Hello, what is the proper way to install AUR package on Manjaro?
Is good idea “pamac install ufsd-module-dkms” ?
The Arch wiki says:
- Download the ufsd-module-dkmsAUR tarball from the AUR.
- Untar the tarball
- Visit http://www.paragon-software.com/home/ntfs-linux-per/download.html and fill in the request form. You should receive an email with a download link shortly. Download the .tbz file and move it to the package folder.
- Build and install the package
$ makepkg -si
- Check if the module has been installed in dkms.
$ dkms status
pamac can not simplify the task? Anyone installed this module? It is said to be significantly better than NTFS-3G
