I’ve been reading (too much and now I’m thrashing) - ArchLInux and any other docs I can find in an effort to get my wireguard network configuration setup - to connect to my self-hosted OPNsense router (it works for my other devices as clients exist that make this easy.)
My challenge is ‘translating’ my settings into the Network Configuration setup in Manjaro.
Note: the keys in the interface and peer are correct (I’ve 4x checked)
My IP address is set here (this matches my OPNsense config)
Note: I am assuming that the IPv4 settings are where I need to put what in OPNSense is my Endpoint allowed IP: 192.168.2.5/32 however I am not able to add the “/32” at the end of the IP in this UI ??? NetMask self-filled but not sure what 0.0.0.0 Gateway is needed for? Also - I only use IPv4 for connectivity so I checked the “IPv4 is required for this connection”
DNS Servers: is the same value that works in my other WG VPN settings (for other devices)
Note2: I have nothing set in the ADVANCED or ROUTES options.
My Peer is setup as:
Note: Public Key is correct. Allowed IP’s is set to that 0.0.0.0/0 value - which I use in all my other WG Client setups.
Note2: I am able to ping home.itsamsg.com from my system - so no issues there. Port 51820 is correct. (I use “home.itsamsg.com” in my other device VPN settings - and it works fine.
Some add’l questions?
- where are these .conf files stored? Perhaps I can edit them directly instead of using the network config UI?
Note: while the VPN is ‘connecting’ on my peer system - It is not handshaking with my router…
