Xdm crashes
Hi all,
I’ve installed the last testing update for my openrc kde and now I’ve the problem, that I have no desktop. My system starts normally but I only get a terminal, where I can login with my username and password. I typed
and I get the output, that xdm crashed.
What can I do to fix this issue?
Roberto
So what DM do you use?
You need to set it in /etc/conf.d/xdm
I suggest for any openrc user to please read some basic openrc documentation. It will help you. :slight_smile:
The gentoo wiki is usually a good source, since openrc is default on gentoo, and you even learn a bit about kernel settings if you are interested, but this can be skipped on manjaro.
Hi artoo, I use sddm and its set in /etc/conf.d/xdm.
Thanks for your hint to get some openrc basics but I don’t find any helpful tips for my problem. I’m always interestet in learning more about the basics of manjaro and openrc.
I tried to restart xdm with
but I get the warning that xdm is already startet.
You need sddm-elogind package.
But I suspect something is off with your xorg.
The sddm-elogind package is installed too. I switched from consolekit to elogind several weeks ago.
Please post the /var/log/Xorg.0.log
And your ~.local/share/sddm/xorg-session.log
Sorry for my stupid question, but how can I post the output of these files, when I have no graphical interface to save and upload it here?
I’m afraid, that I haven’t read this chapter of the basics.
Ah, I see, it depends on your terminal skills do that.
The cat some_file command will display file contents.
Look at your logs if any obvious errors are logged.
I opened the ~.local/share/sddm/xorg-session.log and there is the following error logged:
It seems, taht there is a problem with the X11 server.
As suspected.
I would need your inxi output and if possible the /var/log/Xorg.0.log
Can I send you 2 screenshots to post it?
Start with the log file, its atm more interesting.
Here’s the log file:
Unfortunately, the interesting part is at the beginning of the file, the card and screen initialization.
2nd attempt:
Please try switching to unstable branch, I can guarantee it works there.
Also, your basic error description is insufficient. The pacman.log would be nice too, what updates you did in testing.
Switching to unstable was the solution.
Here is the output of the pacman.log from testing branch:
[2017-05-26 20:16] [PACMAN] Running 'pacman -Sy' [2017-05-26 20:16] [PACMAN] synchronizing package lists [2017-05-26 20:17] [PACMAN] Running 'pacman -Syyu' [2017-05-26 20:17] [PACMAN] synchronizing package lists [2017-05-26 20:17] [PACMAN] starting full system upgrade [2017-05-26 20:20] [ALPM] transaction started [2017-05-26 20:20] [ALPM] upgraded alsa-lib (1.1.3-1 -> 1.1.4-1) [2017-05-26 20:20] [ALPM] upgraded alsa-plugins (1.1.1-1 -> 1.1.4-1) [2017-05-26 20:20] [ALPM] upgraded libtiff (4.0.7-3 -> 4.0.8-1) [2017-05-26 20:20] [ALPM] upgraded imagemagick (6.9.8.5-1 -> 6.9.8.6-1) [2017-05-26 20:20] [ALPM] upgraded libelogind (228.3-1 -> 229.3-1) [2017-05-26 20:20] [ALPM] upgraded hwids (20161103-1 -> 20170328-1) [2017-05-26 20:20] [ALPM] upgraded mesa (17.0.6-1 -> 17.1.0-1) [2017-05-26 20:20] [ALPM] upgraded cups-filters (1.13.5-1 -> 1.14.0-1) [2017-05-26 20:20] [ALPM] upgraded dmidecode (3.0-1 -> 3.1-1) [2017-05-26 20:20] [ALPM] upgraded elogind (228.3-1 -> 229.3-1) [2017-05-26 20:20] [ALPM] upgraded libx264 (2:148.20170121-1 -> 2:148.20170121-6) [2017-05-26 20:20] [ALPM] upgraded ffmpeg (1:3.3-5 -> 1:3.3.1-8) [2017-05-26 20:20] [ALPM] upgraded noto-fonts (20170307-2 -> 20170428-1) [2017-05-26 20:20] [ALPM] upgraded pango (1.40.5-1 -> 1.40.6+6+g6f59d0f3-2) [2017-05-26 20:20] [ALPM] upgraded jasper (2.0.12-1 -> 2.0.13-1) [2017-05-26 20:20] [ALPM] upgraded openssl-1.0 (1.0.2.k-3 -> 1.0.2.k-4) [2017-05-26 20:20] [ALPM] upgraded npth (1.3-1 -> 1.4-1) [2017-05-26 20:20] [ALPM] upgraded qt5-declarative (5.8.0-1 -> 5.8.0-2) [2017-05-26 20:20] [ALPM] upgraded firefox-kde (53.0.2-1 -> 53.0.3-1) [2017-05-26 20:20] [ALPM] upgraded firefox-kde-i18n-de (53.0.2-1 -> 53.0.3-1) [2017-05-26 20:20] [ALPM] upgraded kdenlive (17.04.1-1 -> 17.04.1-1.1) [2017-05-26 20:20] [ALPM] upgraded lib32-libdrm (2.4.79-1 -> 2.4.80-1) [2017-05-26 20:20] [ALPM] installed lib32-lm_sensors (3.4.0-1) [2017-05-26 20:20] [ALPM] upgraded lib32-mesa (17.0.6-1 -> 17.1.0-1) [2017-05-26 20:20] [ALPM] upgraded libatomic_ops (7.4.4-1 -> 7.4.6-1) [2017-05-26 20:20] [ALPM] upgraded linux-firmware (20170309.695f2d6-1 -> 20170422.ade8332-1) [2017-05-26 20:20] [ALPM] upgraded linux49 (4.9.28-1 -> 4.9.29-1) [2017-05-26 20:20] [ALPM-SCRIPTLET] >>> Updating module dependencies. Please wait ... [2017-05-26 20:20] [ALPM] upgraded linux49-bbswitch (0.8-23 -> 0.8-24) [2017-05-26 20:20] [ALPM] upgraded linux49-r8168 (8.044.02-3 -> 8.044.02-4) [2017-05-26 20:20] [ALPM] upgraded manjaro-hotfixes (2015.12-2 -> 2015.12-3) [2017-05-26 20:20] [ALPM] upgraded protobuf (3.2.1-1 -> 3.3.1-1) [2017-05-26 20:20] [ALPM] upgraded python2-cairo (1.10.0-2 -> 1.13.1-1) [2017-05-26 20:20] [ALPM] upgraded qca-qt5 (2.1.3-3 -> 2.1.3-4) [2017-05-26 20:21] [ALPM] upgraded qt5-webengine (5.8.0-8 -> 5.8.0-9) [2017-05-26 20:21] [ALPM] upgraded sane (1.0.25-2 -> 1.0.27-1) [2017-05-26 20:21] [ALPM] upgraded xfsprogs (4.10.0-1 -> 4.11.0-1) [2017-05-26 20:21] [ALPM] transaction completed [2017-05-26 20:21] [ALPM] running '90-linux49.hook'... [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'default' [2017-05-26 20:21] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64.img [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Starting build: 4.9.29-1-MANJARO [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [base] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [udev] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [autodetect] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [modconf] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [block] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [keyboard] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [keymap] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [resume] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [filesystems] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [fsck] [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Generating module dependencies [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64.img [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Image generation successful [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'fallback' [2017-05-26 20:21] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64-fallback.img -S autodetect [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Starting build: 4.9.29-1-MANJARO [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [base] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [udev] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [modconf] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [block] [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [keyboard] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [keymap] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [resume] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [filesystems] [2017-05-26 20:21] [ALPM-SCRIPTLET] -> Running build hook: [fsck] [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Generating module dependencies [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64-fallback.img [2017-05-26 20:21] [ALPM-SCRIPTLET] ==> Image generation successful [2017-05-26 20:21] [ALPM] running '99-grub.hook'... [2017-05-26 20:21] [ALPM-SCRIPTLET] GRUB-Konfigurationsdatei wird erstellt … [2017-05-26 20:21] [ALPM-SCRIPTLET] Hintergrund gefunden: /usr/share/grub/background.png [2017-05-26 20:21] [ALPM-SCRIPTLET] Found Intel Microcode image [2017-05-26 20:21] [ALPM-SCRIPTLET] Linux-Abbild gefunden: /boot/vmlinuz-4.9-x86_64 [2017-05-26 20:21] [ALPM-SCRIPTLET] initrd-Abbild gefunden: /boot/initramfs-4.9-x86_64.img [2017-05-26 20:21] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.9-x86_64-fallback.img [2017-05-26 20:21] [ALPM-SCRIPTLET] WARNING: Failed to connect to lvmetad. Falling back to device scanning. [2017-05-26 20:21] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin [2017-05-26 20:21] [ALPM-SCRIPTLET] erledigt [2017-05-26 20:21] [ALPM] running 'fontconfig.hook'... [2017-05-26 20:21] [ALPM] running 'gtk-update-icon-cache.hook'... [2017-05-26 20:21] [ALPM] running 'update-desktop-database.hook'... [2017-05-26 20:21] [ALPM] running 'update-mime-database.hook'... [2017-05-26 20:21] [ALPM-SCRIPTLET] Unknown media type in type 'all/all' [2017-05-26 20:21] [ALPM-SCRIPTLET] Unknown media type in type 'all/allfiles' [2017-05-26 20:21] [ALPM] running 'xorg-mkfontdir.hook'...
and this the log after switching to unstable:
[2017-05-26 22:50] [PACMAN] Running 'pacman -Syyu' [2017-05-26 22:50] [PACMAN] synchronizing package lists [2017-05-26 22:50] [PACMAN] starting full system upgrade [2017-05-26 22:51] [ALPM] transaction started [2017-05-26 22:51] [ALPM] upgraded confuse (3.0-1 -> 3.1-1) [2017-05-26 22:51] [ALPM] upgraded libdrm (2.4.80-1 -> 2.4.81-1) [2017-05-26 22:51] [ALPM] upgraded lib32-libdrm (2.4.80-1 -> 2.4.81-1) [2017-05-26 22:51] [ALPM] upgraded llvm-libs (4.0.0-2 -> 4.0.0-3) [2017-05-26 22:51] [ALPM] upgraded mesa (17.1.0-1 -> 17.1.1-0) [2017-05-26 22:51] [ALPM] upgraded lib32-mesa (17.1.0-1 -> 17.1.1-0) [2017-05-26 22:51] [ALPM] upgraded openssl (1.1.0.e-1 -> 1.1.0.f-1) [2017-05-26 22:51] [ALPM] upgraded libftdi (1.3-3 -> 1.3-4) [2017-05-26 22:51] [ALPM] upgraded libwbclient (4.5.8-1 -> 4.5.10-0) [2017-05-26 22:52] [ALPM] upgraded linux49 (4.9.29-1 -> 4.9.30-1) [2017-05-26 22:52] [ALPM-SCRIPTLET] >>> Updating module dependencies. Please wait ... [2017-05-26 22:52] [ALPM] upgraded linux49-bbswitch (0.8-24 -> 0.8-25) [2017-05-26 22:52] [ALPM] upgraded linux49-r8168 (8.044.02-4 -> 8.044.02-5) [2017-05-26 22:52] [ALPM] upgraded openssl-1.0 (1.0.2.k-4 -> 1.0.2.l-1) [2017-05-26 22:52] [ALPM] upgraded opus (1.1.4-1 -> 1.1.5-1) [2017-05-26 22:52] [ALPM] upgraded pango (1.40.6+6+g6f59d0f3-2 -> 1.40.6+9+g92cc73c8-1) [2017-05-26 22:52] [ALPM] upgraded qt5-base-nosystemd (5.8.0-3 -> 5.8.0-4) [2017-05-26 22:52] [ALPM] upgraded smbclient (4.5.8-1 -> 4.5.10-0) [2017-05-26 22:52] [ALPM] transaction completed [2017-05-26 22:52] [ALPM] running '90-linux49.hook'... [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'default' [2017-05-26 22:52] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64.img [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Starting build: 4.9.30-1-MANJARO [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [base] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [udev] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [autodetect] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [modconf] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [block] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [keyboard] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [keymap] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [resume] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [filesystems] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [fsck] [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Generating module dependencies [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64.img [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Image generation successful [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux49.preset: 'fallback' [2017-05-26 22:52] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.9-x86_64-fallback.img -S autodetect [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Starting build: 4.9.30-1-MANJARO [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [base] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [udev] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [modconf] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [block] [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [keyboard] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [keymap] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [resume] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [filesystems] [2017-05-26 22:52] [ALPM-SCRIPTLET] -> Running build hook: [fsck] [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Generating module dependencies [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.9-x86_64-fallback.img [2017-05-26 22:52] [ALPM-SCRIPTLET] ==> Image generation successful [2017-05-26 22:52] [ALPM] running '99-grub.hook'... [2017-05-26 22:52] [ALPM-SCRIPTLET] GRUB-Konfigurationsdatei wird erstellt … [2017-05-26 22:52] [ALPM-SCRIPTLET] Hintergrund gefunden: /usr/share/grub/background.png [2017-05-26 22:52] [ALPM-SCRIPTLET] Found Intel Microcode image [2017-05-26 22:52] [ALPM-SCRIPTLET] Linux-Abbild gefunden: /boot/vmlinuz-4.9-x86_64 [2017-05-26 22:52] [ALPM-SCRIPTLET] initrd-Abbild gefunden: /boot/initramfs-4.9-x86_64.img [2017-05-26 22:52] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.9-x86_64-fallback.img [2017-05-26 22:52] [ALPM-SCRIPTLET] WARNING: Failed to connect to lvmetad. Falling back to device scanning. [2017-05-26 22:52] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin [2017-05-26 22:52] [ALPM-SCRIPTLET] erledigt
I guess qt5-base-nosystemd update should go in testing too.
The packages, which are updatet twice are:
and
and
Maybe there is a correlation.
And … thank you very very much for your great help :slight_smile:
