This is a fresh install on a a Lenovo Yoga 7i. I bought the laptop about a year ago, have used windows since purchase because I was worried about drivers. Anyways, there is no audio out of the woofer speakers. I’ve seen that a handful of suggestions say to add an option to the /etc/modprobe.d/alsa-base.conf, but that directory doesn’t exist.
Here’s my alsa project upload.
(I’m not allowed to upload links I guess, so here is the path)
http://alsa-project.org/db/?f=24105c4f27d62a23d0c79d4319221598f6a98c6c
nikgnomic: post edited to show inactive link in preformatted text format
You need to create the file:
sudo mkdir /etc/modprobe.d/alsa-base.conf
Then edit it with whichever editor you prefer (eg: nano):
sudo nano /etc/modprobe.d/alsa-base.conf
Enter the suggested settings; Save; and Reboot.
Cheers.
This worked. The option that I added to the file doesn’t appear to be for my exact laptop series, but if it works don’t touch it. Thanks.
Glad you got it working.
Next time you’re passing by, please share the line that worked for the benefit of other Users with the same issue. Thanks.
Cheers.
