I’m running Manjaro Cinnamon on a Ryzen-based PC with a Radeon RX 5600XT 6GB graphics card on a QHD monitor. World of WarCraft looks gorgeous! However, at random intervals, the screen will freeze (ambient sounds continue playing) for a few seconds. This is fine for questing but is DEATH in dungeons and raids. Any advice?
I might have fixed it by using the default wine in Lutris instead of one version greater.
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
