I have a new lenovo x1 carbon 9th generation.
Tthe inxi -Fx is at the bottom of this post.
The problem is with thermal throttling. When I run s-tui stress
test the system works fine for about a minute, with temps just
below 100C.
Suddenly, the cpu frequency drops to 400 (all cores) then slowly
returns to 2400 and temp stabilizes at about 60C.
Obviously, I want the system to run as fast as possible at up to 100C.
The i7-1165G7 has been locked by intel apparently to it is impossible
to change voltages etc.
But one would hope that the cpu could run at a safe (100C) maximum.
As it stands, my new x1 is slower than my old x1 6th generation that
happily runs at 3300 Mhz forever (thanks to lenovo_fix).
Is there any hope for the x1 9th generation, or is it just a dog?
System: Host: elrond Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Console: tty pts/3
Machine: Type: Laptop System: LENOVO product: 20XW003GUS v: ThinkPad X1 Carbon Gen 9 serial: PF2PLH7L
Mobo: LENOVO model: 20XW003GUS v: SDK0J40697 WIN serial: L2HF13405ZG UEFI: LENOVO v: N32ET47W (1.23 )
date: 03/26/2021
Battery: ID-1: BAT0 charge: 41.7 Wh (72.4%) condition: 57.6/57.0 Wh (101.1%) volts: 16.5 min: 15.4
model: Celxpert 5B10W13974 status: Unknown
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP arch: Tiger Lake rev: 1 cache:
L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44864
Speed: 400 MHz max: 400 MHz Core speeds (MHz): 1: 400 2: 884 3: 964 4: 400 5: 915 6: 886 7: 974 8: 864
X11 connection rejected because of wrong authentication.
Graphics: Device-1: Intel Iris Xe Graphics vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-4:3
Display: server: X.org 1.20.10 driver: loaded: intel unloaded: modesetting
Message: Advanced graphics data unavailable for root.
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo driver: sof-audio-pci bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000 bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: 84:5c:f3:ea:e9:08
Bluetooth: Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
Drives: Local Storage: total: 953.87 GiB used: 328.41 GiB (34.4%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: N/A size: 953.87 GiB temp: 32.9 C
Partition: ID-1: / size: 865.96 GiB used: 328.41 GiB (37.9%) fs: ext4 dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 499 MiB used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6
Swap: ID-1: swap-1 type: partition size: 7.32 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p5
Sensors: System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5454
Info: Processes: 229 Uptime: 23h 26m Memory: 15.36 GiB used: 3.67 GiB (23.9%) Init: systemd Compilers: gcc: 10.2.0
Packages: 1288 Shell: Bash v: 5.1.0 inxi: 3.3.03
