Gt 710 with nouveau
Manjaro Xfce fully update
kernel 5.4 and 5.9
basicaly in 50% of the cases it fails to start X, even startx from console fails
this is a clean install, nvidia proprietary drivers have never been installed, no hardware change (already said it’s a clean install)
Xorg.0.log doesn’t really say much when it fails
[ 5.290] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 5.291] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 5.291] (EE) open /dev/dri/card0: No such file or directory
[ 5.291] (WW) Falling back to old probe method for modesetting
[ 5.291] (EE) Screen 0 deleted because of no matching config section.
[ 5.291] (II) UnloadModule: "modesetting"
[ 5.291] (EE) Device(s) detected, but none match those in the config file.
[ 5.291] (EE)
Fatal server error:
[ 5.291] (EE) no screens found(EE)
[ 5.291] (EE)
this is what I see when it fails.
full log: Xorg.0.log - Pastebin.com
dmesg between when it starts and when it fails has only a minor difference (this log is from when in works, DRM loaded at 5,0, X ended up at the DRM part at 5,6 so no issues):
[ 3.526547] fb0: switching to nouveaufb from VESA VGA
[ 3.534662] nouveau 0000:01:00.0: NVIDIA GK208B (b060b0b1)
[ 3.818711] nouveau 0000:01:00.0: bios: version 80.28.b8.00.6d
[ 3.819225] nouveau 0000:01:00.0: fb: 2048 MiB GDDR5
[ 5.009272] nouveau 0000:01:00.0: DRM: VRAM: 2048 MiB
[ 5.009273] nouveau 0000:01:00.0: DRM: GART: 1048576 MiB
[ 5.009275] nouveau 0000:01:00.0: DRM: TMDS table version 2.0
[ 5.009276] nouveau 0000:01:00.0: DRM: DCB version 4.0
[ 5.009278] nouveau 0000:01:00.0: DRM: DCB outp 00: 01000f02 00020030
[ 5.009279] nouveau 0000:01:00.0: DRM: DCB outp 01: 02011f62 00020010
[ 5.009279] nouveau 0000:01:00.0: DRM: DCB outp 02: 02000f00 00000000
[ 5.009281] nouveau 0000:01:00.0: DRM: DCB conn 00: 00001030
[ 5.009281] nouveau 0000:01:00.0: DRM: DCB conn 01: 00002161
[ 5.009575] nouveau 0000:01:00.0: DRM: MM: using COPY for buffer copies
[ 5.280352] nouveau 0000:01:00.0: DRM: allocated 1920x1080 fb: 0x80000, bo 00000000e94edf95
[ 5.280990] fbcon: nouveaudrmfb (fb0) is primary device
[ 5.280993] nouveau 0000:01:00.0: fb0: nouveaudrmfb frame buffer device
[ 5.296982] [drm] Initialized nouveau 1.3.1 20120801 for 0000:01:00.0 on minor 0
the part that you see here at 5.00 it’s at 5.70+ when it fails. Compared to my other machine with a GT 1030 the DRM part is considerable slower, on the GT 1030 there is no 1,5-2 seconds delay, it basicaly follows in under 0,2s
lspci -knn (it’s the same in both cases, when it works and when it fails)
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GK208B [GeForce GT 710] [10de:128b] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:375a]
Kernel driver in use: nouveau
Kernel modules: nouveau
I kinda understand that it fails because the DRM part is not really loaded when X tries to start. What I don’t understand is why it takes so long…
I can wait as much as I want it will still be a nice blackscreen. Droping to console and trying to start X result in a failure. Only thing changed in the Xorg.0.log is
parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
DRM part is already loaded in dmesg.
Any suggestion on how to speed up the DRM part that is lagging?
Alternative how do I add a delay before X starts? Hopefully the DRM part will be loaded by then…
