I can list many wireless Access points or routers or whatever but can`t connect them
at least tries phone hotspot and a router. It tries connect but connection time end after a while.
The phone not detect a connection by the way.
But, good news it solving after first update after external hdd installation
inxi -Fxz
System: Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: Deepin 20.1
Machine: Type: Laptop System: Dell product: Inspiron 3585 v: 1.4.0 serial: <filter>
Mobo: Dell model: 0CNMRV v: X01 serial: <filter> UEFI: Dell v: 1.4.0 date: 05/29/2019
Battery: ID-1: BAT1 charge: 31.2 Wh (100.0%) condition: 31.2/42.0 Wh (74.2%) volts: 12.8 min: 11.4
model: Simplo 0x59,0x36,0x42,0x53,0x00,0x00,0x000C status: Full
CPU: Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP
arch: Zen rev: 0 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31938
Speed: 2336 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 2336 2: 2366
3: 2696 4: 2684 5: 2095 6: 2053 7: 2662 8: 2653
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Dell
driver: amdgpu v: kernel bus-ID: 04:00.0
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-4:3
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting
s-res: 1920x1080
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0 5.10.30-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.2 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 04:00.1
Device-2: AMD Family 17h HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 04:00.6
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel
port: 2000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell
driver: ath10k_pci v: kernel port: 2000 bus-ID: 03:00.0
IF: wlp3s0 state: down mac: <filter>
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 3-2.4:5
Drives: Local Storage: total: 253.12 GiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG30ZMS256G NVMe 256GB size: 238.47 GiB temp: 44.9 C
ID-2: /dev/sda type: USB vendor: Generic model: Flash Disk size: 14.65 GiB
Partition: Message: No partition data found.
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 85.2 C mobo: 0 C gpu: amdgpu temp: 85.0 C
Fan Speeds (RPM): fan-1: 0
Info: Processes: 246 Uptime: 14m Memory: 5.76 GiB used: 2.25 GiB (39.1%) Init: systemd Compilers:
gcc: 10.2.0 Packages: 1170 Shell: Bash v: 5.1.0 inxi: 3.3.04
system journal shows an networks error so long
how can I grep special ones like
journalctl |grep 'AMD-Vi\|can't request\|Failed\|network\|timedated\|network'
