Wirelesss mouse not working
hello all
I use ASUS M509DA npteboook.
My wireless mouse Dual SmartSwitch BLACK - CONNECT IT not working. I tried very hard to solve it by different sources but unless I didn’t succeed. I send terminal output inxi -Fxxxz
Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X509DA_M509DA
v: 1.0 serial:
Mobo: ASUSTeK model: X509DA v: 1.0 serial:
UEFI: American Megatrends v: X509DA.306 date: 10/11/2019
ID-1: BAT0 charge: 24.2 Wh (95.7%) condition: 25.3/32.0 Wh (79.1%)
volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 106
Info: quad core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP smt: enabled arch: Zen/Zen+ note: check rev: 1 cache:
L1: 384 KiB L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1229 high: 1280 min/max: 1400/2100 boost: enabled
cores: 1: 1280 2: 1222 3: 1222 4: 1221 5: 1222 6: 1221 7: 1222 8: 1223
bogomips: 33550
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x07f1 res: 1920x1080
hz: 60 dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.5") modes:
max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtl8821ce v: N/A pcie: speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
IF: wlp1s0 state: up mac:
IF-ID-1: pan1 state: down mac:
Local Storage: total: 476.94 GiB used: 39.43 GiB (8.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLQ512HALU-00000
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial:
rev: FXV7000Q temp: 10.8 C scheme: GPT
ID-1: / size: 130.48 GiB used: 39.42 GiB (30.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 5.4 MiB (1.8%) fs: vfat
dev: /dev/nvme0n1p1
dev: /dev/nvme0n1p3
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): cpu: 1700
Processes: 258 Uptime: 7m wakeups: 1 Memory: 5.8 GiB used: 3.35 GiB (57.8%)
Init: systemd v: 250 Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1215
pacman: 1205 snap: 10 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.15
It works while I charge my notebook sometimes.
Hi @symbio, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
