I’ve checked the Power settings in the UI, and I didn’t see anything to help.
I connect remotely to my laptop at home using DWService. If I am inactive for any amount of time (because: work) not only am I disconnected from the remote session, but I am also disconnected from the wireless network altogether.
This means that without some individual interaction to physically be at the desktop, I am unable to remotely connect to the machine again.
How can I set the wireless adapted to connect and stay connected regardless if the display goes dark and/or traffic activity?
some wifi cards have a power managment builtin which is controlled by the driver. It is possible to disable it. Could you provide some information about your wifi?
I can as soon as I regain access to it.
@Visone I did check power management app, the yellow oval with the black lightning bolt, didn’t see anything in there. I even checked Advanced Network Management for it, too.
When I arrived home this evening, the system said that the wireless connection needed to be re-validated? I rebooted the OS and it loaded with no issues and no request for additional validation.
What’s the output of cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf …? If it returns wifi.powersave = 3 try changing that value to 2 . I’ll advise as to how if you need that.
Interestingly enough, that file isn’t listed in that directory…? When I manually navigated to there, there were no files listed in the conf.d directory.
Also, it seems to disconnect regardless if there is an active connection to it or not. While obtaining the information for my previous post and obtaining the information that you had requested, the wireless disconnected again. I walked into the other room and had to click on ‘Connect’ twice to get it to reconnect to my SSID.
Connection lasted about an hour and then dropped. Since it’s asking me to re-authenticate to the SSID … is it maybe a keyring thing or something like that?
It seems that the removal of Laptop Mode Tools Configuration with the combination of setting the default to off on the power manage aspect of the device seems to have corrected the issue.
I was able to step away for lunch and when I logged back in I was able to re-connect to the desktop remotely.
I’d like to thank everyone that helped out with this, and took tolerance for a Arch-N00b like myself. I’m sure that I’ll have more questions to ask in the future, I’m happy to know that there are knowledgeable people that I can obtain answers from.
