Wireguard connection with Plasma Network Manager
Hi. I have a Raspberry Pi with Wireguard. I exprorted the wireguard configuration as .conf file.
When I import in Network Manager Plasma, it created a connection, but when I active it, I can't navigate. I haven't connection.
I think the problem is the IP. The VPN connection is configured as static IP with 172.27.66.2/24 and gateway 0.0.0.0.
Any ideas?
NetworkManager does not support WireGuard connections in the GUI yet. However, you can install networkmanager-wireguard-git from the AUR and then you'll have the option to create a Wireguard VPN.
But the KDE Plasma show the Wireguard config dialogs
