Trying to run KRUSADER fom terminal:
Success - but output in termina:
pkexec krusader
kf.i18n: KLocalizedString: Using an empty domain, fix the code. msgid: "No jobs" msgid_plural: "" msgctxt: ""
10:41:17.855-warning default unknown@0 # QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
10:41:17.882-warning default unknown@0 # QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
10:41:17.964-debug default unknown@0 # System icon theme: "oxygen"
Cannot connect to the D-BUS session bus.
To start it, run:
eval `dbus-launch --auto-syntax`
10:41:18.133-warning kf.i18n unknown@0 # Trying to convert empty KLocalizedString to QString.
DBus Error: org.freedesktop.DBus.Error.Disconnected, Not connected to D-Bus server
This particular warning is perfectly normal, nothing to worry about. It’s just saying that you haven’t customized the location of the runtime dir, so it’s using the default.
