Where did it go? I switched to the 5.4 kernel for a while because I’m on a Thinkpad T440P and feel as if I don’t really need the latest & greatest, plus I just like the fact that it’s supported till 2025 and don’t like to make a lot of changes to my system. Anyhow, I need wireguard-lts for Torguard vpn, but it seems to be gone.
Torguard has wireguard-tools as an optional dependency, could it be that you are mistaken?
Mistaken about what? wireguard-lts can’t be installed, and I need it because Torguard will not connect with wireguard without it.
cj@thinkpad ~]$ sudo pacman -S wireguard-lts
[sudo] password for cj:
error: target not found: wireguard-lts
Well there is no such package and the Torguard AUR package has wireguard-tools as a dependency.
What makes you think it needs wireguard-lts, where does it say so?
What makes me think I need it? Uh, because it’s not working?
And yes, there is such a package. There used to be, anyway. Now it’s gone.
these are the dependencies for Torguard:
iproute2 (iproute2-git, iproute-mptcp, iproute2-selinux)
qt5-declarative (qt5-declarative-git)
qt5-websockets (qt5-websockets-git)
shadowsocks-libev (shadowsocks-libev-git)
stunnel (stunnel-systemd-git)
unbound
wireguard-tools (wireguard-tools-git) (optional) – wireguard support
For wireguard support you need wireguard-tools!
It’s an optional dependency of wireguard-tools, WHICH I ALREADY HAVE, OBVIOUSLY… Do I need to post a screenshot to prove it to you?
There is no such package as wireguard-lts. You need wireguard-tools for wireguard support. Good luck!
I saw that but there is no such package in the official repos or the AUR
No kidding… ya think? Why do you suppose that I made this topic? It wont run on the 5.4 kernel, nothing else has changed, so that is the only explanation.
You could use a non LTS kernel if that is an option?
I don’t want to use a non-lts kernel, for reasons that have already been explained in my op.
[cj@thinkpad ~]$ sudo pacman -U https://archlinux.org/packages/extra/x86_64/wireguard-lts
wireguard-lts 13.0 KiB 89.1 KiB/s 00:00 [########################################] 100%
error: failed retrieving file 'alpmtmp.eoVkSt' from archlinux.org : The requested URL returned error: 404
warning: failed to download https://archlinux.org/packages/extra/x86_64/wireguard-lts/.sig
loading packages...
error: '/var/cache/pacman/pkg/wireguard-lts': package missing required signature
I have a feeling Mirdarthos will have the answer…
Hi guys,
Apologies for butting in.
IIRC Wireguard will only work from Kernel 5.8 onwards without a DKMS package. This mena it’ll not just work with kernel version 5.4.
Fortunately, @pretzelbrain, Kernel version 5.10 is set to be the next LTS version, so I’m guessing you can install it and maybe Wireguard will then come back to you.
Edit:
When searching with pamac search
there are many results for “wireguard”:
$ pamac search wireguard
wgroute 1.0.1-1 AUR
A tiny script to use if you want to route all of your packets through WireGuard without wg-quick
wgmgr 1.5.2-1 AUR
Manages WireGuard PKIs for VPN-like deployments
wgcf 2.1.4-1 AUR
Generate WireGuard profile from Cloudflare Warp account
tunsafe-git r9.ge116360-1 AUR
High performance and secure VPN client that uses the WireGuard protocol
tunsafe 1.4-1 AUR
python-wgtools-git r11.f986439-2 AUR
Python bindings for wireguard-tools
python-wgtools 1.0.1-1 AUR
lxc-service-snapshots 2.17-1 AUR
Run disposable (read-only then delete) Linux containers (LXC) to serve up OpenVPN, Pi-Hole, or WireGuard.
dynwg 1.1.3-1 AUR
A DynDNS watchdog for WireGuard over systemd-networkd
boringtun-git 0.3.0.13.g362be0d-1 AUR
Userspace WireGuard® Implementation in Rust
vxwireguard-generator-git r16.779f0a5-1 AUR
Utility to generate VXLAN over Wireguard mesh SD-WAN configuration
systemd-wireguard-refresh-git r4.6e75115-2 AUR
A script and configuration files to refresh Wireguard endpoints periodically (or not)
prometheus_wireguard_exporter 3.4.1-1 AUR
A prometheus exporter for wireguard stats
networkmanager-wireguard-git r87.0e1124d-1 AUR
NetworkManager VPN plugin for WireGuard - git
networkmanager-wireguard 0+r87+g0e1124d-1 AUR
mkinitcpio-wireguard 0.4.1-1 AUR
mkinitcpio hook that initialises Wireguard to assist in the remote unlocking of encrypted partitions.
wireguard-vanity-address 0.4.0-1 AUR
Generate Wireguard keypairs with a given prefix string
wireguard-tools-git 0.0.20190601.r2.gaab8bec-1 AUR
next generation secure network tunnel - git checkout
wireguard-tools 1.0.20200827-1 extra
next generation secure network tunnel - tools for configuration
wireguard-module-git 0.0.20191226.r4.g7481b6a-1 AUR
Fast, modern, secure VPN tunnel (kernel module)
wireguard-go-git v0.0.20191012.13.gddfad45-1 AUR
Go userspace implementation of WireGuard
wireguard-dkms-git 0.0.20190601.r2.gaab8bec-1 AUR
wireguard-dkms 1.0.20201221-1 extra
next generation secure network tunnel - module sources
So, maybe it is there, just with another name, or something? Perhaps wireguard-tools
. I don’t know. I’m no expert.
I feared that this might be the case. sigh I was on 5.10, and a few things seemed glitchy. Also, according to what I have read, it’s not supported for as long as 5.4.
I have the dkms package installed, btw.
I already have wireguard-tools installed, as well. Wireguard-lts is listed as an optional dependency for it.
It is set to become LTS when 5.11 is released, if I understand correctly. I don’t really know what’s glitchy according to you, but I have it, and use it daily for about 8-10 hours straight, with no problems. I don’t find anything glitchy at all.
