I have this Message in journal
wireplumber[1624]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
My System
systemctl --user status wireplumber.service
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-04-15 20:46:37 CEST; 8min ago
Main PID: 1624 (wireplumber)
Tasks: 4 (limit: 14238)
Memory: 23.9M
CPU: 179ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─1624 /usr/bin/wireplumber
Apr 15 20:46:37 weingeist-PC systemd[1339]: Started Multimedia Service Session Manager.
Apr 15 20:46:37 weingeist-PC wireplumber[1624]: Failed to set scheduler settings: Die Operation ist nicht erlaubt
Apr 15 20:46:38 weingeist-PC wireplumber[1624]: <WpSiAudioAdapter:0x563158606070> Object activation aborted: proxy destroyed
Apr 15 20:46:38 weingeist-PC wireplumber[1624]: <WpSiAudioAdapter:0x563158606070> failed to activate item: Object activation aborted: proxy destroyed
systemctl --user list-unit-files|grep pipewire
pipewire-pulse.service disabled enabled
pipewire-session-manager.service alias -
pipewire.service disabled enabled
pipewire-pulse.socket enabled enabled
pipewire.socket enabled enabled
pactl info ✔
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 60
Tile Size: 65472
User Name: weingeist
Host Name: weingeist-PC
Server Name: PulseAudio (on PipeWire 0.3.49)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1b.0.analog-stereo
Default Source: alsa_input.pci-0000_00_1b.0.analog-stereo
Cookie: eaf5:99a7
What is wrong with wireplumber ?
