So this 2.0.13-1 version isnt building. Hope here I can find solution.
In console:
Building latvia-eid-middleware...
==> Making package: latvia-eid-middleware 2.0.13-1 (Thu 26 May 2022 10:59:25 EEST)
==> Retrieving sources...
-> Downloading latvia-eid-middleware-2.0.13-1.zip...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
curl: (92) HTTP/2 stream 0 was not closed cleanly: INTERNAL_ERROR (err 2)
==> ERROR: Failure while downloading https://www.pmlp.gov.lv/sites/pmlp/files/media_file/latvia-eid_2.0.13-1_ubuntu_0.zip
Aborting...
Failed to build latvia-eid-middleware
Interesting the .zip is downloadable manually from given site. Any ideas how to overcome the error?
Thanks in advance,
I would suggest storing the manually downloaded .zip
file — e.g. in ~/Downloads
— and then cd
'ing into that directory. Edit the PKGBUILD
to refer to the location of the .zip
file, and then build the package manually with makepkg
https://wiki.archlinux.org/title/Makepkg
I have discovered this isn’t pamac, exactly. Rather, it seems to be curl
. I get the exact same error when I test the URL with curl
, but it works with wget
. Is it possible to rather use wget
, instead of curl
Edit:
See
https://wiki.archlinux.org/title/wget#pacman_integration
Based on that I’d say change the XferCommand
setting in /etc/pacman.conf
sudo nano /etc/pacman.conf
Change it from:
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
To
XferCommand = /usr/bin/wget --passive-ftp -q --show-progress -c -O %o %u
Save, Ctrl+O and exit Ctrl+X → Y.
Followed by trying again.
Thanks for your input! It would be my first time editing PKGBUILD
file, but looks like this is not an option – the .zip
has only two .deb
files in it:
latvia-eid_2.0.13-1_amd64.deb latvia-eid_2.0.13-1_i386.deb
You could try converting that package into an ALPM package by way of debtap
from the AUR. You don’t need the i386
package.
Thank you for clear instructions! Unfortunately, the same curl error occurs. Tried after saving pacman.conf
and then after restart.
sudo pacman -U latvia-eid-middleware-2.0.13-1-x86_64.pkg.tar.zst
loading packages...
resolving dependencies...
Packages (1) latvia-eid-middleware-2.0.13-1
Total Installed Size: 21.65 MiB
Net Upgrade Size: 2.39 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [###################################] 100%
(1/1) checking package integrity [###################################] 100%
(1/1) loading package files [###################################] 100%
(1/1) checking for file conflicts [###################################] 100%
(1/1) checking available disk space [###################################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) upgrading latvia-eid-middleware [###################################] 100%
/tmp/alpm_BJORFE/.INSTALL: line 41: syntax error near unexpected token `then'
/tmp/alpm_BJORFE/.INSTALL: line 41: ` -a -L /usr/lib/eidlv-pkcs11.so ]; then'
