Wrong monitor setup
When I boot my computer first Grub menu loads in my second monitor (16:10 DVI) and my main monitor (16:9 HDMI) is not recognized. Why is that?
Then when I boot into the system, the monitor setup is wrong. I set it correctly before, but when I reboot, the wrong setting is restored, meaning that the second monitor is set as my main monitor, where the menu and icons appear, although the startup screen is loaded on the other screen.
I think this is happening since I started to use a newer kernel..
EDIT: After testing with different kernels it seams to have nothing to do with that.
Maybe?
and always
$ inxi -Fxxxz
:wink:
FYI I am still alive just very busy.:slightly_smiling_face:
  Kernel: 5.1.1-2-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.3.0 Desktop: Xfce 4.13.3git-dc69f6 tk: Gtk 3.24.8 info: xfce4-panel
  wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: Z87 Extreme4 serial: <filter>
  UEFI [Legacy]: American Megatrends v: P3.50 date: 03/11/2018
  Topology: Quad Core model: Intel Core i5-4570S bits: 64 type: MCP
  arch: Haswell rev: 3 L2 cache: 6144 KiB
  bogomips: 23154
  Speed: 1996 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 1996 2: 1996
  3: 1995 4: 1996
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
  driver: nvidia v: 418.74 bus ID: 01:00.0 chip ID: 10de:1c82
  Display: x11 server: X.Org 1.20.4 driver: nvidia
  resolution: 1680x1050~60Hz
  OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 418.74
  direct render: Yes
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASRock
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
  Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
  Sound Server: ALSA v: k5.1.1-2-MANJARO
  Device-1: Intel Ethernet I217-V vendor: ASRock driver: e1000e v: 3.2.6-k
  port: f040 bus ID: 00:19.0 chip ID: 8086:153b
  IF: enp0s25 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 4.47 TiB used: 61.17 GiB (1.3%)
  ID-1: /dev/sda vendor: OCZ model: VERTEX4 size: 119.24 GiB speed: 6.0 Gb/s
  serial: <filter> rev: 1.5 scheme: MBR
  ID-2: /dev/sdb vendor: Crucial model: CT525MX300SSD1 size: 489.05 GiB
  speed: 6.0 Gb/s serial: <filter> rev: R021 scheme: MBR
  ID-3: /dev/sdc vendor: Crucial model: M4-CT256M4SSD2 size: 238.47 GiB
  speed: 6.0 Gb/s serial: <filter> rev: 040H scheme: MBR
  ID-4: /dev/sdd vendor: Seagate model: ST4000DM004-2CV104 size: 3.64 TiB
  speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-1: / size: 112.93 GiB used: 61.17 GiB (54.2%) fs: ext4 dev: /dev/sdb2
  ID-2: swap-1 size: 11.72 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb3
  System Temperatures: cpu: 33.0 C mobo: N/A gpu: nvidia temp: 47 C
  Processes: 188 Uptime: 2m Memory: 7.72 GiB used: 971.5 MiB (12.3%)
  Init: systemd v: 242 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.7
  running in: xfce4-terminal inxi: 3.0.34
Thanks, but this didn't fix the issue. The monitor I like to be the main monitor after startup is configured to be my right monitor although I have configured it to be on the left and primary (so monitors are switched wrong). I have to reset the setting to the correct config after every startup.
What is also weird, but maybe unrelated is that very often after startup the Manjaro theme is gone and I see some sort of old Gnome theme. Logging out and in fixes this temporary.
Use a start script for your settings.
It was a known Xfce fail.
I found a workaround for my problem: I used arandr to set the correct monitor position and lxrandr to set the refresh rate (weird enough they both have a setting the other doesn't have) and then put them together as a startup script.
I still find it strange that my display settings are reverted. If I do the following command:
xfce4-display-settings -m
I get the monitor selection screen, but at that point it seams to have picked up my original saved settings correctly.
This issue seemed fixed via update Xfce 4.14pre1. I disabled my personal startup script.
