wxpython2.8 build issue
I need wxpython2.8 as a dependency for a program.
I attempted to install wxpython2.8 via
yay -S wxpython2.8.
The build failed.
In file included from src/helpers.cpp:16:
include/wx/wxPython/wxPython_int.h:19:10: fatal error: wx/wx.h: No such file or directory
   19 | #include <wx/wx.h>
compilation terminated.
error: command 'gcc' failed with exit status 1
==> ERROR: A failure occurred in build().
    Aborting...
Yes, I have read Wxpython2.8 build problem.
I have installed wxgtk2.8 successfully. It has not ameliorated the situation.
Any help would be appreciated.
I recently build a package depending on wxpython 2.8 - but it is not available.
I had to change the dependency to wxpython 3 and then the build succeeded.
Which one?
Like @linux-aarhus said, it's possible it can be built with python2-wxpython3 or python-wxpython.
The program Trelby required wxpython2.8 as a dependency. I have since installed it via other means (using trelby-git instead of building it from source.)
Regardless, thanks to both for the tip!
Well, there you go. trelby-git uses python2-wxpython3. :wink:
