.0.2-1
                    firefox-i18n-son            103.0.1-1            103.0.2-1
                     firefox-i18n-sq            103.0.1-1            103.0.2-1
                     firefox-i18n-sr            103.0.1-1            103.0.2-1
                  firefox-i18n-sv-se            103.0.1-1            103.0.2-1
                    firefox-i18n-szl            103.0.1-1            103.0.2-1
                     firefox-i18n-ta            103.0.1-1            103.0.2-1
                     firefox-i18n-te            103.0.1-1            103.0.2-1
                     firefox-i18n-th            103.0.1-1            103.0.2-1
                     firefox-i18n-tl            103.0.1-1            103.0.2-1
                     firefox-i18n-tr            103.0.1-1            103.0.2-1
                    firefox-i18n-trs            103.0.1-1            103.0.2-1
                     firefox-i18n-uk            103.0.1-1            103.0.2-1
                     firefox-i18n-ur            103.0.1-1            103.0.2-1
                     firefox-i18n-uz            103.0.1-1            103.0.2-1
                     firefox-i18n-vi            103.0.1-1            103.0.2-1
                     firefox-i18n-xh            103.0.1-1            103.0.2-1
                  firefox-i18n-zh-cn            103.0.1-1            103.0.2-1
                  firefox-i18n-zh-tw            103.0.1-1            103.0.2-1
                                gcab                1.4-2                1.5-1
                                 gcr             3.41.1-1             3.41.1-2
                            gcr-docs             3.41.1-1             3.41.1-2
                         gdk-pixbuf2             2.42.8-1             2.42.9-1
                    gdk-pixbuf2-docs             2.42.8-1             2.42.9-1
                        geocode-glib             3.26.3-1             3.26.4-1
                      geoip-database           20220621-1           20220802-1
                geoip-database-extra           20220621-1           20220802-1
                                 git             2.37.1-1             2.37.2-1
                                 gjs           2:1.72.1-1           2:1.72.2-1
                               glade             3.38.2-3             3.40.0-1
                     glib-networking           1:2.72.1-1           1:2.72.2-1
                             glslang            11.10.0-1            11.11.0-1
                         gnome-chess               42.0-1               42.1-1
                       gnome-desktop             1:42.3-1             1:42.4-1
                     gnome-desktop-4             1:42.3-1             1:42.4-1
                gnome-desktop-common             1:42.3-1             1:42.4-1
                  gnome-info-collect              1.0.3-1              1.0.5-1
                gnome-remote-desktop               42.3-1               42.4-1
                         gnome-shell           1:42.3.1-1             1:42.4-1
                      gnome-software               42.3-1               42.4-1
    gnome-software-packagekit-plugin               42.3-1               42.4-1
                               gnote               42.0-1               42.1-1
                             gnu-efi             3.0.14-4             3.0.15-1
                            graphviz              5.0.0-1              5.0.0-2
                                 gsm             1.0.20-1             1.0.22-1
                                gvim           9.0.0000-1           9.0.0135-1
                            harfbuzz              5.0.1-1              5.1.0-1
                        harfbuzz-icu              5.0.1-1              5.1.0-1
                 ibus-typing-booster             2.17.1-1             2.18.9-1
                            inkscape              1.2.1-1              1.2.1-2
                       jdk11-openjdk         11.0.16.u8-2       11.0.16.1.u1-2
                       jre11-openjdk         11.0.16.u8-2       11.0.16.1.u1-2
              jre11-openjdk-headless         11.0.16.u8-2       11.0.16.1.u1-2
                   kactivitymanagerd             5.25.3-1             5.25.4-1
                       kde-cli-tools             5.25.3-1             5.25.4-1
                      kde-gtk-config             5.25.3-1             5.25.4-1
                         kdecoration             5.25.3-1             5.25.4-1
                    kdeplasma-addons             5.25.3-1             5.25.4-1
                             kgamma5             5.25.3-1             5.25.4-1
                            khotkeys             5.25.3-1             5.25.4-1
                         kinfocenter             5.25.3-1             5.25.4-1
                              kismet         2022_02_R1-3         2022_08_R1-1
                          kitinerary            22.04.3-2            22.04.3-3
                           kmenuedit             5.25.3-1             5.25.4-1
                             kscreen             5.25.3-1             5.25.4-1
                       kscreenlocker             5.25.3-1             5.25.4-1
                         ksshaskpass             5.25.3-1             5.25.4-1
                        ksystemstats             5.25.3-1             5.25.4-1
                         kwallet-pam             5.25.3-1             5.25.4-1
                kwayland-integration             5.25.3-1             5.25.4-1
                                kwin             5.25.3-1             5.25.4-1
                             kwrited             5.25.3-1             5.25.4-1
                            lablgtk2            2.18.12-1            2.18.12-2
                      layer-shell-qt             5.25.3-1             5.25.4-1
                                 ldb            2:2.5.2-1            2:2.5.2-2
                            lib2geom                1.2-1                1.2-2
                          libadwaita            1:1.1.3-1            1:1.1.4-1
                    libadwaita-demos            1:1.1.3-1            1:1.1.4-1
                     libadwaita-docs            1:1.1.3-1            1:1.1.4-1
                           libbluray              1.3.1-1              1.3.2-1
                             libcmis             0.5.2-10             0.5.2-11
                      libdmapsharing             2.9.39-3             2.9.41-1
                            libevdev             1.12.1-1             1.13.0-1
                            libglvnd              1.4.0-2              1.4.0-3
                          libkscreen             5.25.3-1             5.25.4-1
                        libksysguard             5.25.3-1             5.25.4-1
                      liblightdm-qt5           1:1.30.0-4           1:1.32.0-1
                       libmalcontent             0.10.4-1             0.10.5-1
                   libreoffice-fresh              7.3.4-2              7.3.5-3
                libreoffice-fresh-af              7.3.4-1              7.3.5-1
                libreoffice-fresh-am              7.3.4-1              7.3.5-1
                libreoffice-fresh-ar              7.3.4-1              7.3.5-1
                libreoffice-fresh-as              7.3.4-1              7.3.5-1
               libreoffice-fresh-ast              7.3.4-1              7.3.5-1
                libreoffice-fresh-be              7.3.4-1              7.3.5-1
                libreoffice-fresh-bg              7.3.4-1              7.3.5-1
                libreoffice-fresh-bn              7.3.4-1              7.3.5-1
             libreoffice-fresh-bn-in              7.3.4-1              7.3.5-1
                libreoffice-fresh-bo              7.3.4-1              7.3.5-1
                libreoffice-fresh-br              7.3.4-1              7.3.5-1
               libreoffice-fresh-brx              7.3.4-1              7.3.5-1
                libreoffice-fresh-bs              7.3.4-1              7.3.5-1
                libreoffice-fresh-ca              7.3.4-1              7.3.5-1
       libreoffice-fresh-ca-valencia              7.3.4-1              7.3.5-1
               libreoffice-fresh-ckb              7.3.4-1              7.3.5-1
                libreoffice-fresh-cs              7.3.4-1              7.3.5-1
                libreoffice-fresh-cy              7.3.4-1              7.3.5-1
                libreoffice-fresh-da              7.3.4-1              7.3.5-1
                libreoffice-fresh-de              7.3.4-1              7.3.5-1
               libreoffice-fresh-dgo              7.3.4-1              7.3.5-1
               libreoffice-fresh-dsb              7.3.4-1              7.3.5-1
                libreoffice-fresh-dz              7.3.4-1              7.3.5-1
                libreoffice-fresh-el              7.3.4-1              7.3.5-1
             libreoffice-fresh-en-gb              7.3.4-1              7.3.5-1
             libreoffice-fresh-en-za              7.3.4-1              7.3.5-1
                libreoffice-fresh-eo              7.3.4-1              7.3.5-1
                libreoffice-fresh-es              7.3.4-1              7.3.5-1
                libreoffice-fresh-et              7.3.4-1              7.3.5-1
                libreoffice-fresh-eu              7.3.4-1              7.3.5-1
                libreoffice-fresh-fa              7.3.4-1              7.3.5-1
                libreoffice-fresh-fi              7.3.4-1              7.3.5-1
                libreoffice-fresh-fr              7.3.4-1              7.3.5-1
               libreoffice-fresh-fur              7.3.4-1              7.3.5-1
                libreoffice-fresh-fy              7.3.4-1              7.3.5-1
                libreoffice-fresh-ga              7.3.4-1              7.3.5-1
                libreoffice-fresh-gd              7.3.4-1              7.3.5-1
                libreoffice-fresh-gl              7.3.4-1              7.3.5-1
                libreoffice-fresh-gu              7.3.4-1              7.3.5-1
               libreoffice-fresh-gug              7.3.4-1              7.3.5-1
                libreoffice-fresh-he              7.3.4-1              7.3.5-1
                libreoffice-fresh-hi              7.3.4-1              7.3.5-1
                libreoffice-fresh-hr              7.3.4-1              7.3.5-1
               libreoffice-fresh-hsb              7.3.4-1              7.3.5-1
                libreoffice-fresh-hu              7.3.4-1              7.3.5-1
                libreoffice-fresh-id              7.3.4-1              7.3.5-1
                libreoffice-fresh-is              7.3.4-1              7.3.5-1
                libreoffice-fresh-it              7.3.4-1              7.3.5-1
                libreoffice-fresh-ja              7.3.4-1              7.3.5-1
                libreoffice-fresh-ka              7.3.4-1              7.3.5-1
               libreoffice-fresh-kab              7.3.4-1              7.3.5-1
                libreoffice-fresh-kk              7.3.4-1              7.3.5-1
                libreoffice-fresh-km              7.3.4-1              7.3.5-1
          libreoffice-fresh-kmr-latn              7.3.4-1              7.3.5-1
                libreoffice-fresh-kn              7.3.4-1              7.3.5-1
                libreoffice-fresh-ko              7.3.4-1              7.3.5-1
               libreoffice-fresh-kok              7.3.4-1              7.3.5-1
                libreoffice-fresh-ks              7.3.4-1              7.3.5-1
                libreoffice-fresh-lb              7.3.4-1              7.3.5-1
                libreoffice-fresh-lo              7.3.4-1              7.3.5-1
                libreoffice-fresh-lt              7.3.4-1              7.3.5-1
                libreoffice-fresh-lv              7.3.4-1              7.3.5-1
               libreoffice-fresh-mai              7.3.4-1              7.3.5-1
                libreoffice-fresh-mk              7.3.4-1              7.3.5-1
                libreoffice-fresh-ml              7.3.4-1              7.3.5-1
                libreoffice-fresh-mn              7.3.4-1              7.3.5-1
               libreoffice-fresh-mni              7.3.4-1              7.3.5-1
                libreoffice-fresh-mr              7.3.4-1              7.3.5-1
                libreoffice-fresh-my              7.3.4-1              7.3.5-1
                libreoffice-fresh-nb              7.3.4-1              7.3.5-1
                libreoffice-fresh-ne              7.3.4-1              7.3.5-1
                libreoffice-fresh-nl              7.3.4-1              7.3.5-1
                libreoffice-fresh-nn              7.3.4-1              7.3.5-1
                libreoffice-fresh-nr              7.3.4-1              7.3.5-1
               libreoffice-fresh-nso              7.3.4-1              7.3.5-1
                libreoffice-fresh-oc              7.3.4-1              7.3.5-1
                libreoffice-fresh-om              7.3.4-1              7.3.5-1
                libreoffice-fresh-or              7.3.4-1              7.3.5-1
             libreoffice-fresh-pa-in              7.3.4-1              7.3.5-1
                libreoffice-fresh-pl              7.3.4-1              7.3.5-1
                libreoffice-fresh-pt              7.3.4-1              7.3.5-1
             libreoffice-fresh-pt-br              7.3.4-1              7.3.5-1
                libreoffice-fresh-ro              7.3.4-1              7.3.5-1
                libreoffice-fresh-ru              7.3.4-1              7.3.5-1
                libreoffice-fresh-rw              7.3.4-1              7.3.5-1
             libreoffice-fresh-sa-in              7.3.4-1              7.3.5-1
               libreoffice-fresh-sat              7.3.4-1              7.3.5-1
                libreoffice-fresh-sd              7.3.4-1              7.3.5-1
               libreoffice-fresh-sdk              7.3.4-2              7.3.5-3
                libreoffice-fresh-si              7.3.4-1              7.3.5-1
               libreoffice-fresh-sid              7.3.4-1              7.3.5-1
                libreoffice-fresh-sk              7.3.4-1              7.3.5-1
                libreoffice-fresh-sl              7.3.4-1              7.3.5-1
                libreoffice-fresh-sq              7.3.4-1              7.3.5-1
                libreoffice-fresh-sr              7.3.4-1              7.3.5-1
           libreoffice-fresh-sr-latn              7.3.4-1              7.3.5-1
                libreoffice-fresh-ss              7.3.4-1              7.3.5-1
                libreoffice-fresh-st              7.3.4-1              7.3.5-1
                libreoffice-fresh-sv              7.3.4-1              7.3.5-1
             libreoffice-fresh-sw-tz              7.3.4-1              7.3.5-1
               libreoffice-fresh-szl              7.3.4-1              7.3.5-1
                libreoffice-fresh-ta              7.3.4-1              7.3.5-1
                libreoffice-fresh-te              7.3.4-1              7.3.5-1
                libreoffice-fresh-tg              7.3.4-1              7.3.5-1
                libreoffice-fresh-th              7.3.4-1              7.3.5-1
                libreoffice-fresh-tn              7.3.4-1              7.3.5-1
                libreoffice-fresh-tr              7.3.4-1              7.3.5-1
                libreoffice-fresh-ts              7.3.4-1              7.3.5-1
                libreoffice-fresh-tt              7.3.4-1              7.3.5-1
                libreoffice-fresh-ug              7.3.4-1              7.3.5-1
                libreoffice-fresh-uk              7.3.4-1              7.3.5-1
                libreoffice-fresh-uz              7.3.4-1              7.3.5-1
                libreoffice-fresh-ve              7.3.4-1              7.3.5-1
               libreoffice-fresh-vec              7.3.4-1              7.3.5-1
                libreoffice-fresh-vi              7.3.4-1              7.3.5-1
                libreoffice-fresh-xh              7.3.4-1              7.3.5-1
             libreoffice-fresh-zh-cn              7.3.4-1              7.3.5-1
             libreoffice-fresh-zh-tw              7.3.4-1              7.3.5-1
                libreoffice-fresh-zu              7.3.4-1              7.3.5-1
                   libreoffice-still              7.2.7-3              7.2.7-5
               libreoffice-still-sdk              7.2.7-3              7.2.7-5
                             librest              0.9.0-1              0.9.1-1
                        librest-docs              0.9.0-1              0.9.1-1
                  libsysprof-capture             3.44.0-1             3.44.0-2
                             libupnp            1.14.12-3            1.14.13-1
                   libva-mesa-driver             22.1.4-1             22.1.6-1
                            libwacom              2.3.0-1              2.4.0-1
                             libwebp              1.2.3-1              1.2.4-1
                              libwpe             1.12.0-2             1.12.2-1
                             libxcvt              0.1.1-1              0.1.2-1
                             liferea             1.13.8-1             1.13.9-1
                             lightdm           1:1.30.0-4           1:1.32.0-1
                            lighttpd             1.4.65-1             1.4.66-1
                                llvm             14.0.6-2             14.0.6-3
                           llvm-libs             14.0.6-2             14.0.6-3
                              lprint              1.1.0-1              1.1.0-2
                                 lua              5.4.4-1              5.4.4-2
                                meld             3.21.2-1             3.21.3-2
                                mesa             22.1.4-1             22.1.6-1
                          mesa-vdpau             22.1.4-1             22.1.6-1
                               meson             0.63.0-1             0.63.1-1
                               milou             5.25.3-1             5.25.4-1
                              mpg123             1.30.1-1             1.30.2-1
                               msmtp             1.8.20-1             1.8.22-1
                           msmtp-mta             1.8.20-1             1.8.22-1
                                mutt              2.2.6-1              2.2.7-1
                              mutter               42.3-1               42.4-1
                         mutter-docs               42.3-1               42.4-1
                               ocaml             4.13.1-3             4.14.0-1
               ocaml-bigarray-compat              1.0.0-2              1.0.0-3
                 ocaml-compiler-libs             4.13.1-3             4.14.0-1
                        ocaml-ctypes             0.20.0-2             0.20.1-1
                      ocaml-integers              0.5.1-2              0.7.0-1
                        ocaml-result                1.5-6                1.5-7
                         ocaml-topkg              1.0.4-2              1.0.5-1
                         opencl-mesa             22.1.4-1             22.1.6-1
                        opencore-amr              0.1.5-5              0.1.6-1
                       openjdk11-src         11.0.16.u8-2       11.0.16.1.u1-2
                              ostree             2022.5-1             2022.5-2
                              oxygen             5.25.3-1             5.25.4-1
                       oxygen-sounds             5.25.3-1             5.25.4-1
                               pango           1:1.50.8-1           1:1.50.9-1
                          pango-docs           1:1.50.8-1           1:1.50.9-1
                    perl-alien-build               2.50-1               2.51-1
                                 php              8.1.8-1              8.1.9-1
                          php-apache              8.1.8-1              8.1.9-1
                             php-cgi              8.1.8-1              8.1.9-1
                           php-dblib              8.1.8-1              8.1.9-1
                           php-embed              8.1.8-1              8.1.9-1
                         php-enchant              8.1.8-1              8.1.9-1
                             php-fpm              8.1.8-1              8.1.9-1
                              php-gd              8.1.8-1              8.1.9-1
                            php-imap              8.1.8-1              8.1.9-1
                            php-intl              8.1.8-1              8.1.9-1
                            php-odbc              8.1.8-1              8.1.9-1
                           php-pgsql              8.1.8-1              8.1.9-1
                          php-phpdbg              8.1.8-1              8.1.9-1
                          php-pspell              8.1.8-1              8.1.9-1
                            php-snmp              8.1.8-1              8.1.9-1
                          php-sodium              8.1.8-1              8.1.9-1
                          php-sqlite              8.1.8-1              8.1.9-1
                            php-tidy              8.1.8-1              8.1.9-1
                             php-xsl              8.1.8-1              8.1.9-1
                            pkgstats              3.2.2-1              3.2.4-1
          plasma-browser-integration             5.25.3-1             5.25.4-1
                      plasma-desktop             5.25.3-1             5.25.4-1
                        plasma-disks             5.25.3-1             5.25.4-1
                     plasma-firewall             5.25.3-1             5.25.4-1
                  plasma-integration             5.25.3-1             5.25.4-1
                           plasma-nm             5.25.3-1             5.25.4-1
                           plasma-pa             5.25.3-1             5.25.4-1
                          plasma-sdk             5.25.3-1             5.25.4-1
                plasma-systemmonitor             5.25.3-1             5.25.4-1
                  plasma-thunderbolt             5.25.3-1             5.25.4-1
                        plasma-vault             5.25.3-1             5.25.4-1
              plasma-wayland-session           5.25.3.1-2             5.25.4-1
                    plasma-workspace           5.25.3.1-2             5.25.4-1
         plasma-workspace-wallpapers             5.25.3-1             5.25.4-1
                    polkit-kde-agent             5.25.3-1             5.25.4-1
                             poppler            22.07.0-1            22.08.0-1
                        poppler-glib            22.07.0-1            22.08.0-1
                         poppler-qt5            22.07.0-1            22.08.0-1
                         poppler-qt6            22.07.0-1            22.08.0-1
                          powerdevil             5.25.3-1             5.25.4-1
        prometheus-blackbox-exporter             0.21.1-1             0.22.0-1
                      python-chardet              4.0.0-5              5.0.0-1
                     python-dbusmock             0.28.1-1             0.28.4-1
                          python-pip             22.2.1-1             22.2.2-1
                     python-requests             2.27.1-1             2.28.1-1
            python-trove-classifiers          2022.7.22-1           2022.8.7-1
                      python-urllib3             1.26.9-1            1.26.11-1
                  python-urllib3-doc             1.26.9-1            1.26.11-1
                               rsync              3.2.4-1          3.2.5pre2-1
                                rust           1:1.62.1-1           1:1.63.0-1
                            rust-src           1:1.62.1-1           1:1.63.0-1
                               samba             4.16.4-1             4.16.4-3
                               scons              4.3.0-3              4.4.0-1
                            sddm-kcm             5.25.3-1             5.25.4-1
                          sdl2_image              2.6.0-2              2.6.1-1
                           smbclient             4.16.4-1             4.16.4-3
                             sysprof             3.44.0-1             3.44.0-2
                      systemsettings             5.25.3-1             5.25.4-1
                                tali               40.7-1               40.8-1
                              tevent           1:0.12.1-1           1:0.13.0-1
                         thunderbird            91.11.0-1            91.12.0-1
                 thunderbird-i18n-af            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ar            91.11.0-1            91.12.0-1
                thunderbird-i18n-ast            91.11.0-1            91.12.0-1
                 thunderbird-i18n-be            91.11.0-1            91.12.0-1
                 thunderbird-i18n-bg            91.11.0-1            91.12.0-1
                 thunderbird-i18n-br            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ca            91.11.0-1            91.12.0-1
                thunderbird-i18n-cak            91.11.0-1            91.12.0-1
                 thunderbird-i18n-cs            91.11.0-1            91.12.0-1
                 thunderbird-i18n-cy            91.11.0-1            91.12.0-1
                 thunderbird-i18n-da            91.11.0-1            91.12.0-1
                 thunderbird-i18n-de            91.11.0-1            91.12.0-1
                thunderbird-i18n-dsb            91.11.0-1            91.12.0-1
                 thunderbird-i18n-el            91.11.0-1            91.12.0-1
              thunderbird-i18n-en-gb            91.11.0-1            91.12.0-1
              thunderbird-i18n-en-us            91.11.0-1            91.12.0-1
              thunderbird-i18n-es-ar            91.11.0-1            91.12.0-1
              thunderbird-i18n-es-es            91.11.0-1            91.12.0-1
                 thunderbird-i18n-et            91.11.0-1            91.12.0-1
                 thunderbird-i18n-eu            91.11.0-1            91.12.0-1
                 thunderbird-i18n-fi            91.11.0-1            91.12.0-1
                 thunderbird-i18n-fr            91.11.0-1            91.12.0-1
              thunderbird-i18n-fy-nl            91.11.0-1            91.12.0-1
              thunderbird-i18n-ga-ie            91.11.0-1            91.12.0-1
                 thunderbird-i18n-gd            91.11.0-1            91.12.0-1
                 thunderbird-i18n-gl            91.11.0-1            91.12.0-1
                 thunderbird-i18n-he            91.11.0-1            91.12.0-1
                 thunderbird-i18n-hr            91.11.0-1            91.12.0-1
                thunderbird-i18n-hsb            91.11.0-1            91.12.0-1
                 thunderbird-i18n-hu            91.11.0-1            91.12.0-1
              thunderbird-i18n-hy-am            91.11.0-1            91.12.0-1
                 thunderbird-i18n-id            91.11.0-1            91.12.0-1
                 thunderbird-i18n-is            91.11.0-1            91.12.0-1
                 thunderbird-i18n-it            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ja            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ka            91.11.0-1            91.12.0-1
                thunderbird-i18n-kab            91.11.0-1            91.12.0-1
                 thunderbird-i18n-kk            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ko            91.11.0-1            91.12.0-1
                 thunderbird-i18n-lt            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ms            91.11.0-1            91.12.0-1
              thunderbird-i18n-nb-no            91.11.0-1            91.12.0-1
                 thunderbird-i18n-nl            91.11.0-1            91.12.0-1
              thunderbird-i18n-nn-no            91.11.0-1            91.12.0-1
              thunderbird-i18n-pa-in            91.11.0-1            91.12.0-1
                 thunderbird-i18n-pl            91.11.0-1            91.12.0-1
              thunderbird-i18n-pt-br            91.11.0-1            91.12.0-1
              thunderbird-i18n-pt-pt            91.11.0-1            91.12.0-1
                 thunderbird-i18n-rm            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ro            91.11.0-1            91.12.0-1
                 thunderbird-i18n-ru            91.11.0-1            91.12.0-1
                 thunderbird-i18n-sk            91.11.0-1            91.12.0-1
                 thunderbird-i18n-sl            91.11.0-1            91.12.0-1
                 thunderbird-i18n-sq            91.11.0-1            91.12.0-1
                 thunderbird-i18n-sr            91.11.0-1            91.12.0-1
              thunderbird-i18n-sv-se            91.11.0-1            91.12.0-1
                 thunderbird-i18n-th            91.11.0-1            91.12.0-1
                 thunderbird-i18n-tr            91.11.0-1            91.12.0-1
                 thunderbird-i18n-uk            91.11.0-1            91.12.0-1
                 thunderbird-i18n-uz            91.11.0-1            91.12.0-1
                 thunderbird-i18n-vi            91.11.0-1            91.12.0-1
              thunderbird-i18n-zh-cn            91.11.0-1            91.12.0-1
              thunderbird-i18n-zh-tw            91.11.0-1            91.12.0-1
                             tomcat8             8.5.81-1             8.5.82-1
                            tracker3              3.3.2-1              3.3.3-1
                       tracker3-docs              3.3.2-1              3.3.3-1
                     tracker3-miners              3.3.1-1              3.3.1-2
                                tree              2.0.2-1              2.0.2-2
                             tumbler             4.16.0-3             4.16.1-1
                               unzip               6.0-18               6.0-19
                             varnish              7.1.0-1              7.1.1-1
                         vim-runtime           9.0.0000-1           9.0.0135-1
                     vulkan-broadcom             22.1.4-1             22.1.6-1
                  vulkan-mesa-layers             22.1.4-1             22.1.6-1
                     vulkan-panfrost             22.1.4-1             22.1.6-1
                       vulkan-radeon             22.1.4-1             22.1.6-1
                       vulkan-swrast             22.1.4-1             22.1.6-1
                   wayland-protocols               1.25-1               1.26-1
                          webkit2gtk             2.36.5-1             2.36.6-1
                      webkit2gtk-4.1             2.36.5-1             2.36.6-1
                      webkit2gtk-5.0             2.36.5-1             2.36.6-1
                         wireplumber             0.4.11-2             0.4.11-4
                    wireplumber-docs             0.4.11-2             0.4.11-4
                      wpebackend-fdo             1.12.0-2             1.12.1-1
                           wpewebkit             2.36.5-1             2.36.6-1
                  xdg-desktop-portal             1.14.5-1             1.15.0-1
              xdg-desktop-portal-kde             5.25.3-1             5.25.4-1
                       xdg-user-dirs               0.17-3               0.18-1
                 xfce4-screenshooter             1.9.10-2             1.9.11-1
                    xkeyboard-config               2.36-2               2.36-3
                           xorgproto             2022.1-1             2022.2-1
                       librest-demos                    -              0.9.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
                             akonadi22.04.3.r12797.g5e6620486-122.04.3.r12799.g00999d2ce-1
                    akonadi-calendar22.04.3.r2148.g6f8be46-122.04.3.r2149.gb4abd2d-1
              akonadi-calendar-tools22.04.3.r959.g9e027c8-122.04.3.r960.g7c23324-1
                    akonadi-contacts22.04.3.r3233.gaa2fe31b-122.04.3.r3234.gc4518d3e-1
               akonadi-import-wizard22.04.3.r1841.g7bc967b-122.04.3.r1843.gceab58e-1
                      akonadi-search22.04.3.r1253.gbf732e7-122.04.3.r1255.gf0ff77d-1
                      akonadiconsole22.04.3.r1602.gee6df9c-122.04.3.r1603.g1a81412-1
                           akregator22.04.3.r6456.ge98d960c-122.04.3.r6457.g517e080e-1
                           alligator 22.06.r26.g1dcaced-1 22.06.r32.g34aeada-1
                           angelfish 22.06.r24.g48cd9a7-1 22.06.r36.gc7a662a-1
                                 ark22.04.3.r4823.g55f774bd-122.04.3.r4830.g29251d84-1
                          artikulate22.04.3.r1425.g1066b70-122.04.3.r1428.g898a7e8-1
                              attica5.96.0.r878.g9e2a404-15.96.0.r879.g1544fae-1
                         audiocd-kio22.04.3.r1101.g059a3f8-122.04.3.r1106.g7a176f7-1
                           audiotube 22.06.r19.gef59e9d-1 22.06.r23.gb4c6749-1
                               baloo5.96.0.r3059.gea7d6992-15.96.0.r3060.gfaed70bc-1
                       baloo-widgets22.04.3.r764.ge7669e5-122.04.3.r765.gd34e9d9-1
                             blinken22.04.3.r676.gc226950-122.04.3.r678.g98892b1-1
                           bluedevil1:5.25.3.r2425.g69532493-11:5.25.4.r2429.g77fc223b-1
                            bluez-qt5.96.0.r715.gc4f457a-15.96.0.r717.ge5c36f0-1
                              bomber22.04.3.r571.gb7c2acf-122.04.3.r572.g2a54bd9-1
                                bovo22.04.3.r782.ga336e2a-122.04.3.r783.gf19bf48-1
                              breeze5.25.3.r2434.g737ef761-15.25.4.r2439.g45745976-1
                         breeze-grub5.25.3.r11.g63136a9-15.25.4.r11.g63136a9-1
                          breeze-gtk5.25.3.r485.gf5c1363-15.25.4.r485.gf5c1363-1
                        breeze-icons5.96.0.r1909.gacc75ff7-15.96.0.r1911.g788ff4e0-1
                                buho  2.1.2.r6.g3fe40dc-1  2.1.2.r9.gdfd2429-1
                     calendarsupport22.04.3.r719.g0d93a55-122.04.3.r723.g9d51240-1
                           calindori  22.06.r9.g1b8b909-1 22.06.r16.ge791c0c-1
                         cask-server        r2.ge1c218e-1        r3.ge442424-1
                            cervisia22.04.3.r1689.ge08a02a-122.04.3.r1690.g3a429e2-1
                            discover5.25.3.r8769.g268f98e5-15.25.4.r8775.gd3def74e-1
                              disman5.25.0.r1844.g9f33299-15.25.4.r1844.g9f33299-1
                             dolphin22.04.3.r7054.gd7ca76799-122.04.3.r7059.g9dbe48137-1
                     dolphin-plugins22.04.3.r668.g0db9289-122.04.3.r675.g8ee2371-1
                              dragon22.04.3.r1048.ge20da44-122.04.3.r1058.gf0999a4-1
                             drkonqi5.25.3.r811.gf58645f1-15.25.4.r813.g489dac6b-1
                               elisa22.04.3.r3002.gdd57c124-122.04.3.r3004.g7670077b-1
                          elisa-qtmm22.04.3.r3002.gdd57c124-122.04.3.r3004.g7670077b-1
                          eventviews22.04.3.r862.g17c0b0e-122.04.3.r863.g340af1a-1
                 extra-cmake-modules5.96.0.r3506.gce726d38-15.96.0.r3510.ga7e2d05a-1
                        ffmpegthumbs22.04.3.r227.g8f27039-122.04.3.r233.g9e0e0c0-1
                           filelight22.04.3.r1157.gdc184ef-122.04.3.r1165.g68eb68f-1
                frameworkintegration5.96.0.r647.g817408a-15.96.0.r650.gaf506e7-1
                           granatier22.04.3.r986.gb00b485-122.04.3.r987.g5f0c5c2-1
                     grantlee-editor22.04.3.r831.g1a1dd3a-122.04.3.r832.g2a1698e-1
                            gwenview22.04.3.r6887.gb948a072-122.04.3.r6889.ge9655a87-1
                     incidenceeditor22.04.3.r912.gd7141d5-122.04.3.r913.g7c3c44e-1
                            index-fm 2.1.2.r36.g5132862-1 2.1.2.r41.gc28d301-1
                           itinerary22.04.3.r1970.g6f1f8b2-122.04.3.r1983.gee1af6a-1
                                 juk22.04.3.r3168.gb8f64903-122.04.3.r3175.gce43c719-1
                                 k3b1:22.04.3.r6808.g27ac23378-11:22.04.3.r6811.g02290a4b9-1
               kaccounts-integration22.04.3.r1268.gfd1d35c-122.04.3.r1269.g217353a-1
                         kactivities5.96.0.r1404.gfeda83d6-15.96.0.r1405.g7de15f9d-1
                   kactivities-stats5.96.0.r412.gd64e767-15.96.0.r413.g76ef2ca-1
                   kactivitymanagerd5.25.3.r1413.gc562bf6-15.25.4.r1417.g12b9815-1
                        kaddressbook22.04.3.r6225.g7f5e4c61-122.04.3.r6228.g3361e056-1
                             kajongg22.04.3.r4347.g86f0115c-122.04.3.r4348.g1c5a3ffa-1
                              kalarm22.04.3.r7972.g5ac7ad15-122.04.3.r7981.g01f64924-1
                            kalgebra22.04.3.r2070.g0c74265-122.04.3.r2073.g91da468-1
                                kalk 22.06.r13.ga060835-1 22.06.r14.g88ed070-1
                             kalzium22.04.3.r4373.gfc36b715-122.04.3.r4375.g69c3bd06-1
                              kamera22.04.3.r728.gf685528-122.04.3.r732.g1c3d3d4-1
                              kamoso22.04.3.r1470.gc7d4dd4-122.04.3.r1472.g064f2cd-1
                            kanagram22.04.3.r1319.g9180818-122.04.3.r1324.gfadf8af-1
                              kapman22.04.3.r665.g6e39899-122.04.3.r666.g0ccc626-1
                        kapptemplate22.04.3.r997.g20b2c62-122.04.3.r998.gba7fdc9-1
                            karchive5.96.0.r549.g20b8e69-15.96.0.r550.g1fd9dc6-1
                               kasts 22.06.r32.g8844d94-1 22.06.r37.g9b97613-1
                                kate22.04.3.r19266.ga8b4c0f44-122.04.3.r19301.g26d1f1c47-1
                             katomic22.04.3.r967.gf5c1e78-122.04.3.r968.g1473146-1
                               kauth5.96.0.r503.g4545a5a-15.96.0.r504.g463ce9b-1
                             kbackup22.04.3.r449.g7d24781-122.04.3.r451.g76cd24f-1
                           kblackbox22.04.3.r775.g8a71905-122.04.3.r776.g59e7617-1
                             kblocks22.04.3.r751.g599c64d-122.04.3.r752.g4c1ebb6-1
                          kbookmarks5.96.0.r465.gdfcd9a6-15.96.0.r466.gb7c7b99-1
                             kbounce22.04.3.r856.gaec2598-122.04.3.r857.g203340f-1
                           kbreakout22.04.3.r930.gb90aab3-122.04.3.r933.gc80f6a9-1
                              kbruch22.04.3.r873.gab39884-122.04.3.r874.g159d907-1
                         kcachegrind22.04.3.r1189.gbdeab59-122.04.3.r1192.gfab7e8d-1
                  kcachegrind-common22.04.3.r1189.gbdeab59-122.04.3.r1192.gfab7e8d-1
                               kcalc22.04.3.r1626.g0157bea-122.04.3.r1627.ga9da569-1
                       kcalendarcore5.96.0.r1335.g0fbb0c73f-15.96.0.r1336.g5c2c1ff23-1
                         kcharselect22.04.3.r538.g9c2bd2e-122.04.3.r540.g4251ce4-1
                              kclock 22.06.r22.gf23328a-1 22.06.r24.ga963493-1
                            kcmutils5.96.0.r651.g85097f0-15.96.0.r656.gbd521f3-1
                             kcodecs5.96.0.r426.ge62c81c-15.96.0.r427.geab5287-1
                       kcolorchooser22.04.3.r278.ge237116-122.04.3.r279.g8672f3b-1
                         kcompletion5.96.0.r506.gb10de8d-15.96.0.r507.g1196686-1
                      kconfigwidgets5.96.0.r752.g89d04a1-15.96.0.r754.ge4b6cb0-1
                           kcontacts1:5.96.0.r3342.gdff759f2-11:5.96.0.r3343.ga7f93d4c-1
                         kcoreaddons5.96.0.r1540.gfadef3bb-15.96.0.r1543.g231c98e2-1
                              kcrash5.96.0.r451.g0dcdf97-15.96.0.r452.g72cd5b4-1
                                kdav1:5.96.0.r1350.g20ecfa7-11:5.96.0.r1351.gea558bc-1
                         kdbusaddons5.96.0.r421.gfe3cbed-15.96.0.r422.g5e8a7bd-1
                       kde-cli-tools5.25.3.r1947.ge85be44-15.25.4.r1949.g2986931-1
                       kde-dev-utils22.04.3.r594.gb8df7e2-122.04.3.r596.g4a84ce3-1
                      kde-gtk-config5.25.3.r939.g3c56cb7-15.25.4.r939.g3c56cb7-1
                      kdebugsettings22.04.3.r955.g6967cdc-122.04.3.r960.gfcb9655-1
                        kdeclarative5.96.0.r1018.g92b6cf0-15.96.0.r1020.g0a1f77c-1
                          kdeconnect22.04.3.r3505.g1c65ede5-122.04.3.r3513.g7f0b03f2-1
                         kdecoration5.25.3.r295.g5df2f5b-15.25.4.r295.g5df2f5b-1
                                kded5.96.0.r468.gec9f232-15.96.0.r470.g143cbf3-1
            kdegraphics-thumbnailers22.04.3.r275.g90f30e3-122.04.3.r277.g1646021-1
                     kdelibs4support5.96.0.r1100.g7cf36906-15.96.0.r1102.g8b2dc42a-1
              kdenetwork-filesharing22.04.3.r964.gc177fc3-122.04.3.r972.ge9ccfd3-1
                            kdenlive22.04.3.r16463.g382ec1a0c-122.04.3.r16557.g74ef83e07-1
                       kdepim-addons22.04.3.r4733.gc10a61798-122.04.3.r4741.g14ad5a25b-1
                    kdeplasma-addons5.25.3.r8967.g8b918d58b-15.25.4.r8992.gbd848ce47-1
                     kdesignerplugin5.96.0.r358.g1603103-15.96.0.r359.g65341e2-1
                               kdesu5.96.0.r512.gb1963b7-15.96.0.r513.g8bf4ac2-1
                           kdewebkit5.96.0.r305.g6be60b7-15.96.0.r306.g3ca78da-1
                                 kdf22.04.3.r867.g822be92-122.04.3.r868.g545f7af-1
                             kdialog22.04.3.r1232.g1f8285e07-122.04.3.r1235.ged8ddd196-1
                            kdiamond22.04.3.r732.g6207f90-122.04.3.r733.gda2c490-1
                            kdisplay5.25.0.r1516.g4617e62-15.25.4.r1516.g4617e62-1
                              kdnssd5.96.0.r355.g60f918e-15.96.0.r356.gfb07d29-1
                           kdoctools5.96.0.r672.gd1a4ebe-15.96.0.r673.g602065c-1
                          kemoticons5.96.0.r422.ge293d50-15.96.0.r423.g9ca93ce-1
                            keysmith 22.06.r17.g9d403f6-1 22.06.r18.g8ed0399-1
                       kfilemetadata5.96.0.r868.g138880a-15.96.0.r870.ge85d971-1
                               kfind22.04.3.r2708.gf40bc0d4b-122.04.3.r2717.g7050e94da-1
                             kfloppy22.04.3.r799.gf7ef5df-122.04.3.r800.ga01a995-1
                         kfourinline22.04.3.r1031.ga76109c-122.04.3.r1032.gf12a7f5-1
                             kgamma55.25.3.r481.g5d1c771-15.25.4.r481.g5d1c771-1
                          kgeography22.04.3.r1161.g65d2576-122.04.3.r1162.g153531f-1
                                kget22.04.3.r3217.gbd08a346-122.04.3.r3219.gf2af4abf-1
                        kglobalaccel5.96.0.r537.g5683e03-15.96.0.r538.g27624db-1
                         kgoldrunner22.04.3.r1293.gab710ef-122.04.3.r1294.ge3cb3b6-1
                                kgpg22.04.3.r3199.g22092caf-122.04.3.r3202.g2427cbcc-1
                          kguiaddons5.96.0.r481.ga3b46ae-15.96.0.r483.g6493b29-1
                            khangman22.04.3.r1621.gfd91cfe-122.04.3.r1623.g30d2e54-1
                  khealthcertificate 22.06.r12.gd20ebea-1 22.06.r17.gbf895ba-1
                         khelpcenter22.04.3.r2767.g2b26e275-122.04.3.r2770.g1cae17ac-1
                           kholidays1:5.96.0.r1045.g8cc6ac7-11:5.96.0.r1052.gb883a37-1
                            khotkeys5.25.3.r2154.gf725bc7-15.25.4.r2154.gf725bc7-1
                               khtml5.96.0.r590.g559f347-15.96.0.r593.g9712a64-1
                               ki18n5.96.0.r564.g0926f2b-15.96.0.r565.g7c12a65-1
                         kiconthemes5.96.0.r615.g9095ef7-15.96.0.r620.g41fb2ae-1
                           kidletime5.96.0.r362.g07f0ef5-15.96.0.r363.g11d238e-1
                                kigo22.04.3.r577.g0aa6d0a-122.04.3.r578.ga21efd6-1
                            killbots22.04.3.r801.ge083b35-122.04.3.r802.gd0e6de7-1
                       kimageformats5.96.0.r421.g6074c4d-15.96.0.r422.ge6955e1-1
                     kimagemapeditor22.04.3.r500.g98044a1-122.04.3.r502.g9b8f3db-1
                         kinfocenter5.25.3.r2129.g59184a24-15.25.4.r2134.g3bd2b474-1
                               kinit5.96.0.r443.g208c119-15.96.0.r445.g85ca4b6-1
                                 kio5.96.0.r5617.gbef623c10-15.96.0.r5641.g63c888e33-1
                          kio-extras22.04.3.r7314.g2430179b-122.04.3.r7331.gdbb5869f-1
                          kio-gdrive22.04.3.r622.g85bd479-122.04.3.r629.gfb7c7e9-1
                     kirigami-addons  1:0.3.r6.gbd7741e-1  1:0.3.r7.g3830da0-1
                    kirigami-gallery22.04.3.r259.gf983f28-122.04.3.r264.gcb4ae79-1
                           kirigami25.96.0.r3187.g07959ea6-15.96.0.r3280.ge35b48b9-1
                              kiriki22.04.3.r458.g9484807-122.04.3.r461.g8f83065-1
                         kitemmodels5.96.0.r614.g8d0117c-15.96.0.r615.g78cde10-1
                          kitemviews5.96.0.r379.g77f35ee-15.96.0.r380.ge4d9fcd-1
                               kiten22.04.3.r1206.g07564c4-122.04.3.r1207.g99d1609-1
                          kitinerary22.04.3.r2340.g9c83d2e-122.04.3.r2354.g3544865-1
                         kjobwidgets5.96.0.r422.g437782c-15.96.0.r424.gc096275-1
                                 kjs5.96.0.r367.gd1b8856-15.96.0.r368.gfd9252e-1
                            kjsembed5.96.0.r332.gc786956-15.96.0.r333.gef9ea48-1
                        kjumpingcube22.04.3.r830.g1dfa2f1-122.04.3.r831.g0f447de-1
                           kleopatra22.04.3.r6723.gaf5904e2-122.04.3.r6785.g22cc7a6f-1
                            klettres22.04.3.r971.g76432f8-122.04.3.r972.gebc55cc-1
                            klickety22.04.3.r703.gbc1c850-122.04.3.r706.ga9f487a-1
                              klines22.04.3.r829.g1a1611f-122.04.3.r830.gf8e4590-1
                                kmag22.04.3.r743.g99e4aaf-122.04.3.r744.g24a22bd-1
                           kmahjongg22.04.3.r1567.g6df1f7f-122.04.3.r1569.gdd62313-1
                               kmail22.04.3.r26463.ge277afc67-122.04.3.r26499.g9f8759235-1
                        kmediaplayer5.96.0.r321.gf68bf85-15.96.0.r322.g014a259-1
                           kmenuedit5.25.3.r1058.g372bd9e-15.25.4.r1062.g6e7cd3f-1
                              kmines22.04.3.r1773.g9b0543f-122.04.3.r1774.gb5699a9-1
                                kmix22.04.3.r2456.gae08af55-122.04.3.r2459.g07dd1b95-1
                          kmousetool22.04.3.r451.gec55edf-122.04.3.r453.g0078db7-1
                              kmouth22.04.3.r735.gea167b1-122.04.3.r741.g4384969-1
                              kmplot22.04.3.r1502.g5cd3999-122.04.3.r1505.gedccb7d-1
                        knavalbattle22.04.3.r1440.g442257c-122.04.3.r1441.ga31fd57-1
                            knetwalk22.04.3.r707.g800f644-122.04.3.r708.g6f5d2c7-1
                           knewstuff5.96.0.r1368.g3bf2a1f2-15.96.0.r1369.ga97b882d-1
                             knights22.04.3.r1151.g5a6ba8b-122.04.3.r1153.gc3d77b4-1
                              knotes22.04.3.r3685.g85f97513-122.04.3.r3688.g72d23770-1
                      knotifications5.96.0.r752.gb83d890-15.96.0.r753.g04dbd95-1
                       knotifyconfig5.96.0.r389.gc0aad14-15.96.0.r390.gbd78f1a-1
                                koko 22.06.r12.g8a3a8bc-1 22.06.r13.g906a5fe-1
                                kolf22.04.3.r1515.gcd146ae-122.04.3.r1518.g6297a22-1
                           kollision22.04.3.r542.g4223584-122.04.3.r543.g0b77fd6-1
                         kolourpaint22.04.3.r2429.gb5116cfc-122.04.3.r2432.ga15bb8be-1
                             kompare22.04.3.r1146.g3d27211-122.04.3.r1152.g2e4ae11-1
                            kongress 22.06.r12.g4126d2f-1 22.06.r26.g6ceb7ca-1
                           konqueror22.04.3.r15134.g12e4f8431-122.04.3.r15150.gacc58909d-1
                            konquest22.04.3.r938.gf977f64-122.04.3.r939.g078d7c7-1
                             konsole22.04.3.r8562.g036be9ee-122.04.3.r8570.ga27a22ff-1
                             kontact22.04.3.r5556.gd7c715b9-122.04.3.r5559.gd677e97e-1
                            kontrast22.04.3.r211.gde0b942-122.04.3.r212.g216d41e-1
                        konversation22.04.3.r9132.gd0ca8bf5-122.04.3.r9134.g3bb108c8-1
                              kopete22.04.3.r16446.gd5d42981c-122.04.3.r16447.gf95cf63c8-1
                          korganizer22.04.3.r11780.gf25a8724e-122.04.3.r11788.g9fee35d00-1
                       kosmindoormap22.04.3.r746.gafe12ac-122.04.3.r748.gbb0dd84-1
                            kpackage5.96.0.r760.g74bf92c-15.96.0.r761.g5f69b4a-1
                              kparts5.96.0.r594.g4743e72-15.96.0.r595.g8f564bc-1
                                kpat22.04.3.r2627.gdd62a1ab-122.04.3.r2628.g387601a7-1
                             kpeople5.96.0.r1381.ge9b7118-15.96.0.r1382.g22c5339-1
                           kpipewire5.25.3.r135.g3bc932e-15.25.4.r135.g3bc932e-1
                           kplotting5.96.0.r328.g61fd8b9-15.96.0.r329.gc67bc59-1
                             kpmcore22.04.3.r1294.gf01581f-122.04.3.r1295.g8381994-1
                                kpty5.96.0.r380.gfba4b75-15.96.0.r381.g99d043f-1
                    kpublictransport22.04.3.r2038.g704136b5-122.04.3.r2040.g6cbb1c5c-1
                        kquickcharts5.96.0.r525.g0b6c9e5-15.96.0.r528.g7d72fc0-1
                                krdc22.04.3.r1617.g6953f60-122.04.3.r1618.g88ffda7-1
                           krecorder 22.06.r10.g7551196-1 22.06.r11.g2e30772-1
                            kreversi22.04.3.r1277.ge439d6c-122.04.3.r1278.ge11a534-1
                                krfb22.04.3.r1511.g5173e7f-122.04.3.r1515.g4606fca-1
                               kross5.96.0.r362.g06fc4ec-15.96.0.r364.gcca187e-1
                              kruler22.04.3.r742.g7a29873-122.04.3.r743.gb06fab2-1
                             krunner5.96.0.r778.g1fcb430-15.96.0.r779.gbe6e416-1
                             kscreen5.25.3.r1505.ge15d173-15.25.4.r1521.g97e612c-1
                       kscreenlocker5.25.3.r972.g87f3043-15.25.4.r974.g5af2dbd-1
                            kservice5.96.0.r1024.g7b06291-15.96.0.r1027.g19eb760-1
                             kshisen22.04.3.r1251.gc911899-122.04.3.r1252.gaa75b67-1
                               ksirk22.04.3.r1040.g0f6e3dc-122.04.3.r1044.ge301aa0-1
                          ksnakeduel22.04.3.r860.gd452466-122.04.3.r861.gf46b2f8-1
                          kspaceduel22.04.3.r680.g87cab42-122.04.3.r681.gc8228fe-1
                            ksquares22.04.3.r566.g608dcbf-122.04.3.r567.g7142f12-1
                         ksshaskpass5.25.3.r212.gd1bef1b-15.25.4.r212.gd1bef1b-1
                             ksudoku22.04.3.r1125.g56f3503-122.04.3.r1127.g64ec262-1
                           ksysguard5.25.3.r3538.g13734f4d-15.25.4.r3540.geea1d41b-1
                          ksystemlog22.04.3.r743.g59d0474-122.04.3.r744.ge555200-1
                        ksystemstats5.25.3.r232.g5ae8db9-15.25.4.r232.g5ae8db9-1
                            kteatime22.04.3.r764.g8bcc6b3-122.04.3.r765.ged58378-1
                         ktexteditor5.96.0.r3442.g9dd9142e-15.96.0.r3484.g18cd4752-1
                        ktextwidgets5.96.0.r453.g7f5c312-15.96.0.r454.g608c190-1
                              ktimer22.04.3.r527.g11ffead-122.04.3.r529.gef39a2b-1
                            ktorrent22.04.3.r2871.gefcfdaa3-122.04.3.r2878.g28d8ee6c-1
                              ktouch22.04.3.r2195.gd290b2a-122.04.3.r2196.g2bf7c51-1
                               ktrip  22.06.r9.g649ae9b-1 22.06.r11.gcc2e33e-1
                          ktuberling22.04.3.r1072.gcd78e2a-122.04.3.r1073.g87ff652-1
                             kturtle22.04.3.r1178.gbe120d4-122.04.3.r1181.g1755a0b-1
                             kubrick22.04.3.r416.gc7023a4-122.04.3.r417.g3eae0c0-1
                     kunitconversion5.96.0.r423.ge54e91e-15.96.0.r424.g7456dc5-1
                             kwallet5.96.0.r1165.gcc873f6-15.96.0.r1166.g8c458cc-1
                         kwallet-pam5.25.3.r271.g40ad5fe-15.25.4.r271.g40ad5fe-1
                      kwalletmanager22.04.3.r1282.gc6579ba-122.04.3.r1283.g3b2a55b-1
                               kwave22.04.3.r3801.gac141b3f-122.04.3.r3803.gc09e9745-1
                            kwayland5.96.0.r1172.g5227e3f-15.96.0.r1175.g57cf099-1
                kwayland-integration5.25.3.r212.gef63862-15.25.4.r212.gef63862-1
                     kwayland-server5.25.3.r1480.g7f15f36-15.25.4.r1481.gdec04c4-1
                            kweather 22.06.r25.gb729666-1 22.06.r39.g5f0ba67-1
                        kweathercore    0.6.r6.gee49ab6-1   0.6.r13.g05b1eec-1
                      kwidgetsaddons5.96.0.r959.ge3465ead-15.96.0.r965.gecc211bc-1
                                kwin5.25.3.r22868.gbd8d65a86-15.25.4.r22980.gf4e917f73-1
                       kwindowsystem5.96.0.r689.gaf80173-15.96.0.r690.gf543b42-1
                              kwinft5.25.0.r20860.g5bda3d48c-15.25.4.r21056.g483de1b14-1
                           kwordquiz22.04.3.r1189.g589682f-122.04.3.r1198.gb92c023-1
                              kwrite22.04.3.r19266.ga8b4c0f44-122.04.3.r19301.g26d1f1c47-1
                             kwrited5.25.3.r514.g2a65ab9-15.25.4.r514.g2a65ab9-1
                             kxmlgui5.96.0.r898.g072c1e8e-15.96.0.r900.gb9104169-1
                       kxmlrpcclient5.96.0.r485.g39b1f081d-15.96.0.r486.g4f9239727-1
                      layer-shell-qt5.25.3.r62.g7bd6366-15.25.4.r62.g7bd6366-1
                          libakonadi22.04.3.r12797.g5e6620486-122.04.3.r12799.g00999d2ce-1
                         libgravatar22.04.3.r431.gddf44e2-122.04.3.r432.g9cbfbfe-1
                            libkcddb22.04.3.r765.g5088301-122.04.3.r766.g87fb821-1
                     libkcompactdisc22.04.3.r396.g25896b1-122.04.3.r397.gdf35590-1
                  libkeduvocdocument22.04.3.r1810.g5b20cc7-122.04.3.r1811.gd4b7962-1
                            libkgapi22.04.3.r1371.gd1e1cbf-122.04.3.r1372.g87bdfc1-1
                             libkleo22.04.3.r1240.g07e762c-122.04.3.r1249.g0386040-1
                        libkmahjongg22.04.3.r486.ga227949-122.04.3.r487.g8694c45-1
                          libkscreen5.25.3.r1634.g4004b09-15.25.4.r1634.g4004b09-1
                           libksieve22.04.3.r1733.g087d103a-122.04.3.r1736.g37e547f4-1
                        libksysguard5.25.3.r2425.g9a01468-15.25.4.r2426.gbd1dc2a-1
                         libktorrent22.04.3.r552.g4f6c01c-122.04.3.r561.g4a88224-1
                            lokalize22.04.3.r1841.g167df143-122.04.3.r1845.g161489f1-1
                               lskat22.04.3.r862.g1426b3a-122.04.3.r863.g367290c-1
                          mailcommon22.04.3.r1269.g5f8ee03-122.04.3.r1287.g9f0aad7-1
                    maliit-framework 2.3.0.r0.gcb623a42-1 2.3.0.r2.g7a929ce8-1
                              marble22.04.3.r13459.g4aac89480-122.04.3.r13461.g7c89da6c3-1
                       marble-common22.04.3.r13459.g4aac89480-122.04.3.r13461.g7c89da6c3-1
                           marble-qt22.04.3.r13459.g4aac89480-122.04.3.r13461.g7c89da6c3-1
                        markdownpart22.04.3.r131.g8f0d5b2-122.04.3.r132.g8d3f6f5-1
                           maui-clip 2.1.2.r11.gb56ee85-1 2.1.2.r12.g29017bd-1
                           maui-nota 2.1.2.r11.g1064432-1 2.1.2.r13.g231216b-1
                            maui-pix 2.1.2.r18.g1ea25f0-1 2.1.2.r19.g476ee36-1
                          maui-shell 0.5.0.r57.g1182b2e-1 0.5.0.r72.ge969251-1
                             mauikit2.1.2.r51.gdaf7fab6-12.1.2.r59.gc6085161-1
                mauikit-filebrowsing  2.1.2.r9.g2ae2187-1 2.1.2.r11.gca2084a-1
                  mauikit-imagetools  2.1.2.r4.gf2b432e-1  2.1.2.r5.gad0d210-1
                  mauikit-texteditor  2.1.2.r4.g2270a27-1  2.1.2.r5.g60b5ab0-1
                             mauiman        r26.0eff78b-1        r28.101f05f-1
                          messagelib22.04.3.r6636.g9b961d803-122.04.3.r6651.g0291e64e4-1
                               milou5.25.3.r780.ga50415d-15.25.4.r781.gf71a8fd-1
                              minuet22.04.3.r618.gd5a8e59-122.04.3.r619.g95e0c81-1
                     modemmanager-qt5.96.0.r558.gbc128da-15.96.0.r559.gd870646-1
                             neochat22.06.r56.g84a265b7-122.06.r63.gf9ad0e84-1
                   networkmanager-qt5.96.0.r1158.gea3156d-15.96.0.r1159.g5f9316a-1
                              okular22.04.3.r9793.gb96902b40-122.04.3.r9812.g4ad5753c3-1
                              oxygen5.25.3.r4500.ga50719e0-15.25.4.r4501.gdf744478-1
                            palapeli22.04.3.r1294.gf2d5df8-122.04.3.r1301.ge794a84-1
                              parley22.04.3.r4535.gf3a4ad33-122.04.3.r4540.g21073171-1
                    partitionmanager22.04.3.r1637.g799603c-122.04.3.r1639.gf33e780-1
                   pim-data-exporter22.04.3.r2770.g975f545c-122.04.3.r2779.gfc0c86a8-1
                    pim-sieve-editor22.04.3.r1645.g766e5fe-122.04.3.r1647.g7234f18-1
                           pimcommon22.04.3.r1258.g6000a95-122.04.3.r1262.gf3d5251-1
                    plasma-bigscreen      r494.gcff5977-1      r497.gb8eedee-1
          plasma-browser-integration5.25.3.r1339.g3ba5d473-15.25.4.r1342.g9ba3362d-1
                      plasma-desktop5.25.3.r9497.g0dbd7da03-15.25.4.r9539.g6eec434c4-1
                       plasma-dialer 22.06.r22.gd032a2d-1 22.06.r26.gc60f8b8-1
                        plasma-disks5.25.3.r286.g3f58a5f-15.25.4.r287.g38d3106-1
                     plasma-firewall5.25.3.r644.g2dfb7dd-15.25.4.r646.gf7df8cb-1
                    plasma-framework5.96.0.r16374.g5ddb367d0-15.96.0.r16387.gca97fada4-1
                  plasma-integration5.25.3.r572.g6ed27d1-15.25.4.r572.g6ed27d1-1
                       plasma-mobile5.25.3.r1926.gaeddd5ab7-15.25.4.r1929.gb9fbb2da5-1
                    plasma-mobile-nm5.25.3.r3307.g117e0add-15.25.4.r3316.g700fd979-1
                         plasma-nano5.25.3.r191.g5deb2a5-15.25.4.r192.gbd29071-1
                           plasma-nm5.25.3.r3307.g117e0add-15.25.4.r3316.g700fd979-1
                           plasma-pa5.25.3.r1064.g99fd1b1-15.25.4.r1065.ge9732de-1
                    plasma-phonebook  22.06.r8.g6a98656-1 22.06.r11.g689a118-1
                          plasma-sdk5.25.3.r2382.g720c0865-15.25.4.r2385.g53055b35-1
                     plasma-settings 22.06.r48.ga3af120-1 22.06.r64.gb242244-1
                plasma-systemmonitor5.25.3.r603.g5ce820d-15.25.4.r608.g42fde83-1
                  plasma-thunderbolt5.25.3.r193.g8369978-15.25.4.r194.gfa11777-1
                        plasma-vault5.25.3.r388.gf2f7183-15.25.4.r388.gf2f7183-1
              plasma-wayland-session5.25.3.r12151.g8df9bef6f-15.25.4.r12199.g05e2dc0c6-1
                    plasma-workspace5.25.3.r12151.g8df9bef6f-15.25.4.r12199.g05e2dc0c6-1
         plasma-workspace-wallpapers5.25.3.r368.g30a6341-15.25.4.r374.g54d2dd6-1
                          plasmatube  22.06.r8.g939828c-1 22.06.r11.gdb1c664-1
                    polkit-kde-agent5.25.3.r531.ge482883-15.25.4.r531.ge482883-1
                          powerdevil5.25.3.r2574.ga4e1252c-15.25.4.r2581.g260c2489-1
                       print-manager22.04.3.r1149.g9e58537-122.04.3.r1155.g1f93b44-1
                              prison5.96.0.r394.gd7671ab-15.96.0.r396.g7f359b9-1
                             purpose5.96.0.r985.g64ed389-15.96.0.r989.g0acb6e7-1
                         qcachegrind22.04.3.r1189.gbdeab59-122.04.3.r1192.gfab7e8d-1
                          qmlkonsole 22.06.r12.g9fe7f12-1 22.06.r14.g812010d-1
                   qqc2-breeze-style5.25.3.r249.g36ec4ea-15.25.4.r249.g36ec4ea-1
                  qqc2-desktop-style5.96.0.r646.g1bcaf0b-15.96.0.r647.g138b675-1
                                rocs22.04.3.r3095.g4c9d2cfa-122.04.3.r3110.g8f75ac0d-1
                            sddm-kcm5.25.3.r673.g70e0760-15.25.4.r680.gd5dcd87-1
                               solid5.96.0.r784.g8c9ad6a-15.96.0.r785.gf7391d6-1
                              sonnet5.96.0.r707.g091b91f-15.96.0.r708.g0b11814-1
                            spacebar 22.06.r45.g6ae2512-1 22.06.r55.g8d3c86a-1
                           spectacle22.04.3.r1377.gde864e6-122.04.3.r1382.gdb23e1f-1
                                step22.04.3.r1205.gbf9c057-122.04.3.r1206.g78637a2-1
                             svgpart22.04.3.r234.gb4c5361-122.04.3.r235.g939b16d-1
                             sweeper22.04.3.r579.g28430e5-122.04.3.r583.g0648883-1
                         syndication5.96.0.r878.g90db4b7-15.96.0.r879.g6a9c9de-1
                 syntax-highlighting5.96.0.r1869.g4568c392-15.96.0.r1899.gd109fd23-1
                      systemsettings5.25.3.r2696.gec27bae1-15.25.4.r2701.gea3f2d06-1
       telepathy-kde-desktop-applets22.04.3.r1006.gb0a027c-122.04.3.r1007.g06cd5ac-1
                        threadweaver5.96.0.r546.g167d409-15.96.0.r548.gec07224-1
                             tokodon 22.06.r22.gb0cb919-1 22.06.r26.g5b4fa72-1
                            umbrello22.04.3.r8487.g908b3425f-122.04.3.r8499.g775fbb65b-1
                         vakzination 22.06.r19.g50d4ab9-1 22.06.r30.g56d3e49-1
                               vvave 2.1.2.r26.ge0417a4-1 2.1.2.r27.g9ec0341-1
                            wrapland5.25.0.r1761.gc522abc3-15.25.4.r1761.gc522abc3-1
              xdg-desktop-portal-kde5.25.3.r512.g57f17b2-15.25.4.r513.g7b0219e-1
                             yakuake22.04.3.r807.g1213c6d-122.04.3.r813.g0a559f0-1
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #manjaro-arm:arm-testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
Donation
Please consider supporting Manjaro ARM directly via Patreon, Ko-Fi or Open Collective.
You can also donate to our upstream, which is Arch Linux ARM.
Poll
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Before 2022-07-22
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
  1. any time you launch waydroid, run the following after it has started:
echo "ip route add default via 192.168.250.1" |sudo waydroid shell
Old Issues
Plasma Dialer cannot answer calls
Sadly Plasma Dialer 22.02 has a serious regression with no known workaround. It’s not possible to accept incoming calls. Very sorry about this. Follow the upstream bug report. We will patch the package as soon as a solution is found.
Plasma Mobile - Black screen after update
We are seeing some reports about Plasma Mobile on the PinePhone only showing a black screen after entering the PIN after this update.
Workaround: Downgrade qt5-es2-wayland to 5.15.2+kde+r41 which is now back in Stable and Testing branch repositories.
New Breath theme not applying correctly
With the update to the new Breath theme, a migration package tries to apply the new theme correctly.
However this is not getting done for Plasma’s Lockscreen and the SDDM theme.
So please go through your settings after updating to make sure the themes are correctly applied.
Fix: manjaro-system should take care of this for you.
Plasma Mobile switch to ModemManager
With the PlaMo Gear 21.12 release, Plasma Mobile is now using ModemManager as the telephony stack. So in order to use SIM capabilities, you need to switch from using oFono to ModemManager.
Fix: Run sudo systemctl disable --now ofono ofonoctl && sudo systemctl enable --now ModemManager. You might have to reboot your phone for Plasma Mobile to pick up this change.
Plasma Mobile has does not launch after update
This was caused by an error in kwin 5.23.2 which only affects installs based on openGLES (qt5-es2).
Fix: Update to kwin 5.23.2-1.2 or above.
No ethernet on rk3399 boards
A recent kernel regression has resulted in built in ethernet on rk3399 based boards, such as RockPro64 and Rock Pi 4’s, no longer works on kernel 5.14. This is an upstream issue that has not been fixed yet.
Fix: Update to linux-5.14.1-2 or newer.
Vivaldi no longer working
The issue is present in all chrome based browser (except Chromium that got a patch for it).
It’s an issue with systemd-resolved and has been reported in the Arch Linux Bug Tracker.
Needs to be fixed by Vivaldi updates in the future.
Fix: Vivaldi 4.1.2369.21 fixed this issue.
Modemmanager-pp dependency issue
modemmanager-pp 1.16.10 depends on libqmi-pp and libmbim-pp, but they are no longer found in the repo.
Fixed by updated to modemmanager-pp 1.18rc1+2+ga20f2c05-2.
systemd-hook unsuccesful after pacman 6 update
After the pacman 6 update, updates will create this message in the post-transation hooks part:
Running the command manually works and there has been no issues reported as the result of this. This will either get fixed at some point in Pacman or SystemD.
Should be fixed with pacman-6.0.0-4
Keyring issues
If you have some gpg keyring issues, you can run sudo systemctl start pacman-init.service which will regenerate your keyring. Will take a few minutes to complete.
Should be fixed with manjaro-system-20210716-1
Plasma Mobile no longer boots
The current update to qt5-es2-base results in Plasma Mobile no longer booting, showing a screen that says to run a loginctl command to login.
Fixed by updating to qt5-es2-base-5.15.2+kde+r199-3.1 and qt5-es2-declarative-5.15.2+kde+r28-3.1.
Kwin crashes on startup on Pinebook Pro
This seems to be related to Mesa 20.3 and the Pinebook Pro support in kernel 5.10, as this does not seem to happen on other devices.
It does not impact 3d performance as far as I can tell. Just the OpenGL compositing in Kwin.
Fixed with mesa 20.3.2-2.
My VPN no longer connects
OpenVPN 2.5.0 changed how VPN routes work.
Workaround is to downgrade to previous version (2.4.9):
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.4.9*
DP Alt Mode no longer works on Pinebook Pro
This is a known issue, the hacky patch we had to enable this has broken in recent kernels.
@tsys and Ayufan are looking into it.
As a workaround you can install linux-pinebookpro again.
FIXED with linux-5.9.12-4 and linux-rc-5.10-rc7-2 and above.
brcm-patchram-plus and pi-blueooth are in conflict
See this post for workaround:
[ARM Testing Update] 2020-11-16 - Bitwarden, Mesa-Git, Pacman and kernels - #10 by Darksky
Plasma Mobile Keyboard
The plasma mobile onscreen keyboard does not work with QT 5.15.0.
This is fixed by updating to kwin 5.19.3-1.1.
PinePhone uboot
This update to the PinePhone Uboot package (2020.04-2), changed how the DTS is loaded from the kernel, since the Kernel DTS for the Pinephone also changed. When doing this update on the PinePhone images from Alpha5 and back, please make this change to the /boot/extlinux/extlinux.conf before rebooting:
  • sun50i-a64-pinephone.dtb to sun50i-a64-pinephone-1.2.dtb
  • root=LABEL=ROOT to root=LABEL=ROOT_MNJRO
Manual interventions:
The nss and zn_poly packages prior to version 3.51.1-1 and version 0.9.2-2 respectively, were missing a soname link each. This has been fixed in 3.51.1-1 and 0.9.2-2 of these packages, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
nss: /usr/lib/p11-kit-trust.so exists in filesystem
zn_poly: /usr/lib/libzn_poly-0.9.so  exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/p11-kit-trust.so --overwrite /usr/lib/libzn_poly-0.9.so
to perform the upgrade.
Device stopped booting after Uboot update
The uboot update included a change to the extlinux.conf file. This change will be incompatible with the old 1 partition layout of some devices.
So if you are updating installs made with images 20.02.1 or older, you need to apply this fix before rebooting!
To fix this please edit your /boot/extlinux/extlinux.conf file and add 2 periods in front of each first slash, like so:
KERNEL ../Image
FDT ../dtbs/ #etc.
APPEND initrd=../initramfs-linux.img #etc.
GT King Pro upgraded successfully successfully to Arm-Stable-2022-08-16 but with warnings and took 69 minutes (which is much longer than usual).
( 71/102) upgrading graphviz                                    [##################################] 100%
Warning: Could not load "/usr/lib/graphviz/libgvplugin_gdk.so.6" - It was found, so perhaps one of its dependents was not.  Try ldd.
Warning: Could not load "/usr/lib/graphviz/libgvplugin_gtk.so.6" - It was found, so perhaps one of its dependents was not.  Try ldd.
( 72/102) upgrading hwinfo                                      [##################################] 100%
I also notice “systemd-analyze blame” shows an unusually long wait for “systemd-networkd-wait-online.service” >2mins. Is there a way to optimize this?
 jflim@jflim-gtkpro    systemd-analyze blame
2min 131ms systemd-networkd-wait-online.service
   10.401s NetworkManager-wait-online.service
    3.549s udisks2.service
    2.148s dev-sda2.device
    1.088s lvm2-monitor.service
Previous update I also had no more hard lockups and no more wifi adapter problems.
So far everything is smooth on my Pinebook Pro. Been running for several hours.
With other updates I had hard lockups within an hour and it gradually faded away.
Phosh after login accepts one single starting app. If I use the phosh slider to start another the display freezes . Also if I don’t start any app from phosh or missspell first passwords e.g. keyring then phosh freezes. Only hard button reset brings login back. Only shell console works without touching any phosh thing.
Turn on animations under Tweaks > Phosh > Performance
After this update, Geary fails to connect to my ISP’s IMAP server. It keeps asking me to confirm the saved password. The same password worked before the update and still works from my computer. I tried retyping the password as requested, that did not fix it either.
Note that Geary itself was not updated, so it is probably the libraries it uses.
As far as I can tell, it is passing a wrong username and/or password to the IMAP login command (and it does not show in the log what it passes due to misguided “security” concerns). The server rejects the credentials. Why that started happening now, I have no idea, because Geary was not updated.
Yet secret-tool search proto IMAP shows the correct credentials!
Well, guess what, now it works! Yet I have not done anything to make it work (unless searching in secret-tool magically made it work? I doubt it). So I am just going to blame the ISP. Yet the computer was able to successfully log in at the exact same time to the exact same server (well, domain name – round robin DNS might have pointed the machines to different IPs) with the exact same credentials from the same public IP (and normally simultaneous connections are accepted).
Thus, sorry, false alarm (and more than 2 hours wasted debugging it :frowning:).
Good, worked. And awesome how quick my pinephone returned into stable mode. Thank you :blush:
Yes, the update works great on the PinePhone, no regressions noted. (Geary also still works great, the issue yesterday was apparently a transient issue on the mail server’s (the ISP’s) end.)
I mainly use my Pinebook Pro connected to a USB charger. Sometimes I get a warning that the machine will shut down, because of critical low battery level. The battery icon will switch to empty for a couple of seconds, but will quickly switch back to fully charged and everything is back to normal.
Any other people experiencing the same, or is my battery unstable?
Hi there,
I am on a RPI4, the new update tells me there is a conflict when using pacman
"la satisfaction des dépendances a échoué:
  • la suppression de wxgtk-common casse la dĂ©pendance « wxgtk-common » requise par wxgtk2"
    I’ve also tried through the terminal with “sudo pacman -Syu” and there I am asked to accept or not
    Synchronisation des bases de données de paquets…
    core est Ă  jour
    extra est Ă  jour
    community est Ă  jour
    :: Début de la mise à jour complète du système…
    :: Remplacer med par community/med-openmpi ? [O/n] o
    :: Remplacer wxgtk-common par extra/wxwidgets-common ? [O/n] o
    :: Remplacer wxgtk3 par extra/wxwidgets-gtk3 ? [O/n] o
    résolution des dépendances…
    recherche des conflits entre paquets…
    :: hdf5-openmpi et hdf5 sont en conflit. Supprimer hdf5 ? [o/N] o
    erreur : la préparation de la transaction a échoué (la satisfaction des dépendances a échoué)
    :: la suppression de wxgtk-common casse la dépendance « wxgtk-common » requise par wxgtk2
what should * do?
thank you
best regards
I use a Raspberry Pi 400 and I use Majaro-ARM XFCE. I just bought a 4K tv. My old tv was a 1080p and I before it broke I was able to turn it off and leave the Pi on. When I turned on the tv after about 5 minutes or more, it stayed at the same resolution. I have always set Manjaro to 1280x720. I tried it with my new tv and when I turn it back on or unplug and reconnect the HDMI cable, Manjaro is reset to 3840x2160. How do I get Manjaro to ignore this info from my tv and remain at 1280x720?
This also happens for me
