X-Air-Edit (Remote control and programm Behringer X Air Mixers) - The UI won't respond to mouse-clicks
Hi,
Please, help me find what changes I have to make so this (xairedit 1.5-2) will work on my desktop.
Currently I use Manjaro XFCE, kernel 5.4 and 4.19.
I initialize the program, the UI just wont do anything. I can still open extra windows with function keys, but I can't close those extra windows with mouse-click. (They are not using the system's WM, only the main window does.) The whole thing just wont interact with my mouse-clicks. The hover-over effects are showing on Setup/Utility etc UI elements but that's it.
I get no errors when I run it from the terminal.
I've found similar question on Ubuntu Studio 19.10: https://askubuntu.com/questions/1201381/x-air-edit-app-not-working-ubuntustudio-19-10#
It does not matter if I run this AUR version, or the one I downloaded from Behringer's page.
Thanx for any help!
I just installed it on GNOME and can't reproduce your issue. My guess is the package is missing dependencies. I must have something installed that you don't. namcap reports libglvnd as a dependency. It appears that should be there instead of mesa. I suggest editing the PKGBUILD and build it again with the new dependency.
Some extra information:
$ ldd X-AIR-Edit
	linux-vdso.so.1 (0x00007ffea4df3000)
	libasound.so.2 => /usr/lib/libasound.so.2 (0x00007fba5cba8000)
	libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x00007fba5cad8000)
	libX11.so.6 => /usr/lib/libX11.so.6 (0x00007fba5c998000)
	libXext.so.6 => /usr/lib/libXext.so.6 (0x00007fba5c980000)
	libGL.so.1 => /usr/lib/libGL.so.1 (0x00007fba5c8f8000)
	libdl.so.2 => /usr/lib/libdl.so.2 (0x00007fba5c8f0000)
	libpthread.so.0 => /usr/lib/libpthread.so.0 (0x00007fba5c8c8000)
	librt.so.1 => /usr/lib/librt.so.1 (0x00007fba5c8b8000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fba5c6c8000)
	libm.so.6 => /usr/lib/libm.so.6 (0x00007fba5c580000)
	libgcc_s.so.1 => /usr/lib/libgcc_s.so.1 (0x00007fba5c560000)
	libc.so.6 => /usr/lib/libc.so.6 (0x00007fba5c398000)
	/lib64/ld-linux-x86-64.so.2 => /usr/lib64/ld-linux-x86-64.so.2 (0x00007fba5ccc8000)
	libbz2.so.1.0 => /usr/lib/libbz2.so.1.0 (0x00007fba5c380000)
	libpng16.so.16 => /usr/lib/libpng16.so.16 (0x00007fba5c348000)
	libz.so.1 => /usr/lib/libz.so.1 (0x00007fba5c328000)
	libharfbuzz.so.0 => /usr/lib/libharfbuzz.so.0 (0x00007fba5c220000)
	libxcb.so.1 => /usr/lib/libxcb.so.1 (0x00007fba5c1f0000)
	libGLdispatch.so.0 => /usr/lib/libGLdispatch.so.0 (0x00007fba5c138000)
	libGLX.so.0 => /usr/lib/libGLX.so.0 (0x00007fba5c100000)
	libglib-2.0.so.0 => /usr/lib/libglib-2.0.so.0 (0x00007fba5bfd8000)
	libgraphite2.so.3 => /usr/lib/libgraphite2.so.3 (0x00007fba5bfb0000)
	libXau.so.6 => /usr/lib/libXau.so.6 (0x00007fba5bfa8000)
	libXdmcp.so.6 => /usr/lib/libXdmcp.so.6 (0x00007fba5bfa0000)
	libpcre.so.1 => /usr/lib/libpcre.so.1 (0x00007fba5bf28000)
$ file X-AIR-Edit
X-AIR-Edit: ELF 64-bit LSB executable, x86-64, version 1 (GNU/Linux), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, for GNU/Linux 2.6.32, BuildID[sha1]=1c6f75d573e5d96af7f0f6fee59cb4452afd55fb, not stripped
$ uname -a
Linux XY-Manjaro 5.4.6-2-MANJARO #1 SMP PREEMPT Tue Dec 24 15:55:20 UTC 2019 x86_64 GNU/Linux
journalctl does not show me anything related.
Thank you for your suggestion.
libglvnd is installed on my system. But I did the rebuild anyway, no changes.
The dependencies cover all the libraries you listed above. If you haven't, make sure you have the base-devel group and base meta package installed. They are assumed to be installed when using the AUR:
sudo pacman -Syu --needed base-devel base
It have installed: (1) base-2-2
I've rebuilt xairedit.
Sadly no changes.
Can it be something XFCE related? Can I start this program in a separate X session? (I hope I am understandable. :smiley: )
Since base is just a meta package, it probably did nothing since you already had all it's "dependencies" installed.
I have switched to another VT.
I started the program with
xinit ./X-AIR-EDIT -- :1 vt5
It started, and I was able to move faders, click mutes, etc.
I am not sure what does this prove though. :smiley: Is this something XFCE related?
I will check on the forums tomorrow.
Thank you! Good night/morning/day/whatever you all have!
d
I managed to kinda crash xfwm4 with
xfwm4 --replace
Now it's terrible but if I start X-AIR-EDIT, it works perfectly.
