Workspace Settings Crashed
panel
#1
Running latest v18 Manjaro.
I had 5 workspaces setup and all working fine this week. Tried to reduce the number of workspaces to 4 using the Workspaces dialog box. When I did that the panel looks like it crashed and it reduced the number of workspaces to 1. When I try to increase the number of workspaces using the + button on the dialog box, it does not respond. Not sure if there are any logs I can pump out to show you. Let me know.
#2
Are you on Xfce, and are you using Compiz? Also post you inxi -Fzxc0 it helps when people know what they are dealing with.
#3
Yes on XFCE. But not using Compiz.
#4
Well first reboot and see if it works after you boot back up. Second post your inxi -Fzxc0 and journalctl -xb
