Hello,
I’ve been at this for quite a while, and I’m unable to get this figured out.
All I’m trying to do is use my host os to continue browsing with vpn, while my guest kvm is excluded from host vpn, inorder to just connect to internet directly and use Tor.
I understand that I can can do ip route
on Manjaro to get a list. And I know I can somehow add that to postup and predown in a wireguard config file in order to exclude KVM guest vm Whonix-Gateway (Using Network Source: Virtual Network "Whonix-External" : NAT
and device mode is virtrio
) from using host VPN. I’m just not sure how to go about it, and if anyone may please help me out I would really appreciate it.
PS. I’m not sure if it’s okay that I post all these addresses here, does that put me at risk? Please let me know and I will remove it
I was told that I could also exclude libvirt and kvm user groups from firewall rules for wireguard…But I’m not sure how to go about that either.
This is what my mullvad-ca14.conf
file looks like in /etc/wireguard
[Interface]
PrivateKey = <privatekey>
Address = 10.66.218.22/32,fc00:bbbb:bbbb:bb01::3:da15/128
DNS = 193.138.218.74
[Peer]
PublicKey = <publickey>
AllowedIPs = 0.0.0.0/0,::0/0
Endpoint = 107.181.189.206:51820
This is what ip route
looks like:
default via 192.168.1.254 dev wlp2s0 proto dhcp metric 600
10.0.2.0/24 dev virbr1 proto kernel scope link src 10.0.2.2
192.168.1.0/24 dev wlp2s0 proto kernel scope link src 192.168.1.73 metric 600
192.168.122.0/24 dev virbr0 proto kernel scope link src 192.168.122.1 linkdown
This is what my ip addr
looks like with wg-quick up
running a mullvad-ca14.conf
file:
(I am not using systemctl enable/start wg-quick@mullvad-ca14
nor do I have the kill switch added as described in Mullvad’s FAQ for wireguard to be added to the config under [interface])
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether 28:f1:0e:48:d3:b6 brd ff:ff:ff:ff:ff:ff
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether e4:a7:a0:52:13:04 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.73/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp2s0
valid_lft 64592sec preferred_lft 64592sec
inet6 2001:569:fc87:4f00:42cc:f47d:b896:ecde/64 scope global dynamic noprefixroute
valid_lft 14687sec preferred_lft 14387sec
inet6 fe80::ec9d:8da2:38d9:3647/64 scope link noprefixroute
4: virbr2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 52:54:00:cc:b7:c7 brd ff:ff:ff:ff:ff:ff
5: virbr2-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr2 state DOWN group default qlen 1000
6: virbr1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 52:54:00:37:14:76 brd ff:ff:ff:ff:ff:ff
inet 10.0.2.2/24 brd 10.0.2.255 scope global virbr1
7: virbr1-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr1 state DOWN group default qlen 1000
link/ether 5a:5e:05:20:3c:bb brd ff:ff:ff:ff:ff:ff
8: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 52:54:00:8b:1b:95 brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
9: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
14: mullvad-ca14: <POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1420 qdisc noqueue state UNKNOWN group default qlen 1000
link/none
inet 10.66.213.43/32 scope global mullvad-ca14
inet6 fc00:bbbb:bbbb:bb01::3:d52a/128 scope global
15: vnet0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master virbr1 state UNKNOWN group default qlen 1000
link/ether fe:54:00:01:36:c1 brd ff:ff:ff:ff:ff:ff
inet6 fe80::fc54:ff:fe01:36c1/64 scope link
16: vnet1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master virbr2 state UNKNOWN group default qlen 1000
link/ether fe:54:00:2d:cd:9b brd ff:ff:ff:ff:ff:ff
inet6 fe80::fc54:ff:fe2d:cd9b/64 scope link
17: vnet2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master virbr2 state UNKNOWN group default qlen 1000
link/ether fe:54:00:c0:2d:38 brd ff:ff:ff:ff:ff:ff
inet6 fe80::fc54:ff:fec0:2d38/64 scope link
Thanks for taking the time to look at this, as I found one example (sort of), just now on reddit here and earlier I read through Whonix’s Tunneling Wiki however no where does it say how to exclude Whonix-Gateway VM from host VPN wireguard conf, and I still can not figure it out.
EDIT:
I’ve come across this post on gentoo forums, thanks to the Whonix KVM maintainer @hulahoop from whonix forum’s. After a little bit of digging around, I was able to learn a bit from that gentoo forum post, and came across this post on stackexchange regarding a bit more details. However, now I’m more concerned about the [interface[ in the wireguard config file for PostUp and most importantly PreDown, to make sure it that iptables rule gets remove when I disconnect from the wireguard connection.
Still hoping someone can help me make sense of it to do it properly. Thanks again for reading this far…
