I recently replaced Ubuntu with Manjaro on my Dell Precision 5520. I’ve since seen it crash a couple times with a signal 6 (abort). I believe I am running X.org 1.20.9-2. The backtrace in /var/log/Xorg.0.log.old looks like this:
[ 4.808] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x53) [0x5643ff188c03]
[ 4.808] (EE) 1: /usr/lib/Xorg (0x5643ff042000+0x151a45) [0x5643ff193a45]
[ 4.808] (EE) 2: /usr/lib/libc.so.6 (0x7f208e74b000+0x3d6a0) [0x7f208e7886a0]
[ 4.808] (EE) 3: /usr/lib/libc.so.6 (gsignal+0x145) [0x7f208e788615]
[ 4.808] (EE) 4: /usr/lib/libc.so.6 (abort+0x116) [0x7f208e771862]
[ 4.808] (EE) 5: /usr/lib/libc.so.6 (0x7f208e74b000+0x26747) [0x7f208e771747]
[ 4.808] (EE) 6: /usr/lib/libc.so.6 (0x7f208e74b000+0x35bf6) [0x7f208e780bf6]
[ 4.808] (EE) 7: /usr/lib/Xorg (dixRegisterPrivateKey+0x0) [0x5643ff0d7930]
[ 4.808] (EE) 8: /usr/lib/xorg/modules/libglamoregl.so (glamor_init+0xc9) [0x7f2088458fb9]
[ 4.808] (EE) 9: /usr/lib/xorg/modules/drivers/modesetting_drv.so (0x7f20885c2000+0x1404d) [0x7f20885d604d]
[ 4.808] (EE) 10: /usr/lib/Xorg (AddGPUScreen+0x10e) [0x5643ff0bb40e]
[ 4.808] (EE) 11: /usr/lib/Xorg (0x5643ff042000+0x185819) [0x5643ff1c7819]
[ 4.808] (EE) 12: /usr/lib/Xorg (0x5643ff042000+0x1a4520) [0x5643ff1e6520]
[ 4.808] (EE) 13: /usr/lib/Xorg (0x5643ff042000+0x1bae61) [0x5643ff1fce61]
[ 4.808] (EE) 14: /usr/lib/Xorg (0x5643ff042000+0x1bb0cb) [0x5643ff1fd0cb]
[ 4.808] (EE) 15: /usr/lib/Xorg (InitInput+0xf5) [0x5643ff1ad045]
[ 4.808] (EE) 16: /usr/lib/Xorg (0x5643ff042000+0x39768) [0x5643ff07b768]
[ 4.808] (EE) 17: /usr/lib/libc.so.6 (__libc_start_main+0xf2) [0x7f208e773152]
[ 4.808] (EE) 18: /usr/lib/Xorg (_start+0x2e) [0x5643ff07c5ae]
[ 4.808] (EE)
[ 4.808] (EE)
Fatal server error:
[ 4.808] (EE) Caught signal 6 (Aborted). Server aborting
Right after that it says to check wiki.x.org, which I have. That led me nowhere obvious. I thought I read somewhere to include the output of inxi -Fa. I tried to attach it but that failed (looks like upload is only intended for images). So here it is inline.
System: Host: montanaro Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=b1d17947-be57-4080-aff9-0225606850a8
rw quiet apparmor=1 security=apparmor udev.log_priority=3
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0
Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Precision 5520 v: N/A serial: <superuser/root required>
Chassis: type: 10 serial: <superuser/root required>
Mobo: Dell model: 0X41RR v: A00 serial: <superuser/root required> UEFI: Dell v: 1.18.0
date: 11/17/2019
Battery: ID-1: BAT0 charge: 78.7 Wh condition: 82.4/97.0 Wh (85%) volts: 12.6/11.4
model: LGC-LGC3.67 DELL T453X type: Li-ion serial: 30712 status: Charging
CPU: Topology: Quad Core model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake
family: 6 model-id: 9E (158) stepping: 9 microcode: D6 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 46419
Speed: 3670 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 3657 2: 3633 3: 3742 4: 3621
5: 3633 6: 3612 7: 3645 8: 3612
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:591b
Device-2: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Dell driver: nouveau v: kernel
bus ID: 01:00.0 chip ID: 10de:13b6
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:4
chip ID: 0c45:6713
Display: x11 server: X.Org 1.20.9 driver: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.0x11.2") s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 139 size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a171
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: e000 bus ID: 02:00.0 chip ID: 168c:003e
IF: wlp2s0 state: up mac: 28:56:5a:a9:a8:bb
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:3 chip ID: 0cf3:e007
Drives: Local Storage: total: 238.47 GiB used: 66.11 GiB (27.7%)
ID-1: /dev/nvme0n1 model: CX2-8B256-Q11 NVMe LITEON 256GB size: 238.47 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: TW0XVRV7LOH006BS0008
rev: 48811QD scheme: GPT
Partition: ID-1: / raw size: 222.24 GiB size: 217.75 GiB (97.98%) used: 66.07 GiB (30.3%) fs: ext4
dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 15.73 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 34.5 C mobo: N/A gpu: nouveau temp: 28 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 217 Uptime: 6m Memory: 15.37 GiB used: 1.42 GiB (9.2%) Init: systemd v: 246
Compilers: gcc: 10.2.0 Packages: pacman: 1145 lib: 345 flatpak: 0 Shell: Bash v: 5.0.18
running in: xfce4-terminal inxi: 3.1.05
I would appreciate some guidance about how to debug this problem or provide more useful details so others can.
