Thanks so much for providing the libxfce4ui-nocsd package! It really helps after the update to XFCE 4.16. I’m using it with gtk3-classic and it works well to restore the classic XFCE window appearance. One more little advantage of using Manjaro!
One little remaining glitch I noticed, though, is double title bars on notification dialogs:
Anyone else seeing this? Can this be fixed with libxfce4ui-nocsd?
Looks like this is not libxfce4ui-nocsd related (as it’s the same with libxfce4ui), maybe just gtk3-classic with XFCE 4.16. But I found the solution in the issues of the libxfce4ui-nocsd github page:
set the DialogsUseHeader option to false under Settings Editor>xsettings>Gtk
Sorry,
maybe it’s a litte bit off-topic, but where from do you get version 4.16. Compile and install from source?
If I do “pacman -S xfce4” i still get the offer to install xfce 4.16
