Xanmod custom Kernel - lightdm failed to start
Hallo!
Ich habe mir mal an einen custom Kernel gewagt und zwar XanMod.
Das Compilieren war soweit erfolgreich, nur wenn ich diesen starte bekomme ich eine Fehler-Meldung:
sudo inxi -Fxxxa
System:    Host: Bolobi Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=0a99b40e-fa5e-42a6-af9f-ff2e3a9ed8ce rw quiet
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: F2A55-M LK2 v: Rev X.0x serial: 131017451901936 UEFI: American Megatrends
           v: 6308 date: 11/25/2014
CPU:       Topology: Quad Core model: AMD A8-5600K APU with Radeon HD Graphics bits: 64 type: MCP arch: Piledriver
           family: 15 (21) model-id: 10 (16) stepping: 1 microcode: 6001119 L1 cache: 192 KiB L2 cache: 2048 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 28954
           Speed: 1404 MHz min/max: 1400/3600 MHz boost: enabled Core speeds (MHz): 1: 1406 2: 1403 3: 1407 4: 1406
           Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics:  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ZOTAC driver: nvidia v: 440.100 bus ID: 01:00.0
           chip ID: 10de:1c82
           Display: server: X.Org 1.20.8 driver: nvidia resolution: 1280x1024~60Hz, 1920x1200~60Hz
           OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 440.100 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD] FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:14.2 chip ID: 1022:780d
           Device-2: NVIDIA GP107GL High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus ID: 01:00.1
           chip ID: 10de:0fb9
           Sound Server: ALSA v: k5.7.9-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series driver: r8169
           v: kernel port: d000 bus ID: 04:00.0 chip ID: 10ec:8168
           IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: bc:ee:7b:5b:d3:d0
Drives:    Local Storage: total: 5.68 TiB used: 3.30 TiB (58.1%)
           ID-1: /dev/sda vendor: Apacer model: AS350 240GB size: 223.57 GiB block size: physical: 512 B logical: 512 B
           speed: 3.0 Gb/s serial: 519307031A5D00021605 rev: 3PE0 scheme: GPT
           ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: WD-WCC6Y7UKE59A rev: 1A01 scheme: GPT
           ID-3: /dev/sdc vendor: Toshiba model: DT01ACA100 size: 931.51 GiB block size: physical: 4096 B logical: 512 B
           speed: 3.0 Gb/s rotation: 7200 rpm serial: X3VMGS6NS rev: A750 scheme: GPT
           ID-4: /dev/sdd vendor: Western Digital model: WD40EZRZ-00GXCB0 size: 3.64 TiB block size: physical: 4096 B
           logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: WD-WCC7K7KH3VV5 rev: 0A80 scheme: GPT
RAID:      Supported md-raid types: raid0
           Device-1: md0 type: mdraid status: active Components: online: sdc1~c1 sdb1~c0
           Info: raid: raid-0 blocks: 1950087168 report: N/A chunk size: 512k super blocks: 1.2
Partition: ID-1: / raw size: 223.27 GiB size: 218.77 GiB (97.98%) used: 23.50 GiB (10.7%) fs: ext4 block size: 4096 B
           dev: /dev/sda2
           ID-2: /home raw size: 1.82 TiB size: 1.79 TiB (98.38%) used: 1.20 TiB (67.1%) fs: ext4 block size: 4096 B
           dev: /dev/md0
Sensors:   System Temperatures: cpu: 38.0 C mobo: 37.0 C gpu: nvidia temp: 38 C
           Fan Speeds (RPM): cpu: 0 fan-1: 1106 gpu: nvidia fan: 49%
           Voltages: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.29
Info:      Processes: 200 Uptime: 8m Memory: 7.80 GiB used: 1.86 GiB (23.9%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Shell: zsh (sudo) v: 5.8 running in: xfce4-terminal inxi: 3.0.37
Xorg.0.log.old
[   137.331] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[   137.333]
X.Org X Server 1.20.8
[   137.336] Build Operating System: Linux Manjaro Linux
[   137.337] Current Operating System: Linux Bolobi 5.7.11-xanmod1-1-xanmod #1 SMP PREEMPT Fri, 31 Jul 2020 02:53:11 +0000 x86_64
[   137.337] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux-xanmod root=UUID=0a99b40e-fa5e-42a6-af9f-ff2e3a9ed8ce rw quiet apparmor=1 security=apparmor udev.log_priority=3
[   137.341] Build Date: 03 June 2020  10:02:55AM
[   137.342]
[   137.343] Current version of pixman: 0.40.0
[   137.345] 	Before reporting problems, check http://wiki.x.org
[   137.345] Markers: (--) probed, (**) from config file, (==) default setting,
[   137.349] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Jul 31 19:45:35 2020
[   137.350] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   137.351] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   137.352] (==) ServerLayout "layout"
[   137.352] (**) |-->Screen "Screen0" (0)
[   137.352] (**) |   |-->Monitor "Monitor0"
[   137.352] (**) |   |-->Device "Device0"
[   137.352] (==) Automatically adding devices
[   137.352] (==) Automatically enabling devices
[   137.352] (==) Automatically adding GPU devices
[   137.352] (==) Automatically binding GPU devices
[   137.352] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   137.352] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   137.352] 	Entry deleted from font path.
[   137.352] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[   137.352] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[   137.352] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[   137.352] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[   137.352] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF,
	/usr/share/fonts/OTF
[   137.352] (==) ModulePath set to "/usr/lib/xorg/modules"
[   137.352] (**) Extension "COMPOSITE" is enabled
[   137.352] (II) The server relies on udev to provide the list of input devices.
[   137.352] (II) Module ABI versions:
[   137.352] 	X.Org ANSI C Emulation: 0.4
[   137.352] 	X.Org Video Driver: 24.1
[   137.352] 	X.Org XInput driver : 24.1
[   137.352] 	X.Org Server Extension : 10.0
[   137.353] (++) using VT number 3
[   137.354] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[   137.357] (--) PCI:*(1@0:0:0) 10de:1c82:19da:1454 rev 161, Mem @ 0xfd000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[   137.357] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   137.357] (II) LoadModule: "glx"
[   137.357] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   137.358] (II) Module glx: vendor="X.Org Foundation"
[   137.358] 	compiled for 1.20.8, module version = 1.0.0
[   137.358] 	ABI class: X.Org Server Extension, version 10.0
[   137.358] (II) LoadModule: "nvidia"
[   137.359] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   137.359] (II) Module nvidia: vendor="NVIDIA Corporation"
[   137.359] 	compiled for 1.6.99.901, module version = 1.0.0
[   137.359] 	Module class: X.Org Video Driver
[   137.359] (II) NVIDIA dlloader X Driver  440.100  Fri May 29 08:21:27 UTC 2020
[   137.359] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   137.359] (II) Loading sub module "fb"
[   137.359] (II) LoadModule: "fb"
[   137.359] (II) Loading /usr/lib/xorg/modules/libfb.so
[   137.359] (II) Module fb: vendor="X.Org Foundation"
[   137.359] 	compiled for 1.20.8, module version = 1.0.0
[   137.359] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   137.359] (II) Loading sub module "wfb"
[   137.359] (II) LoadModule: "wfb"
[   137.359] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   137.359] (II) Module wfb: vendor="X.Org Foundation"
[   137.360] (II) Loading sub module "ramdac"
[   137.360] (II) LoadModule: "ramdac"
[   137.360] (II) Module "ramdac" already built-in
[   137.362] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[   137.362] (EE) NVIDIA:     system's kernel log for additional error messages and
[   137.362] (EE) NVIDIA:     consult the NVIDIA README for details.
[   137.362] (EE) No devices detected.
[   137.362] (EE)
Fatal server error:
[   137.362] (EE) no screens found(EE)
[   137.362] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[   137.362] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   137.362] (EE)
[   137.364] (EE) Server terminated with error (1). Closing log file.
journalctl --grep=lightdm
-- Logs begin at Tue 2020-07-14 21:42:15 CEST, end at Fri 2020-07-31 23:32:47 CEST. --
Jul 31 23:31:48 Bolobi audit[917]: USER_LOGOUT pid=917 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=Bolobi addr=? terminal=/dev/tty7 res=success'
Jul 31 23:31:48 Bolobi kernel: audit: type=1113 audit(1596231108.600:476): pid=917 uid=0 auid=1000 ses=2 subj==unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=Bolobi addr=? terminal=/dev/tty7 res=success'
Jul 31 23:31:48 Bolobi lightdm[917]: pam_unix(lightdm:session): session closed for user henuk
Jul 31 23:31:48 Bolobi audit[917]: USER_END pid=917 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env,pam_gnome_keyring acct="henuk" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 31 23:31:48 Bolobi audit[917]: CRED_DISP pid=917 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyring acct="henuk" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Jul 31 23:31:48 Bolobi systemd[1]: lightdm.service: Succeeded.
Jul 31 23:31:48 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
Jul 31 23:31:49 Bolobi dbus-daemon[656]: [system] Activating via systemd: service name='org.freedesktop.login1' unit='dbus-org.freedesktop.login1.service' requested by ':1.16' (uid=0 pid=694 comm="/usr/bin/lightdm ")
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
Jul 31 23:31:50 Bolobi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:50 Bolobi dbus-daemon[656]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service' requested by ':1.16' (uid=0 pid=694 comm="/usr/bin/lightdm ")
-- Reboot --
-- Reboot --
-- Reboot --
-- Reboot --
Jul 31 23:31:50 Bolobi systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Jul 31 23:31:50 Bolobi systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jul 31 23:31:50 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jul 31 23:31:50 Bolobi systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 1.
Jul 31 23:31:50 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:51 Bolobi systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 2.
Jul 31 23:31:51 Bolobi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:51 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:51 Bolobi systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE
Jul 31 23:31:51 Bolobi systemd[1]: lightdm.service: Failed with result 'exit-code'.
Jul 31 23:31:51 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jul 31 23:31:51 Bolobi systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 3.
Jul 31 23:31:51 Bolobi systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 4.
Jul 31 23:31:52 Bolobi systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
Jul 31 23:31:52 Bolobi audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:52 Bolobi audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 31 23:31:52 Bolobi systemd[1]: lightdm.service: Start request repeated too quickly.
Jul 31 23:31:52 Bolobi systemd[1]: lightdm.service: Failed with result 'exit-code'.
[   137.362] (EE)
Fatal server error:
Gut also liegt das Problem am NVIDIA Modul. Dachte das lässt sich mit mkinitcpio -P beheben, aber scheint wohl auch fehlerhaft zu sein:
==> Building image from preset: /etc/mkinitcpio.d/linux-xanmod.preset: 'default'
  -> -k /boot/vmlinuz-linux-xanmod -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-xanmod.img
==> Starting build: 5.7.11-xanmod1-1-xanmod
  -> Running build hook: [base]
  -> Running build hook: [udev]
  -> Running build hook: [lvm2]
cp: der Aufruf von stat für '(builtin)' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux-xanmod.img
==> WARNING: errors were encountered during the build. The image may not be complete.
==> Building image from preset: /etc/mkinitcpio.d/linux-xanmod.preset: 'fallback'
  -> -k /boot/vmlinuz-linux-xanmod -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-xanmod-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux-xanmod-fallback.img
Nun frag ich mich, da ich im Forum und anderswo schon gesucht habe, wie man den Nvidia Treiber einbinden könnte? Ein Hinweis in würde reichen :slight_smile: Danke.
Such nach nvidia-dkms. Das Paket gibt es nicht in Manjaro. Aber im Prinzip brauchst du so was. Das Nvidia Modul muss für jeden Kernel gebaut werden und muss genau zu dem Nvidia Utilities Paket/Version passen.
Du kannst also nicht die bereits kompilierten Nvidia Module für die Manjaro Kernel nehmen. Da es zu dem Nvidia Utilities Paket passen musst kannst du vielleicht auch das Arch nvidia-dkms Paket nicht direkt verwenden.
Manjaro macht es Benutzern mit Nvidia Karten die den proprietären Treiber verwenden wollen extrem schwierig alternative Kernel zu benutzen.
Zur Not musst du es halt manuell machen.
Danke! Also bräuchte ich nvidia-dkms.
Tatsache pamac findet das Paket nicht:
pamac search nvidia dkms        ~
nvidia-vulkan-dkms        450.56.02-1       AUR
    NVIDIA driver sources for linux (vulkan developer branch)
nvidia-llb-dkms        375.66-2          AUR
    NVIDIA kernel module sources (DKMS) - long lived branch
nvidia-bl-dkms        18.11.0-2         AUR
    Driver to adjust display backlight on legacy mobile NVidia graphics adapters - DKMS edition.
nvidia-beta-dkms        450.57-2          AUR
    NVIDIA driver sources for linux (beta version)
nvidia-390xx-dkms        390.138-3         AUR
    NVIDIA driver sources for linux, 390xx legacy branch
nvidia-340xx-lts-dkms        340.108-2         AUR
    NVIDIA driver sources for linux-lts, 340xx legacy branch
nvidia-340xx-dkms        340.108-8         AUR
    NVIDIA driver sources for linux, 340xx legacy branch
nvhda-dkms-git        r10.3e13d2e-1     AUR
    Kernel driver to dynamically enable/disable NVIDIA HDMI audio output in optimus laptops
bbswitch-ati-dkms-git        0.8.5.gddbd243-1  AUR
    kernel module allowing to switch also AMD integrated and Nvidia dedicated graphics card on Optimus
    laptops (Git version)
Aber wenn ich zb. nvidia-beta-dkms mit pamac installieren will, dann wird die aktuelle nvidia-440xx-utils ersetzt. Ich müsste also diese Paket samt Abhängigkeiten entfernen. Ich habe leider keine Ahnung was für Folgen das haben kann.
Kann Abhängigkeiten nicht erfüllen:
- das Entfernen von nvidia-440xx-utils verletzt Abhängigkeit von 'nvidia-440xx-utils' benötigt von lib32-nvidia-440xx-utils
nvidia-dkms und nvidia-beta-dkms scheinen wohl eine identische Versionsnummer zu haben: 450.57-2, aber unterschiedliche PKGBUILDs.
Ich bin jetzt echt überfragt in wie weit Manjaro sich dann verhält... hab keine Lust mein System zu zerschießen.
Das ist nichts was du mit einem Befehl installieren kannst. Du müsstest dir ein eigenes nvidia-dkms Paket passend zu deinem aktuell in Manjaro installierten nvidia-utilities Paket bauen.
Es war nur der Hinweis was du theoretisch brauchen würdest. Die praktische Umsetzung ist aufwendiger.
Als Alternative könntest du dir auch mal den PKGBUILD von Paketen wie linux57-nvidia anschauen und ein für dich passendes Paket bauen.
Am Ende brauchst du für deinen Kernel kompilierte Nvidia Module. Wie du die baust und installierst ist egal.
Mit einer AMD Grafikkarte ist das Leben in so einem Fall einfacher.
Ich baue mir auch einen eigenen kernel (liquorix) und ich mache das so, das ich die extra module von manjaro ebenfalls kompilieren.
Und so gehts bei mir:
  1. herunterladen (git clone) der entsprechenden extramodules die du brauchst von Manjaro. Für kernel 5.7 ist das hier: https://gitlab.manjaro.org/packages/extra/linux57-extramodules
    Die PKGBUILD dateien müssen entsprechend angepasst werden.
    EDIT: bsp. musst du den paket namen ändern damit es nicht zu konflikten kommt mit den original Manjaro Paketen. Ich hänge bei meinen Paketen immer ein -mbo an
  2. kernel kompilieren und installieren. Nicht rebooten. Es fehlen noch die ganzen extramodules.
  3. In /lib/modules muss das entsprechende extramodules verzeichnis anlegt und verlinkt werden. Außerdem braucht man in dem extramodule Verzeichnis die entsprechende "version" Datei des neuen kernels.
Für meinen liquorix kernel 5.7.12-lqx1-17-lqx-mbo sieht das so aus:
cd /lib/modules/
mkdir extramodules-lqx-mbo
cd 5.7.12-lqx1-17-lqx-mbo
ln -s ../extramodules-lqx-mbo extramodules
cp build/version extramodules
  1. Jetzt kann man mit makepkg die einzelnen extra module komlilieren, packetieren und installieren.
Bei mir funktioniert das so mit den extra modulen von nvidia-440x, zfs und virtualbox.
Viel Spaß!
Hier gibt es die selben Probleme?! und Lösung?!
linux-xanmod#comment-756374
FS#65725 - [mkinitcpio] cp: cannot stat '(builtin)': No such file or directory
Ich habe nun auch mit xanmod experimentiert. Leider ist der kernel bei mir nicht stabil sobald der PC unter hoher Last ist. Es kommt teilweise zum kompletten freeze. Ich habe dazu auch ein issue in xanmod github aufgemacht:
https://github.com/xanmod/linux/issues/73
Demzufolge kann ich den xanmod kernel auf keinen Fall empfehlen.
Auf der anderen Seite habe ich bis jetzt sehr gute Erfahrungen mit dem liquorix kernel gemacht. Keine Problem unter hoher Last oder ähnliches.
Gut Danke für den Hinweis @mbod und danke an @Lila-Kuh und @xabbu :bowing_man:
Ich werde es erst mal ruhen lassen. Erscheint mir doch ein wenig zu viele Mehraufwand zu sein für ein bisschen mehr Performance. Hab jetzt auch andere Projekte wieder am Laufen. Betrachtet den Post als geschlossen :slight_smile:
