Hi,
i recently noticed that my network connection is very slow (sometimes it drops down to 5 mbit/s). I am connected via LAN. A reboot or waiting for 5-10 mins usually fixes it but it’s still annoying… Hope you can help
System information:
Kernel: 5.15.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=0b4fea78-6afe-4423-a0a6-10fd7db1e52f rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 2 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: H410M PRO (MS-7C89) v: 1.1
serial: <superuser required> UEFI: American Megatrends v: F.20
date: 06/10/2020
RAM: total: 15.56 GiB used: 5.51 GiB (35.4%)
RAM Report:
Info: model: Intel Core i7-10700F bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEE
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2900 min/max: 800/4800 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 2900 2: 2900 3: 2900 4: 2900 5: 2900 6: 2900
7: 2900 8: 2900 9: 2900 10: 2900 11: 2900 12: 2900 13: 2900 14: 2900
15: 2900 16: 2900 bogomips: 92838
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht
ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 510.68.02 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
Device-2: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5.3.1:6 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-0 res: 3440x1440 dpi: 107 size: 819x346mm (32.24x13.62")
diag: 889mm (35") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Sunplus Innovation FHD Camera Microphone type: USB
Device-4: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3.2:7
chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.15.38-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-7:3
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.97 TiB used: 1.1 TiB (37.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 41.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21111000 temp: 35.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-22MFCA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Apple model: HDD HTS547575A9E384
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: D70F scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 52.43 GiB (11.2%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: N/A uuid: 0b4fea78-6afe-4423-a0a6-10fd7db1e52f
ID-2: /Data/Data raw-size: 909.11 GiB size: 909.11 GiB (100.00%)
used: 385.99 GiB (42.5%) fs: ntfs dev: /dev/sda1 maj-min: 8:1 label: Data
uuid: 78BA6D2EBA6CE9D8
ID-3: /Data/FotoBackUp raw-size: 698.44 GiB size: 698.44 GiB (100.00%)
used: 476.51 GiB (68.2%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: FotoBackUp uuid: 8E8CFBE28CFBC2AF
ID-4: /Data/Windows raw-size: 930.51 GiB size: 930.51 GiB (100.00%)
used: 208.28 GiB (22.4%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:6
label: Windows uuid: 94AC6989AC696728
ID-5: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
label: NO_LABEL uuid: A28E-FE3E
ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 100 MiB fs: vfat label: SYSTEM
uuid: B669-1AEB
ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 800 MiB fs: ntfs label: N/A
uuid: 34BA3C23BA3BE052
ID-4: /dev/sda2 maj-min: 8:2 size: 22.38 GiB fs: ntfs label: BIOS_RVY
uuid: B6DA6ED5DA6E9203
ID-5: /dev/sdb1 maj-min: 8:17 size: 200 MiB fs: vfat label: EFI
uuid: 2860-11F4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 1-5.3:4 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-5.3.1:6 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Device-2: 1-5.3.2:7 info: C-Media USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0012 class-ID: 0300
Device-3: 1-5.3.3:8 info: Logitech Corded Keyboard K280e
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c328 class-ID: 0300
Device-4: 1-5.3.4:9 info: Logitech G502 SE HERO Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-5: 1-7:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-6: 1-8:5 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c89 class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 47%
Processes: 380 Uptime: 10h 6m wakeups: 0 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1472
pacman: 1455 lib: 463 flatpak: 9 snap: 8 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.16
