Hi,
I think I have an issue with my graphic driver and want to confirm that.
Since a cople of month’s, I had the feeling like my display was slugish then I ran some test yesterday an it look’s like the wrong driver is running. I am runnning an NVIDIA GF100GL [Quadro 4000] and all is up to date kernell 5.10.19-1. From the wiki the info that the command return is for a intel driver not Nvidia. Is that correct?
Thx
glxinfo | grep OpenGL
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 11.1.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 20.3.4
OpenGL core profile shading language version string: 4.50
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.1 Mesa 20.3.4
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 20.3.4
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
means that you are using a software OpenGL renderer. After having installed linux510-nvidia390xx, restart the computer and then check your /var/log/Xorg.0.log.
If there is some error saying
Failed to initialize the GLX module;
you will have to amend /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf. The contents of this file should look like
