Hi there, fresh install of Manjaro and I’m absolutely losing it trying to figure this out.
I have a pair of Edifier G2000 speakers attached to the back audio jack, and they are not detected at all by the system. Every other audio output works perfectly fine - my earbuds in the front panel audio jack, the passthrough line-out on my USB microphone, and my monitor’s speakers via DisplayPort. It’s just the speakers in the back panel that don’t work.
Here is the output of some diagnostic commands:
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b89584f5-27fe-4f50-861a-553d68ea9641 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
Type: Desktop Mobo: Gigabyte model: Z590 UD AC v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 01/06/2021
System RAM: total: 16 GiB available: 15.49 GiB used: 2.52 GiB (16.3%)
Info: model: 11th Gen Intel Core i7-11700KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x59
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 3600 min/max: 800/4900:5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 3600 2: 3600 3: 3600 4: 3600 5: 3600 6: 3600
7: 3600 8: 3600 9: 3600 10: 3600 11: 3600 12: 3600 13: 3600 14: 3600
15: 3600 16: 3600 bogomips: 115232
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 535.xx+ status: current (as of 2023-08)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1,HDMI-A-1,HDMI-A-2 empty: DVI-D-1 bus-ID: 01:00.0
chip-ID: 10de:1f08 class-ID: 0300 temp: 50.0 C
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-7:2 chip-ID: 046d:085e
class-ID: 0300 serial: <filter>
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: nouveau gpu: nouveau d-rect: 5360x2520 display-ID: 0
Monitor-1: DP-1 pos: primary,top-left res: 3440x1440 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.3 Mesa 23.1.5 renderer: NV166 direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Pyle USB Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3
chip-ID: 3212:1a03 class-ID: 0300 serial: <filter>
Device-4: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8
Local Storage: total: 2.73 TiB used: 11.32 GiB (0.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte model: GP-ASM2NE6100TTTD
lanes: 4 tech: SSD serial: <filter> fw-rev: EGFM13.0 temp: 37.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 292.97 GiB size: 287.31 GiB (98.07%) used: 11.29 GiB (3.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: b89584f5-27fe-4f50-861a-553d68ea9641
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: E416-804C
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 637.94 GiB fs: ntfs
label: Windows uuid: 78E216FCE216BE76
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 500 MiB fs: ntfs label: Recovery
uuid: 561A17101A16ECAD
ID-4: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/sda2 maj-min: 8:2 size: 1.82 TiB fs: ntfs label: Storage
uuid: 421EB16D1EB15B1D
Device-1: 1-4:2 info: SteelSeries ApS Apex Pro type: keyboard,HID
driver: hid-generic,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1038:1610 class-ID: 0300
Device-2: 1-6:3 info: Pyle USB Microphone type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
Device-3: 1-8:4 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Hub-2: 1-11:5 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 1-12:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-13:10 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-14:8 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
Device-1: 2-7:2 info: Logitech BRIO Ultra HD Webcam type: video,audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 046d:085e class-ID: 0300 serial: <filter>
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nouveau temp: 50.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 0
Processes: 306 Uptime: 21m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1162 libs: 345 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
pactl list cards
Card #44
Driver: alsa
Owner Module: n/a
Properties:
api.acp.auto-port = "false"
api.alsa.card = "1"
api.alsa.card.longname = "HDA NVidia at 0x54080000 irq 17"
api.alsa.card.name = "HDA NVidia"
api.alsa.path = "hw:1"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio1"
device.api = "alsa"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
device.description = "TU106 High Definition Audio Controller"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
device.plugged.usec = "6100313"
device.product.id = "0x10f9"
device.product.name = "TU106 High Definition Audio Controller"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
media.class = "Audio/Device"
factory.id = "14"
client.id = "33"
object.id = "44"
object.serial = "44"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x54080000 irq 17"
device.string = "1"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 4, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "Acer X34"
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
Card #45
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "3"
api.alsa.card.longname = "Pyle USB Microphone Pyle USB Microphone at usb-0000:00:14.0-6, full speed"
api.alsa.card.name = "Pyle USB Microphone"
api.alsa.path = "hw:3"
api.dbus.ReserveDevice1 = "Audio3"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-Pyle_USB_Microphone_Pyle_USB_Microphone_20180928-00"
device.bus_path = "pci-0000:00:14.0-usb-0:6:1.0"
device.description = "Pyle USB Microphone"
device.form_factor = "microphone"
device.icon_name = "audio-input-microphone-analog-usb"
device.name = "alsa_card.usb-Pyle_USB_Microphone_Pyle_USB_Microphone_20180928-00"
device.nick = "Pyle USB Microphone"
device.plugged.usec = "6189699"
device.product.id = "0x1a03"
device.product.name = "Pyle USB Microphone"
device.serial = "Pyle_USB_Microphone_Pyle_USB_Microphone_20180928"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/sound/card3"
device.vendor.id = "0x3212"
device.vendor.name = "Pyle USB Microphone"
factory.id = "14"
client.id = "33"
object.id = "45"
object.serial = "45"
object.path = "alsa:pcm:3"
alsa.card = "3"
alsa.card_name = "Pyle USB Microphone"
alsa.long_card_name = "Pyle USB Microphone Pyle USB Microphone at usb-0000:00:14.0-6, full speed"
alsa.driver_name = "snd_usb_audio"
device.string = "3"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo+input:iec958-stereo: Analog Stereo Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 6555, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: yes)
output:iec958-stereo+input:iec958-stereo: Digital Stereo Duplex (IEC958) (sinks: 1, sources: 1, priority: 5555, available: yes)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-ac3-surround-51+input:analog-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 365, available: yes)
output:iec958-ac3-surround-51+input:iec958-stereo: Digital Surround 5.1 (IEC958/AC3) Output + Digital Stereo (IEC958) Input (sinks: 1, sources: 1, priority: 355, available: yes)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (sinks: 1, sources: 0, priority: 300, available: yes)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-ac3-surround-51+input:analog-stereo
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
Part of profile(s): input:iec958-stereo, output:analog-stereo+input:iec958-stereo, output:iec958-stereo+input:iec958-stereo, output:iec958-ac3-surround-51+input:iec958-stereo
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
Properties:
port.type = "speaker"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-stereo+input:iec958-stereo
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo, output:iec958-stereo+input:iec958-stereo
Card #46
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "2"
api.alsa.card.longname = "Logitech BRIO at usb-0000:00:14.0-7, super speed"
api.alsa.card.name = "Logitech BRIO"
api.alsa.path = "hw:2"
api.dbus.ReserveDevice1 = "Audio2"
device.api = "alsa"
device.bus = "usb"
device.bus-id = "usb-046d_Logitech_BRIO_5BD69A01-03"
device.bus_path = "pci-0000:00:14.0-usb-0:7:1.3"
device.description = "BRIO Ultra HD Webcam"
device.form_factor = "webcam"
device.icon_name = "camera-web-analog-usb"
device.name = "alsa_card.usb-046d_Logitech_BRIO_5BD69A01-03"
device.nick = "Logitech BRIO"
device.plugged.usec = "6180066"
device.product.id = "0x085e"
device.product.name = "BRIO Ultra HD Webcam"
device.serial = "046d_Logitech_BRIO_5BD69A01"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.3/sound/card2"
device.vendor.id = "0x046d"
device.vendor.name = "Logitech, Inc."
factory.id = "14"
client.id = "33"
object.id = "46"
object.serial = "46"
object.path = "alsa:pcm:2"
alsa.card = "2"
alsa.card_name = "Logitech BRIO"
alsa.long_card_name = "Logitech BRIO at usb-0000:00:14.0-7, super speed"
device.string = "2"
Profiles:
pro-audio: Pro Audio (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:analog-stereo
Ports:
Properties:
port.type = "mic"
Properties:
port.type = "spdif"
Card #47
Driver: alsa
Owner Module: n/a
Properties:
api.alsa.card = "0"
api.alsa.card.longname = "HDA Intel PCH at 0x54410000 irq 158"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.path = "hw:0"
device.api = "alsa"
device.bus = "pci"
device.description = "Built-in Audio"
device.name = "alsa_card.pci-0000_00_1f.3"
device.nick = "HDA Intel PCH"
device.plugged.usec = "6106764"
device.product.id = "0x43c8"
device.product.name = "Tiger Lake-H HD Audio Controller"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.vendor.id = "0x8086"
factory.id = "14"
client.id = "33"
object.id = "47"
object.serial = "47"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x54410000 irq 158"
device.string = "0"
Profiles:
pro-audio: Pro Audio (sinks: 2, sources: 2, priority: 1, available: yes)
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Properties:
port.type = "spdif"
card.profile.port = "5"
Note that this command says that analog-input-lineout
is “not available”.
pactl list sinks
Sink #54
State: SUSPENDED
Description: TU106 High Definition Audio Controller Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 59638 / 91% / -2.46 dB, front-right: 59638 / 91% / -2.46 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
alsa.card = "1"
alsa.class = "generic"
alsa.device = "3"
alsa.id = "HDMI 0"
alsa.name = "Acer X34"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
api.alsa.path = "hdmi:1"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "4"
device.api = "alsa"
device.class = "sound"
device.id = "44"
device.profile.description = "Digital Stereo (HDMI)"
device.profile.name = "hdmi-stereo"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
node.name = "alsa_output.pci-0000_01_00.1.hdmi-stereo"
node.nick = "Acer X34"
node.pause-on-idle = "false"
object.path = "alsa:pcm:1:hdmi:1:playback"
priority.driver = "696"
priority.session = "696"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "33"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "54"
object.serial = "54"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.alsa.card = "1"
device.bus = "pci"
device.string = "1"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
Sink #55
State: SUSPENDED
Name: alsa_output.usb-Pyle_USB_Microphone_Pyle_USB_Microphone_20180928-00.analog-stereo
Description: Pyle USB Microphone Analog Stereo
Driver: PipeWire
Mute: no
Volume: front-left: 39977 / 61% / -12.88 dB, front-right: 39977 / 61% / -12.88 dB
balance 0.00
Monitor Source: alsa_output.usb-Pyle_USB_Microphone_Pyle_USB_Microphone_20180928-00.analog-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.card = "3"
alsa.device = "0"
alsa.id = "USB Audio"
alsa.name = "USB Audio"
api.alsa.path = "front:3"
api.alsa.pcm.card = "3"
device.api = "alsa"
device.id = "45"
device.profile.description = "Analog Stereo"
device.profile.name = "analog-stereo"
device.routes = "1"
node.name = "alsa_output.usb-Pyle_USB_Microphone_Pyle_USB_Microphone_20180928-00.analog-stereo"
node.nick = "Pyle USB Microphone"
object.path = "alsa:pcm:3:front:3:playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "18"
client.id = "33"
object.id = "55"
object.serial = "55"
api.alsa.period-size = "512"
api.alsa.period-num = "64"
api.alsa.headroom = "512"
api.alsa.card = "3"
device.bus = "usb"
device.string = "3"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability unknown)
Active Port: analog-output-speaker
Formats:
pcm
Sink #58
State: SUSPENDED
Description: Built-in Audio Analog Stereo
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
Volume: front-left: 57672 / 88% / -3.33 dB, front-right: 57672 / 88% / -3.33 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Properties:
alsa.card = "0"
alsa.device = "0"
alsa.id = "ALC897 Analog"
alsa.name = "ALC897 Analog"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
card.profile.device = "5"
device.api = "alsa"
device.id = "47"
device.routes = "2"
node.name = "alsa_output.pci-0000_00_1f.3.analog-stereo"
node.nick = "ALC897 Analog"
object.path = "alsa:pcm:0:front:0:playback"
factory.id = "18"
client.id = "33"
object.id = "58"
object.serial = "58"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
analog-output-lineout: Line Out (type: Line, priority: 9000, availability group: Legacy 4, not available)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 5, available)
Active Port: analog-output-headphones
Formats:
pcm
What’s really odd is that if I unplug the headphones and re-run pactl list sinks
, the sink that had analog-output-lineout
vanishes and is replaced with this mystery sink:
Sink #315
State: SUSPENDED
Description: Built-in Audio Digital Stereo (IEC958)
Driver: PipeWire
Mute: no
Volume: front-left: 26214 / 40% / -23.88 dB, front-right: 26214 / 40% / -23.88 dB
balance 0.00
Monitor Source: alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor
Flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
alsa.card = "0"
alsa.device = "1"
alsa.id = "ALC897 Digital"
alsa.name = "ALC897 Digital"
api.alsa.path = "iec958:0"
card.profile.device = "6"
device.api = "alsa"
device.id = "47"
device.profile.description = "Digital Stereo (IEC958)"
device.profile.name = "iec958-stereo"
device.routes = "1"
node.name = "alsa_output.pci-0000_00_1f.3.iec958-stereo"
node.nick = "ALC897 Digital"
object.path = "alsa:pcm:0:iec958:0:playback"
priority.driver = "736"
priority.session = "736"
factory.id = "18"
client.id = "33"
object.id = "59"
object.serial = "315"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports:
iec958-stereo-output: Digital Output (S/PDIF) (type: SPDIF, priority: 0, availability unknown)
Active Port: iec958-stereo-output
Formats:
pcm
And lastly, ALSA information script link:
https://alsa-project.org/db/?f=f6f7493ca861796871d0a3faa9137ed5d5da33e1
Any help is much appreciated, I haven’t done a whole lot with Linux since about 2016 so I’m very, very out of practice. Thanks!
