Xbox 360 Controller Driver Fix
Sorry If This Is A Duplicate Thread.
Hello Iam New To Arch Based Linux, Iam Currently Using Manjaro Gnome Nibia.
The Problem Is
When I plugin My Wireless Controller’s Dongle It Shows As “ShanWan PC/PS3/Android”,
Is There Any Way To Replace This Driver With Xbox 360 Driver For Better Pc Game Compatibility?
Thankyou.:slightly_smiling_face:
Have you read this this post, it states that the 360 controller should be supported.
https://wiki.archlinux.org/index.php/Gamepad#Xbox_360_controller
The ‘ShanWan PC/PS3/Android’ could mean that you are not using the controller that you think you are using, :point_down: could be a good starting point to find out how to get it to work.
https://bbs.archlinux.org/viewtopic.php?id=235395
p.s. if you get it to work please post the solution here, other searchers will thank you later :slight_smile:
Thank You For Your Response, But My Controller Is not Bluetooth One It Uses A Seperate Wifi Dongle To Get Connected With My Laptop… :innocent:
