Wxpython2.8 build problem
Apparently I need to have wxpython2.8 for some software I want to install.
Following yay guidance I typed:
yay -S wxpython2.8
All seemed to be going well until the scrolling stuff in the terminal stopped and the following appeared:
In file included from src/helpers.cpp:16:
include/wx/wxPython/wxPython_int.h:19:10: fatal error: wx/wx.h: No such file or directory
 #include <wx/wx.h>
compilation terminated.
error: command 'gcc' failed with exit status 1
==> ERROR: A failure occurred in build().
    Aborting...
Error making: wxpython2.8
What should I do next? I’ve searched ‘wxpython2.8’ but haven’t found any clues.
Thanks.
yes is in comments and not fixed by maintainer since 2 months :roll_eyes:
It looks like it is missing a dependency. I installed wxgtk2 first and it built successfully.
Many thanks dalto … that’s worked. :slightly_smiling_face:
